[Sammelthread] NVIDIA GeForce RTX 4090 + FAQ
Here we go again
Quelle:
TEST:
Karten:
News:
Wakü News:
Shops:
PowerLimits:
KarteMinMax
4090 Founders Edition450W600W
4090 Gainward Golden Sample450W450W
4090 MSI Suprim X450W450W Silent Mode / 520W Power Modus
4090 STRIX OC500W600W / Dual Bios
4090 Aorus Master450W600W
4090 Zotac AMP Extreme450W495W
4090 MSI Suprim Liquid X480W530W / Selten auch 600W
4090 Gigabyte Gaming OC450W600W
4090 Palit Gamerock OC450W500W
CARDGPU Voltage PhasesGPU Voltage ControllerGPU MOSMOS Current (A)Total GPU CurrentMemory Voltage PhasesMemory Voltage ControllerMemory MOSMOS Current (A)Total Memory CurrentTotal PhasesSource
MSI Suprim X (& Liquid)
26​
Monolithic MP2891Monolithic MP86957
70​
1820​
4​
70​
280​
30​
Techpowerup
ASUS STRIX OC
24​
Monolithic MP2891OnSemi FDMF3170
70​
1680​
4​
70​
280​
28​
Techpowerup
Nvidia Founders
20​
70​
1400​
3​
70​
210​
23​
Techpowerup
Colorful Vulcan (& Neptune)
24​
uPI uP9512UAlpha & Omega AOZ5311NQI-03 BLN3
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI-03 BLN3
55​
220​
28​
Techpowerup
Zotac AIRO
24​
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI BLN0
50​
200​
28​
Techpowerup
ASUS TUF OC
18​
Monolithic MP2888AInfineon TDA21570
70​
1260​
4​
uPI uP9512QVishay SIC638A
50​
200​
22​
Hardware Unboxed
Gigabyte Gaming OC
20​
uPI uP9512UVishay SIC653A
50​
1000​
4​
uPI uP9512RVishay SIC653A
50​
200​
24​
Techpowerup
MSI Gaming Trio X
18​
Monolithic MP2891OnSemi NCP303151
50​
900​
4​
50​
200​
22​
CoolPC
Palit GameRock OC
16​
uPI uP9512UOnSemi NCP302150
50​
800​
3​
uPI uP9512ROnSemi NCP302150
50​
150​
19​
Techpowerup
Zotac Trinity OC
14​
55​
770​
4​
50​
200​
18​
CoolPC
Inno3D X3 OC
14​
uPI uP9512UAlpha & Omega AOZ5311NQI BLN0
55​
770​
3​
55​
165​
17​
KitGuru
Gigabyte Windforce
14​
?Vishay SIC653A
50​
700​
4​
?Vishay SIC653A
50​
200​
18​
profesionalreview
Tool
How To?
Anleitung
7. Enter drücken
10. PC neu starten
Seasonic
gibt Ihren Kunden das Kabel Umsonst, für spezielle Seasonic-NT, welche in den letzten 12 Monaten gekauft wurde.
Corsair
FAQ:
Verliere ich Leistung, wenn ich die RTX 4090 mit PCIe 3 laufen lasse? > Ja, ca 2,1% :) Also nicht viel
Quelle: https://www.computerbase.de/2022-10...hnitt_die_geforce_rtx_4090_mit_pcie_30_update
@ssj3rd
Man wird faul ja...
Ein Game laden war früher teilweise richtig Arbeit (mechanisches Zählwerk am Casettenrecorder ablesen etc)
Partitionstabelle einer HDD einrichten? Partitionstabelle inkl. def. Sektoren selbst schreiben :fresse:
Druckertreiber installieren? Druckertreiber selbst schreiben. Da war das fette Handbuch dein bester Freund (www gabs ja noch keins - es wusste auch kein normaler Mensch, was das ist) :d
im using linux bitch tell me about it
Und jetzt bestimmt erst mal Urlaub eingereicht für 6 Wochen? Oder doch gleich eine Kur? 😂
gaga kur im kopf:fresse2:
muss ich jetzt auf türkisch zocken:fresse2: wenn ich jz die region wieder ändere sperrens bestimmt den account, was auch egal wäre aber gut machbarkeitsstudie :wink:
also in timespy säuft die karte wie ein loch. also alles in ordnung :d
Moin,
ich werde diese Woche ein neues System aufbauen und wollte mich dann auch etwas mit Undervolting beschäftigen. Nun möchte ich die Änderungen, welche ich vornehme, natürlich auch qualitativ bewerten und schaue mir derzeit an, was es so an GPU-Benchmarks gibt. Kenne natürlich die Klassiker wie 3DMark, unigine etc. Was ich derzeit aber nicht weiß wie repräsentativ diese sind, wenn ich die Werte später aufs Gaming umlegen möchte. Natürlich könnte ich auch direkt ein Game mit eingebautem Benchmark nehmen, jedoch denke ich nicht, dass dies so repräsentativ ist.
Naiv erhoffe ich mir, dass ein reines Benchmark-Tool hier mehrere Situationen breiter abdeckt. Hat hier jmd. eine gute Empfehlung?
So ein super Tool gibt’s nicht, leider.
Da hilft wirklich nur testen. Kann sein dass es bei 4 oder 5 Spielen ohne Probleme läuft und zack, das nächste ist nicht mehr stabil.
Für all Diejenigen, wie mich, die es nervt, wenn man nach einer Einstellung vom "Energieverwaltungsmodus" (im NV-Panel) einen PC-Neustart machen musste, damit die neue Einstellung wirksam wird
Es reicht, wenn man sich abmeldet und sofort wieder einloggt... :)
Kurz nach dem Einloggen tanzt "Board Power Draw" (GPU-Z) noch bissl herum, aber wenige Sekunden später senkt sich die Idle-Last von 60W auf 6W ab (oder umgekehrt, wenn "Maximale Leistung bevorzugen" eingestellt wurde). Warum eine Änderung, der Einstellung "online" (laufender Acc) immer noch nicht funktioniert - k.A.
Im Übrigen geht es auch, wenn man den NV-Treiber kurzfristig deaktiviert. Etwa beim simulierten speichern, des BIOS (GPU-Z). Ein kurzfristiges de- und aktivieren des NV-Treiber sollte auch mit einer kleinen *.bat funktionieren ;)
Doch hab ich. Wusste nicht, dass die dann direkt aus EU versenden (ändert ja aber nichts daran, dass noch nicht versant wurde).
Habe am 27.03. bestellt und der Adapter ist heute eingetrudelt, nachdem er 2 Wochen bei DPD in der Blackbox unterwegs war.
Fun fact: Das Seitenglas des Lian Li O11 Dynamic mit der Gigabyte Gaming OC geht auch mit / trotz Adapter nicht zu. Der Adapter baut einfach zu sehr auf. Geil..
Danke für die Rückmeldung, das hatte ich befürchtet. Man knickt zwar nicht mehr, aber der Adapter braucht am Ende auch nicht viel weniger Platz als ne enge Rundung.
Naja, auch auf Grund des Preises bin ich froh, dann doch gleich das Gehäuse gewechselt zu haben. War am Ende trotz kompletter Systemmigration wohl die stressfreiere Lösung.
Ich hoffe trotzdem ein deutscher Händler legt sich die ans Lager und dann verkaufen Sie sich wie warme Semmeln
Habe jetzt aus der Not heraus einen von Amazon gekauft: https://www.amazon.com/-/de/gp/product/B0C1H39CSB/ref=ox_sc_act_title_1?smid=A3HGOXAIP94F64&psc=1
Wie es aussieht, ist dieser ca. 1cm kürzer. Ich hoffe das reicht.
Aus Interesse, auf welches Gehäuse bist Du gewechselt? Ich hab das O11 Dynamic in der PCMR Edition hier stehen und kämpfe echt mit mir kein anderes, breiteres Gehäuse zu kaufen :cry:
die doppelkammer cases haben nämlich genau das problem dass der bereich vorne recht schmal ist sonst wird es zu breit.
Siehe System links. Habe mir das NZXT H7 Flow zugelegt, da passt wirklich jede 4090 rein. Kam von einem Lian Li 205 Mesh. Das konnte ich noch für 70€ verkaufen, daher hielt sich der Verlust in Grenzen. Die Temps sind im H7 auch um ~5°C niedriger, hat sich also doppelt gelohnt.
Und warum hoffst Du das? Wenn Du einen willst, kannst doch auch so einen bestellen.
OMG!!! :oops: Muss ich haben 😍
Nächstes Ziel 4090 mit 48GB :fresse:
Und das nächste AAA Titel mit crappy Performance:
Zitat:
„Star Wars Jedi: Survivor ist ein weiteres PC-Spiel, das beim Testen unter massiven technischen Problemen leidet. Selbst mit einer Geforce RTX 3080 oder 4090 bricht die Bildrate nach längerem Spielen massiv ein (unter 20 FPS), weil der VRAM vollläuft, sodass ihr neu starten müsst.
Es gibt störende Nachladeruckler, asynchronen Ton und immer mal wieder Glitches und kleinere Bugs, aber vor allem die Performance ist ein großes Problem.“
Quelle: https://www.gamestar.de/artikel/star-wars-jedi-survivor-technik-check-pc,3393057,seite2.html
Und das bei nem Schlauchlevel Spiel
ja kein wunder
Der Sommer kommt und bis zum Herbst werden die es schon patchen. Kohle gibt's erst wenn's funktioniert. Gilt bei mir für alle Titel, meist dann noch günstiger zu holen.
Wird immer schlechter mit den neuen Titeln, sollte keiner so kaufen 😎
einfach gnadenlos kaputtvoten. anders lernen die es nicht
Och Nee. Habe das Game zwar zur CPU bekommen aber werde da sicherlich erstmal einige Zeit abwarten bis ich das starte. Kann doch nicht wahr sein. Wie kann sowas wie Dead Island 2 aus der Entwicklungshölle nahezu perfekt auf PC laufen Day1 und so große Publisher und Entwickler kriegen es einfach nicht hin. Es nervt nur noch. Aber war ja fast zu erwarten. Der Vorgänger hat bis heute Stuttering Probleme auf PC.
Traurig, aber hab schon damit gerechnet. Es ist ja inzwischen die Ausnahme, dass die Spiele spielbar released werden auf dem PC.
D.h. es wird wie immer erstmal angeblich ein Day1 Patch kommen. Der fixt dann bestimmt wieder alles, außer die Performance.
Ähnliche Themen
Antworten
7K
Aufrufe
541K
