[Sammelthread] NVIDIA GeForce RTX 4090 + FAQ
Here we go again
Quelle:
TEST:
Karten:
News:
Wakü News:
Shops:
PowerLimits:
KarteMinMax
4090 Founders Edition450W600W
4090 Gainward Golden Sample450W450W
4090 MSI Suprim X450W450W Silent Mode / 520W Power Modus
4090 STRIX OC500W600W / Dual Bios
4090 Aorus Master450W600W
4090 Zotac AMP Extreme450W495W
4090 MSI Suprim Liquid X480W530W / Selten auch 600W
4090 Gigabyte Gaming OC450W600W
4090 Palit Gamerock OC450W500W
CARDGPU Voltage PhasesGPU Voltage ControllerGPU MOSMOS Current (A)Total GPU CurrentMemory Voltage PhasesMemory Voltage ControllerMemory MOSMOS Current (A)Total Memory CurrentTotal PhasesSource
MSI Suprim X (& Liquid)
26​
Monolithic MP2891Monolithic MP86957
70​
1820​
4​
70​
280​
30​
Techpowerup
ASUS STRIX OC
24​
Monolithic MP2891OnSemi FDMF3170
70​
1680​
4​
70​
280​
28​
Techpowerup
Nvidia Founders
20​
70​
1400​
3​
70​
210​
23​
Techpowerup
Colorful Vulcan (& Neptune)
24​
uPI uP9512UAlpha & Omega AOZ5311NQI-03 BLN3
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI-03 BLN3
55​
220​
28​
Techpowerup
Zotac AIRO
24​
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI BLN0
50​
200​
28​
Techpowerup
ASUS TUF OC
18​
Monolithic MP2888AInfineon TDA21570
70​
1260​
4​
uPI uP9512QVishay SIC638A
50​
200​
22​
Hardware Unboxed
Gigabyte Gaming OC
20​
uPI uP9512UVishay SIC653A
50​
1000​
4​
uPI uP9512RVishay SIC653A
50​
200​
24​
Techpowerup
MSI Gaming Trio X
18​
Monolithic MP2891OnSemi NCP303151
50​
900​
4​
50​
200​
22​
CoolPC
Palit GameRock OC
16​
uPI uP9512UOnSemi NCP302150
50​
800​
3​
uPI uP9512ROnSemi NCP302150
50​
150​
19​
Techpowerup
Zotac Trinity OC
14​
55​
770​
4​
50​
200​
18​
CoolPC
Inno3D X3 OC
14​
uPI uP9512UAlpha & Omega AOZ5311NQI BLN0
55​
770​
3​
55​
165​
17​
KitGuru
Gigabyte Windforce
14​
?Vishay SIC653A
50​
700​
4​
?Vishay SIC653A
50​
200​
18​
profesionalreview
Tool
How To?
Anleitung
7. Enter drücken
10. PC neu starten
Seasonic
gibt Ihren Kunden das Kabel Umsonst, für spezielle Seasonic-NT, welche in den letzten 12 Monaten gekauft wurde.
Corsair
FAQ:
Verliere ich Leistung, wenn ich die RTX 4090 mit PCIe 3 laufen lasse? > Ja, ca 2,1% :) Also nicht viel
Quelle: https://www.computerbase.de/2022-10...hnitt_die_geforce_rtx_4090_mit_pcie_30_update
Hat Mal jemand von euch in letzter Zeit was nach Alternate gesendet. Vor über 1 Woche was als Widerruf zurück geschickt. Am 15.02.23 4:58 laut DHL Sendebericht
Die Sendung wurde direkt ab Paketzentrum dem Geschäftskunden zugestellt.
seit dem Null keine Mail von Alternate das die Retoure eingegangen ist noch sonst was. Das es Mal 2 Tage Dauern kann ist mir bewusst aber das ist jetzt schon einiges Länger.
Laut Hotline ne noch net bei uns, wenn bekommen sie eine Mail mh ja toll.
Sammeln die Retouren erst 1-2 Wochen oder was machen die ?
evt kann ja jemand Licht ins Dunkel bringen.
@Miles2009
Ja, am 30.01.23 eine Retoure an Alternate geschickt und laut DHL Sendungsverfolgung am 30.01.23 wurde Die Sendung direkt ab Paketzentrum dem Geschäftskunden zugestellt.
Die Eingangsbestätigung der Retoure von Alternate kam per Mail am 08.02.23 und die Paypal Mail bezüglich der Rückzahlung von Alternate kam dann am 09.02.23. Das Geld war am 10.02.23 wieder auf meinem Konto.
Es kann also schon mal ein paar Tage dauern.
Grüße
Bis auf das fehlende Raytracing, was schon schade ist, scheint Atomic Heart aber echt mal wieder ein gut optimiertes PC Spiel zu sein und das ab Tag 1. Damit schafft das Entwicklerteam mit ihrem ersten Spiel was große Publisher und Entwickler auch Wochen nach Release nicht auf die Kette kriegen und zeigt mal wieder, dass es auch mit der UE4 geht, wenn man denn will. (y)
Frame Generation ist denke ich ohne RT in dem Spiel nicht notwendig. In der Anfangsphase wo ich kurz getestet habe, hatte ich jetzt mit FG und ohne DLSS super resolution an die 200 Fps in 4K Max. Mal sehen ob der Inputlag nervt, ansonsten kann man das auch ohne Probleme komplett ohne DLSS Gedöns zocken oder mit Super Resolution auf Qualität, wenn man die 120fps haben will.
Werde diesmal aber nicht auf RT warten. Nachher wird das so wie bei Plague Tale. Ewig drauf warten und dann patchen sie heimlich super schlechtes RT dazu. Einfach Gamepass holen und jetzt zocken.
Die Strix hier ist dann wirklich schlecht gebinned für den Preis, wenn überhaupt.
Meine ist heute auch gekommen. Boost out of the Boox 2820mhz. ab 57°C einen Bin nach unten auf 2805Mhz. Summt wien kleiner Bienenstock aber nicht hochfrequent. Kann ich mit leben.
@Gurkengraeber Also +200/1500 kacken im Metro Bench im 2. Lauf ab.
+150/+1500 scheinen zu laufen. Resultiert bei stock Spannung in 2955mhz und mit 1.1v bei 3000mhz bei 70°C ca.
Also auch kein sonderlich guter Chip. Mit Wakü könnten aus 2955mhz dann eventuell knapp 3000 bei 1.05v werden, da sie unter 50°C noch 3 Stufen höher taktet (+45mhz).
Wollte dir grad zum guten Chip gratulieren. Ich hab meine 3Ghz aber jetzt auch nicht in allen möglichen Games getestet. In RDR2, GR Breakpoint und Division 2 lief es aber ohne Artefakte.
Meine Karten lasse ich aber sowieso zu 100% stock kaufen. Also weder undervoltet noch übertaktet. Habe nur ein Frame Cap bei 144 drin, ist halt das was der Monitor schafft.
Naja 3015mhz mit 1.1v haben 25 Durchläufe Metro Exodus Benchmark durchgehalten. 2955mhz mit 1.05v ebenfalls bei ca. 70°C auf der GPU. Unter Wasser würden dann halt noch mal 3 Taktstufen mehr Anliegen solange die Karte unter 54°C ist. Also 3ghz mit 1.05v und 3060 mit 1.1v.
Ob das gut oder schlecht ist kann ich nicht beurteilen. Ist erst meine Dritte 4090. Die anderen waren aber schlechter.
Der Speicher scheint nicht schlecht zu sein. Lief eben mit +1750 noch durch Port Royal ohne Artefakte durch. Gibt zu +1600 auch noch mehr Punkte. +1800 gibt auch noch mehr Punkte.
Hast Recht... bestelle noch einen heute :fresse:
Der geht eh gerade günstig her für 314 Steinchen. Gratisspiel (Company of Heroes 3) inklusive. Bau deiner Schwester aber den schlechteren Chip ein ;)
Bin auf nächste Woche gespannt, wenn zwei neue X3D erscheinen...
Bin eher gespannt, welchen Performance-Sprung man mit einer 4090 bekommt. Und auf den Preis natürlich auch. Der 7950X3D soll ja knapp um 700 Dollar kosten, der 7900X3D um 600 Dollar. Ab dem 06.04.2023 gibt es dann auch den massentauglicheren 7800X3D für 449 Dollar.
Die neuen X3Ds sind interessant, aber für mich wenn dann erst im April mit dem 7800er. Aber mal sehen wie viel besser als der 5800X3D die dann überhaupt sein werden. Wirklich notwendig werden sie aber sowieso nicht sein bei 4K :fresse: Wobei ja immer mehr Games kommen, die durchaus CPU limitiert sind in 4K mit der 4090. Allerdings bringen 15-20% mehr CPU Leistung da dann oft auch nicht wirklich viel. Wenn ich mir Hogwarts angucke mit Raytracing in Hogsmeade...FPS irgendwo bei 40, selbst mit High End CPUs... da sind 20% mehr Leistung quasi nichts. Dasselbe bei Plague Tale Requiem mit aktiviertem RT.
Ist ziemlich surreal das immer zu lesen
Eine ist im Freundeskreis untergekommen und eine habe ich noch hier. Kein Scalping und FAG Binning.
Hat mal einer ne Hausnummer was UV mäßig so der ,, Standard,, ist? 0.95v bei 2745?
Igor hat es doch schon gesagt, dass man die Erwartungen runter schrauben sollte.
@captn1ko
Du musst dich nicht rechtfertigen ;)
Auch wenn ich es nicht gutheiße, wenn Manche drei, vier, fünf oder drölf GPUs testen und retournieren
Viel schlimmer finde ich zerstörungsfrei geöffnete Siegel und die Ware als "ungeöffnet/versiegelt" zu retournieren
Worst case darf sich der unbedarfte Käufer über Kratzer und/oder über nicht vollständig entfernte WLPaste am IHS seiner "versiegelten" CPU wundern :rolleyes2:
Gibt's hier im Forum überhaupt eine 4090er die 3000+ (1.05v) oder 3100+ (1.1v) wirklich rockstable laufen?
Falls jemand will, die 4090 Ventus für 1549 € im Mindstar
haben ihren Fehler wohl bemerkt, jetzt 1849 😬
@captn1ko
Wie soll das denn gehen ? Meine Sendung ist immer noch net da bei alternate laut Retoure, heute angerufen ja heute angekommen, Gutschrift ist auch schon erstellt soll wohl morgen per PayPal da sein das Geld, werde dann ne Strix White oc Bestellen und habe hoffentlich keinen Bienenstock xD.
Hat aber echt lange gedauert und tut es noch mit Alternate finde ich. Und das die erst sammeln Retouren und dann erst bearbeiten finde ich auch schwach.
Im Outlet sind auch seit heute gesamt 3 Game Rock Omni Black gelandet. Vorher war da nur eine. 1749 Euro aber bei den ihrer Beschreiben blicke ich nicht durch Verpackung der wäre beschädigt was heißt das ?
bei manchen steht Funktioniert aber normal bei einer steht das nicht ist die Funktionsunfähig oder wie ?
Zu meiner Eingeschickten Karton alles 1a karte nur mit Weißen Handschuhen angepackt, war ca 30 min verbaut einmal kurz Hogwarts ca 30 min sofort wieder verpackt und eingeschickt. Bis auf Siegelbruch sage ich unter eid wie Neu Eingeschickt. Wie kommt dann Verpackung leicht beschädigt weil das steht ja bei allen ?
Heißt Siegel Bruch Verpackung beschädigt Denke ja oder m
Egal welches Video ich angesehen habe, ebenso meine Strix 4090 und Strix 3090 haben gesummt.
Wahrscheinlich sind bei Leuten, die behaupten ihre Strix summt nicht, die Lüfter einfach zu laut XD . Bei meiner Gigabyte ist mit UV dagegen wirklich (fast) Ruhe. Die hört man nur minimal solange die Lüfter noch aus sind.
Ähnliche Themen
Antworten
7K
Aufrufe
540K
