[Sammelthread] NVIDIA GeForce RTX 4090 + FAQ
Here we go again
Quelle:
TEST:
Karten:
News:
Wakü News:
Shops:
PowerLimits:
KarteMinMax
4090 Founders Edition450W600W
4090 Gainward Golden Sample450W450W
4090 MSI Suprim X450W450W Silent Mode / 520W Power Modus
4090 STRIX OC500W600W / Dual Bios
4090 Aorus Master450W600W
4090 Zotac AMP Extreme450W495W
4090 MSI Suprim Liquid X480W530W / Selten auch 600W
4090 Gigabyte Gaming OC450W600W
4090 Palit Gamerock OC450W500W
CARDGPU Voltage PhasesGPU Voltage ControllerGPU MOSMOS Current (A)Total GPU CurrentMemory Voltage PhasesMemory Voltage ControllerMemory MOSMOS Current (A)Total Memory CurrentTotal PhasesSource
MSI Suprim X (& Liquid)
26​
Monolithic MP2891Monolithic MP86957
70​
1820​
4​
70​
280​
30​
Techpowerup
ASUS STRIX OC
24​
Monolithic MP2891OnSemi FDMF3170
70​
1680​
4​
70​
280​
28​
Techpowerup
Nvidia Founders
20​
70​
1400​
3​
70​
210​
23​
Techpowerup
Colorful Vulcan (& Neptune)
24​
uPI uP9512UAlpha & Omega AOZ5311NQI-03 BLN3
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI-03 BLN3
55​
220​
28​
Techpowerup
Zotac AIRO
24​
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI BLN0
50​
200​
28​
Techpowerup
ASUS TUF OC
18​
Monolithic MP2888AInfineon TDA21570
70​
1260​
4​
uPI uP9512QVishay SIC638A
50​
200​
22​
Hardware Unboxed
Gigabyte Gaming OC
20​
uPI uP9512UVishay SIC653A
50​
1000​
4​
uPI uP9512RVishay SIC653A
50​
200​
24​
Techpowerup
MSI Gaming Trio X
18​
Monolithic MP2891OnSemi NCP303151
50​
900​
4​
50​
200​
22​
CoolPC
Palit GameRock OC
16​
uPI uP9512UOnSemi NCP302150
50​
800​
3​
uPI uP9512ROnSemi NCP302150
50​
150​
19​
Techpowerup
Zotac Trinity OC
14​
55​
770​
4​
50​
200​
18​
CoolPC
Inno3D X3 OC
14​
uPI uP9512UAlpha & Omega AOZ5311NQI BLN0
55​
770​
3​
55​
165​
17​
KitGuru
Gigabyte Windforce
14​
?Vishay SIC653A
50​
700​
4​
?Vishay SIC653A
50​
200​
18​
profesionalreview
Tool
How To?
Anleitung
7. Enter drücken
10. PC neu starten
Seasonic
gibt Ihren Kunden das Kabel Umsonst, für spezielle Seasonic-NT, welche in den letzten 12 Monaten gekauft wurde.
Corsair
FAQ:
Verliere ich Leistung, wenn ich die RTX 4090 mit PCIe 3 laufen lasse? > Ja, ca 2,1% :) Also nicht viel
Quelle: https://www.computerbase.de/2022-10...hnitt_die_geforce_rtx_4090_mit_pcie_30_update
Ich komm über 310 Watt. Also der drosselt kein PT Limit. Bei timespy extreme hab ich bei 133 Prozent über 530 Watt kurzzeitig.
Das komische dabei ist, stock kommt eigentlich das gleiche raus ^^.
Hast du vielleicht ausversehen irgendwie ne Curve bei dir Aktiviert bzw geändert ?
Wollte ich auch fragen...
Zum Benchen nutze ich nie Curve
Wegen deiner Strix...
Was wir nicht kennen sind deine und seine VRAM-Timings
Hatte letztens bei div. EVC2-Screenshots gesehen, dass die Timings je nach Takt und Hersteller variieren können
Boostet dann auf 2865 mhz und werden über den ganzen Test gehalten
Bei dem Takt lande ich auch nur hier:
Eventuell hast du einfach einen höheren Crossbarclock oder es kommt durch die besserer Kühlung.
Hallo. Mal eine Frage an die Profis hier. Ich hab gerade wieder Cyberpunk angefangen und merke, dass die 2080 Ti arg an die Grenzen kommt. Ich überlege daher eine 4090 zu kaufen. Ich zocke primär auf 3440x1440. Die Frage ist allerdings, ob ich meinen Unterbau (9900K mit DDR4 4000) behalten kann oder das wenig Sinn macht. Laut Anzeige in spielen (hier zB Cyberpunk) hänge ich im GPU Limit. Hab irgendwie wenig Lust alles auszutauschen.
du kannst doch dein cpu limit prüfen. dauert keine 5 minuten
Strix und Galax bios bringen bei mir bei gleichem Takt generell mehr Punkte! Das kann es natürlich auch sein. Guter Punkt!
Jop, könnte noch mal mit dem galax gegentesten. Aber weiß eh das es mehr bringt. Alles schon in Timespy getestet. Strix bringt auch mehr.
Wegen deiner Strix... Was wir nicht kennen sind deine und seine VRAM-Timings ..Hatte letztens bei div. EVC2-Screenshots gesehen, dass die Timings je nach Takt und Hersteller variieren können
Puh kein plan wie da die VRAM Timings sind ... wusste bis eben nichmal das es sowas überhaupt gibt aber macht Sinn da wir ja auch beim normalen RAM Timings haben
Möglich aber seine TUF is in dem Moment ja auch recht Taktstabil währe die Kühlung in dem mom zu schwach würde ja der Takt fallen im Test wenn die Karte wärmer wird aber er meinte ja recht stabile 2655 mhz
Sein Problem is ja auch das er nich mal die 3 ghz packt mit max OC und Stock Kühler und über 500 Watt .. eventuell hat er auch einfach in der Chip Lotterie verloren
Ich hab auch ein anderes Bios drauf. Bin leider direkt nach Einbau, bzw davor auf der Asus Page gewesen und mir das Vbios geladen..
Dat is ja nich weiter wild hab das 2.1 ja auch drauf ( sagte ich dir ja drüben schonmal ) .. das war ja wegen der ECC Sache is ja bei TUF und Strix gleich das Bios bzw die Bios Änderung im neuen Bios
Bei guter Kühlung ist der eff. Takt nahe oder gleich dem gesetzten Takt
Möglich, dass da schärfere Timings gesetzt werden. Was Anderes fällt mir nicht ein
Wenn du das 1.000W meinst, ja
Mit org. Strix OC BIOS ist das Galax bei mir schneller
Muss ja nicht OC sein, wenn sie es nicht packt, dann packt sie es nicht. Aber andere bei Gleichen Takt und meine ist 10% Langsamer.. Da bekomm ich echt die Krise. Weil ichs nicht versteh.
Aja ich nehms Mal so hin. Im overclocking Thread ist Platz 45 auch mies. Mit über 3 GHz seine Points. Und noch andere. Seh zwar kein Stock bench. Aber 5450 ca. Bekomm ich auch hin , und das unter 3 GHz GPU takt. 2940 ca.
Hab ich wohl ne 2100€ möhre was benches betrifft.
Achte auf den eff. Takt...
Je höher die GPU-Temp, desto weiter entfernt sich der eff. Takt vom gesetzen Takt
Also zb 3.000MHz gesetzt, aber Durchschnitt sind am Ende des Benches zb nur 2.900MHz
Sieht man zb bei 3DMark-Benches ganz gut
Hier sind Core-Takt und Durchschnittliche Taktfrequenz nah beisammen (können auch gleich sein)
Aber bei hoher Temp, ausgereiztes PL und/oder zu wenig Spannung ist es nicht ungewöhnlich, wenn der durchschnittliche Takt 30MHz und mehr vom Core-Takt abweicht
Ach, quatsch... :d
Stell den PC ans offene Fenster oder ganz raus, steigt der Score, ohne dass du was am Takt änderst :fresse:
Also zb 3.000MHz gesetzt, aber Durchschnitt sind am Ende des Benches zb nur 2.900MHz Sieht man zb bei 3DMark-Benches ganz gut
Er kann den Takt ja Live verfolgen bei SuperPosi wird dort ja dauernt angezeigt rechts oben und dauernt aktualisiert
und er meinte ja das seinne 2655 mhz recht stabil dort sind und er nur eine Taktstufe runtergeht auf 2640 mhz das macht nun aber keine 500 bzw 300 Punkte bei SuperPosi aus sondern vielleicht so 20 Punkte oder so
Ich Tippe wie drüben im andern Thread schon gesagt auf Chip Lotterie verloren da er ja auch die 3 Ghz nicht erreichen kann
Könnt ich tun.. minus 1 Grad. Rechner steht 1 Meter neben dem Fenster. Und hab Seiten Belüftung beim 5000D.. Danke für eure Hilfe bei der Fehler suche. Ist wohl keiner.
Mir ist aber jetzt zu kalt ;-)
Er kann den Takt ja Live verfolgen bei SuperPosi wird dort ja dauernt angezeigt und dauernt aktualisiert und er meinte ja das seinne 2655 mhz recht stabil dort sind und er nur eine Taktstufe runtergeht auf 2640 mhz
Genau, 2655 und kurzzeitig Mal 2640. Und das alle 17 Tests.
Wo gabs denn eine Benachrichtigung? :) @ralle_h ist der ASUS Shop noch in den Notifications mit drin? :)
Theoretisch noch drin, praktisch aber für RTX Karten wohl nicht mehr, da der ASUS Store die getrackte Seite https://webshop.asus.com/de/grafikkarten/nach-grafikchip/nvidia-rtx4090-rtx4080/ removed hat. Habe ich gerade eben erst, wegen deinem Tag, bemerkt.
Hab den Verfügbarkeitsbot wegen der stark entschärften Verfügbarkeitslage aktuell nicht mehr so aktiv im Auge.
/edit: Habs auf https://webshop.asus.com/de/grafikkarten/nach-grafikchip/nvidia-rtx4090/ umgestellt, danke für den Hinweis
Moin zusammen !
Wäre jemand so nett und würde mir seine Lüfterkurve posten ?
Da es FanExpert nicht mehr ohne ArmouryCrate gibt, musste ich auf Fan Control zurück greifen um meine ganzen Lüfter neu zu steuern. Nur verhält sich meine 4090FE seitdem anders (Lüfter). Würde gerne eine mauelle Kurve vorgeben. min , max Temp. etc.
Danke !
2000 Euro für eine GPU ausgeben und 36 FPS in Hogwarts mit RT haben
Die wichtigste Erkenntnis: 12GB reichen schon jetzt nicht mehr. Also eigentlich ist die 4070Ti wirklich maximal eine 1440p Karte.
In 4K und RT nur mit der 4090 spielbar (ohne DLSS).
Mit DLSS / FG wird das sehr gut spielbar sein.
Ich hab knapp 120 fps. DLSS Quality und FG.
Optisch kein Unterschied zu Native festzustellen. Außer dass es dann eben ruckelt. Wer zuletzt lacht...
Die 4090 wird ja immer noch ob ihres Preises von einigen hier attackiert, dabei ist sie von allen Lovelace und RDNA3 Karten aktuell die einzig Sinnvolle. Vor allen Dingen nach letzten Preissenkungen. Punkt.
Ähnliche Themen
Antworten
6K
Aufrufe
392K
