[Sammelthread] NVIDIA GeForce RTX 4090 + FAQ
Here we go again
Quelle:
TEST:
Karten:
News:
Wakü News:
Shops:
PowerLimits:
KarteMinMax
4090 Founders Edition450W600W
4090 Gainward Golden Sample450W450W
4090 MSI Suprim X450W450W Silent Mode / 520W Power Modus
4090 STRIX OC500W600W / Dual Bios
4090 Aorus Master450W600W
4090 Zotac AMP Extreme450W495W
4090 MSI Suprim Liquid X480W530W / Selten auch 600W
4090 Gigabyte Gaming OC450W600W
4090 Palit Gamerock OC450W500W
CARDGPU Voltage PhasesGPU Voltage ControllerGPU MOSMOS Current (A)Total GPU CurrentMemory Voltage PhasesMemory Voltage ControllerMemory MOSMOS Current (A)Total Memory CurrentTotal PhasesSource
MSI Suprim X (& Liquid)
26​
Monolithic MP2891Monolithic MP86957
70​
1820​
4​
70​
280​
30​
Techpowerup
ASUS STRIX OC
24​
Monolithic MP2891OnSemi FDMF3170
70​
1680​
4​
70​
280​
28​
Techpowerup
Nvidia Founders
20​
70​
1400​
3​
70​
210​
23​
Techpowerup
Colorful Vulcan (& Neptune)
24​
uPI uP9512UAlpha & Omega AOZ5311NQI-03 BLN3
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI-03 BLN3
55​
220​
28​
Techpowerup
Zotac AIRO
24​
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI BLN0
50​
200​
28​
Techpowerup
ASUS TUF OC
18​
Monolithic MP2888AInfineon TDA21570
70​
1260​
4​
uPI uP9512QVishay SIC638A
50​
200​
22​
Hardware Unboxed
Gigabyte Gaming OC
20​
uPI uP9512UVishay SIC653A
50​
1000​
4​
uPI uP9512RVishay SIC653A
50​
200​
24​
Techpowerup
MSI Gaming Trio X
18​
Monolithic MP2891OnSemi NCP303151
50​
900​
4​
50​
200​
22​
CoolPC
Palit GameRock OC
16​
uPI uP9512UOnSemi NCP302150
50​
800​
3​
uPI uP9512ROnSemi NCP302150
50​
150​
19​
Techpowerup
Zotac Trinity OC
14​
55​
770​
4​
50​
200​
18​
CoolPC
Inno3D X3 OC
14​
uPI uP9512UAlpha & Omega AOZ5311NQI BLN0
55​
770​
3​
55​
165​
17​
KitGuru
Gigabyte Windforce
14​
?Vishay SIC653A
50​
700​
4​
?Vishay SIC653A
50​
200​
18​
profesionalreview
Tool
How To?
Anleitung
7. Enter drücken
10. PC neu starten
Seasonic
gibt Ihren Kunden das Kabel Umsonst, für spezielle Seasonic-NT, welche in den letzten 12 Monaten gekauft wurde.
Corsair
FAQ:
Verliere ich Leistung, wenn ich die RTX 4090 mit PCIe 3 laufen lasse? > Ja, ca 2,1% :) Also nicht viel
Quelle: https://www.computerbase.de/2022-10...hnitt_die_geforce_rtx_4090_mit_pcie_30_update
@Gurkengraeber Idle ist bei mir zwischen 7W und 9W an einem 3840x1600 144Hz Monitor
ich habe aber auch die RGB Beleuchtung abgeschalten über das tool von PNY.
Guter Hinweis, das probiere ich auch nochmal.
Edit: Ok das bringt bei mir nicht viel, vielleicht 1W. Aber so ein großer Unterschied? HDR ist aus.
Erste Undervoltingergebnisse
0,875v @ 2685MHz bei 55°C
0,900v @ 2730MHz bei 58°C
HDR ist auch bei mir aus hast du eventuell ein zweiten Monitor dran? Wenn ich mein 4k Fernsehr noch anschließe komme ich glaub ich auch auf 20W raus.
ComputerBase hat das hier ermittelt bei der FE:
Nee nur einen Samsung 4K 144Hz. Allerdings im Desktop auf 60Hz. Aber dann ermitteln die das was ich auch habe, Du liegst aber anscheinend weit darunter. Ich mein gut für Dich. :)
Ja hab mich auch schon gewundert hatte schon bedenken das es mehr als bei der FE wird wegen RGB oder so. Aber da gibt es ja soviel Einflussfaktoren ich hab G-Sync an vlt macht das auch ein unterschied. Meine alte 3090 Gigabyte war jedenfalls immer bei 24-40W und sprang offt hoch bis 100W
Warhammer Darktide probiert? 🥲
Heute gab es nen Patch bei Darktide - 7,4gb.
Performance wurde verbessert.
Nope - ich teste zur Zeit mit Division 2. Das war schon in meiner aktiven Div2 Zeit der OC/UV Test schlechthin. :d
Gerade mal withcer 3 getestet.
Es läuft flüssig wenn man Vsync 116 FPS Cap im NVCP einschaltet, DLSS Quali und FG.
Nachladeruckler sind zwar da aber ansonsten ein smoothes Bild.
Scheint aber nur einigermaßen gut auf den neuen Nvidia Gpus´s zu laufen .
Hab das Update bei der Xbox series X gemacht und im Leistungsmodus läuft es gut und sieht besser aus als das original .
Aber "Germany first" bitte...
Bisher hatte mir kein einziger AC-Block gefallen, wegen den zig Millionen O-Ringen
Aber der Neue sieht schon gut aus und hat einen fairen Preis
Ich schwärme jedoch für WC und AqC...
Hoffentlich enttäuschen die mich dieses Mal nicht
Obwohl... :oops:
Bisher war glaube nur AqC der einzige Hersteller, bei dem man die RAM-Chips mit Paste bestreichen musste
Super RAM-Temperaturen nutzen aber wenig, wenn der "Cold-Bug" zu schlägt. Hatte mich heute auch genervt
Das sieht ja echt geil aus finde ich. Habe den 4090 EK hier noch nicht ausgepackt und wollte den nächste Woche einbauen. Ich ich schicke den jetzt wahrscheinlich doch zurück.
Edit:
Zufällig jemand kürzlich bei cabelmod was bestellt und kann was zu den Lieferfristen aktuell sagen ? Mal Weinachten aussen vor
Meine ersten Bestellungen habe ja Wochen gedauert bei lagernd und aktuell habe ich Mal die "schnelle" shipping Option gewählt was angeblich 1 Woche dauern soll und dafür ist man selber Zoll verantwortlich ....
Hab mir Mal das Standart Kabel bestellt ohne Schnickschnack sind in meinen Augen besser biegsam und gleichen ehr dem seasonic Kabel was die in ihrer Aktion verschickt haben
KFA2 RTX4090 SG 1-Click OC - Pro, Contra? Verhalten unter Wasser?
Eines der vollständigsten Referenzdesign-Boards:
Fürs undervolte um Spulefiepen und sowas zu reduzieren Bombe.
Für max OC unter Wasser eher meh.
Da sind dann FE oder Strix/Suprim besser.
Obwohl... :oops:
Was die Anzahl der Finnen angeht sieht das bei Alphacool sehr gut aus mit der Wärmeabgabefläche für die GPU da macht man einen großen Sprung zur 3000ner Serie und die war ja auch schon gut.
Find das Klasse das Alphacool da mehr investiert.
Edit:
Sind ja schon auf der Alphacool Seite gelistet für in 2 Wochen glaub ich FE und Reference
Mein Suprim Kühler für die 3080 hatte noch 0,6mm Abstand und Breite der Kühlfinnen. Mit Ada ist man runter auf 0,4mm für beides. Dadurch halt auch mehr Oberfläche auf gleichem Raum. Optimus PC ist aber wohl noch feiner, aber irgendwo wird da auch ein Kompromiss sein.
Ist auf jeden Fall schon mal ganz gut hatte das ja auch gelesen mit 0,4 ich glaub der EK war auch 0,6 in der Gen
Wie lange willste da warten? Da kommt bestimmt erst Ostern was. :fresse:
Ja - Ostern 24 :rolleyes2:
Am besten finde ich den EINEN O-Ring und kein Wirrwarr aus "Millionen" O-Ringen, welche ein potentiell viel höheres Risiko an Undichtigkeit beherbergen, wenn man den mal zerlegen will und man alle Dichtungen auf richtigen Sitz kontrollieren muss
Ja, da braucht es mehr Druck...
Die Dicke vom Kühlerboden spielt auch eine Rolle. Mir wären recht dünne, elastische Kühlerböden am liebsten, da diese sich wunderbar "bauchigen" Die´s anpassen
So also hier mal ein schneller erster Vergleich zwischen FE und PNY 4090
FE - PNY
Verbrauch idle: 6 bis 9W - 18 bis 22W
Temp GPU load: 65 bis 72° - 75 bis 80°
Temp Hotspot load: 75° - 85°
Temp mem load: 72° - 80°
stock Boost takt: 2715 - 2700
Lautstärke: Brumm brumm - super leise
Spulenfiepen: nicht wahrnehmbar - sehr leise, nicht störend (hab keine Games über 150 FPS)
Verarbeitung: super - naja, net so dolle
RGB mit Asus Aura einbindbar: ja - nein
Sag: nein - ja
Gehäuse geht zu: relativ einfach - Adapter muss stark geknickt werden
Alles in allem ist diese PNY etwas langsamer als meine FE, sie taktet ein wenig niedriger. Bin jetzt nicht so der Overclocker, silence is king. Was mich allerdings bei der PNY schon stark nervt ist der idle Verbrauch. @Foxel, kannst Du bitte einmal bei Dir schauen was Deine Karte sich auf dem Desktop nimmt? Dunkler Hintergrund. Die Differenz würde bei meinem User Profil und Strompreis ca 115€ pro Jahr ausmachen, das ist schon ne Menge.
Allerdings muss ich diese Karte zurück senden, denn anscheinend sollten sich alle drei Lüfter auch bei niedrigen Temps drehen. Wie schon angesprochen, gerade beim Wiederverkauf gibt es sonst Probleme. Aber auch die Temps sind so nicht ok. WÜRDEN sich alle drei Lüfter drehen und die Temps auf FE Niveau oder gar darunter sein, dann würde ich die PNY behalten. Eine RMA ist mir aber zu gefährlich, nachher drehen beim Ersatzmodell auch nicht alle drei Lüfter. Also Widerruf und neu bestellen. Es gibt bei Reddit auch etwas dazu und bei Amazon ein entsprechendes Review. Scheint also einige Karten zu betreffen. Wären die Temps ok hätte ich vielleicht noch gesagt egal, aber so... Mal schauen ob Amazon das ohne Murren mitmacht. Und bevor sich jetzt jemand beschwert, ja ich werde schreiben dass sich ein Lüfter nicht dreht. ;)
Ätzend. Also alles wieder einpacken und zu Amazon zuück. :(
Klingt ja schon insgesamt als wäre die FE bis auf das Brummen des hinteren Lüfters super, vor allem bei dem auch noch günstigeren Preis. Gibt es da keine simple DIY Lösung wie man das hinbekommt? Einen kleinen Abstandshalterring unter den Lüfter oder sowas damit die Luftverwirbelung anders ist?
Doch gibt es, wurde ja auch hier im Forum bereits vorgestellt. Meine FE ist allerdings gerade bei NVidia, also muss warten bis sie zurück kommt, dann kann ich dieses Mod probieren.
Ich werde wohl versuchen müssen das CableMod Kabel irgendwie zu stornieren/widerrufen, glaub nicht mehr dran, dass das ankommt.
Werden immer noch Daten "intern" ausgetauscht...
Bleibt halt der Dreizack an der Karte.
Weiß jmd nähere Infos zum Cold-Bug beim RAM?
Zb ob das nur einen bestimmten Temperatur-Bereich betrifft?
Denn offentlich gibt es ja ein paar User in der HoF, deren Karten mit -35°C (GPU) arbeiten
Dass die gleichzeitig den RAM warmhalten glaube ich eher nicht. Der extreme Temperaturunterschied auf so kleiner Fläche ist vielleicht nicht so "gesund" !?
Ähnliche Themen
Antworten
7K
Aufrufe
488K
