[Sammelthread] NVIDIA GeForce RTX 4090 + FAQ
Here we go again
Quelle:
TEST:
Karten:
News:
Wakü News:
Shops:
PowerLimits:
KarteMinMax
4090 Founders Edition450W600W
4090 Gainward Golden Sample450W450W
4090 MSI Suprim X450W450W Silent Mode / 520W Power Modus
4090 STRIX OC500W600W / Dual Bios
4090 Aorus Master450W600W
4090 Zotac AMP Extreme450W495W
4090 MSI Suprim Liquid X480W530W / Selten auch 600W
4090 Gigabyte Gaming OC450W600W
4090 Palit Gamerock OC450W500W
CARDGPU Voltage PhasesGPU Voltage ControllerGPU MOSMOS Current (A)Total GPU CurrentMemory Voltage PhasesMemory Voltage ControllerMemory MOSMOS Current (A)Total Memory CurrentTotal PhasesSource
MSI Suprim X (& Liquid)
26​
Monolithic MP2891Monolithic MP86957
70​
1820​
4​
70​
280​
30​
Techpowerup
ASUS STRIX OC
24​
Monolithic MP2891OnSemi FDMF3170
70​
1680​
4​
70​
280​
28​
Techpowerup
Nvidia Founders
20​
70​
1400​
3​
70​
210​
23​
Techpowerup
Colorful Vulcan (& Neptune)
24​
uPI uP9512UAlpha & Omega AOZ5311NQI-03 BLN3
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI-03 BLN3
55​
220​
28​
Techpowerup
Zotac AIRO
24​
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI BLN0
50​
200​
28​
Techpowerup
ASUS TUF OC
18​
Monolithic MP2888AInfineon TDA21570
70​
1260​
4​
uPI uP9512QVishay SIC638A
50​
200​
22​
Hardware Unboxed
Gigabyte Gaming OC
20​
uPI uP9512UVishay SIC653A
50​
1000​
4​
uPI uP9512RVishay SIC653A
50​
200​
24​
Techpowerup
MSI Gaming Trio X
18​
Monolithic MP2891OnSemi NCP303151
50​
900​
4​
50​
200​
22​
CoolPC
Palit GameRock OC
16​
uPI uP9512UOnSemi NCP302150
50​
800​
3​
uPI uP9512ROnSemi NCP302150
50​
150​
19​
Techpowerup
Zotac Trinity OC
14​
55​
770​
4​
50​
200​
18​
CoolPC
Inno3D X3 OC
14​
uPI uP9512UAlpha & Omega AOZ5311NQI BLN0
55​
770​
3​
55​
165​
17​
KitGuru
Gigabyte Windforce
14​
?Vishay SIC653A
50​
700​
4​
?Vishay SIC653A
50​
200​
18​
profesionalreview
Tool
How To?
Anleitung
7. Enter drücken
10. PC neu starten
Seasonic
gibt Ihren Kunden das Kabel Umsonst, für spezielle Seasonic-NT, welche in den letzten 12 Monaten gekauft wurde.
Corsair
FAQ:
Verliere ich Leistung, wenn ich die RTX 4090 mit PCIe 3 laufen lasse? > Ja, ca 2,1% :) Also nicht viel
Quelle: https://www.computerbase.de/2022-10...hnitt_die_geforce_rtx_4090_mit_pcie_30_update
Ich probier mal wie gut es mit Windows 11 läuft.
Aber ich denke halt echt, dass meine Karte Müll ist. In der Silizium Lotterie gewonnen, aber eine schlechte nicht verkaufswürdige bekommen...
Gibt auch einige die Berichten sie konnten es durch MB Bios Update, PCI Express Link State Power Management Off, Stock Settings der GPU oder disablen von XMP lösen. Muss aber sagen außer den ersten beiden finde ich keine dieser Lösungen akzeptabel auf Dauer. Genauso wie Power Management Mode hochzustellen in den Nvidia Drivern.
Aus oder einschalten?
War bei mir wohl schon auf off
Ich habe Asus angeschrieben und die meinen, dass die Software Abteilung bereits an einem neuen Update arbeitet.
Aber ist halt doch komisch. Es ist ja eig die Karte selbst und dann müssen es die MB Hersteller fixen...
Kommt drauf an wo im low power state die Stromversorgung herkommt. Kann durchaus sein das es über den PCI-E slot läuft. Der kann ja schließlich bis zu 75W hergeben. Das könnte also durchaus mit dem Mainboard Bios zu tun haben.
Eventuell ist es: Gute Karte macht zu hohen idle Takt bei zu wenig Spannung und deshalb der Crash?
Ich werd mal die Theorie mit meiner prüfen.
Ich war die letzten Tage so darauf fixiert erstmal eine stabile Karte zu haben, damit ich sicher sein kann die umbauen zu können mit WK ab nächster Woche oder dieses WE.
Aber das mit zu wenig Spannung dacht ich auch, deswegen hatte ich +100 core voltage in Afterburner eingestellt und gleich gecrashed
Ahh wobei ich sollte denke ich eig die curve dafür anpassen.
Ach du kacke. Ich hatte gerade mein PL auf 133% gesetzt und in furmark wurden wirklich 600 W gezogen, obwohl ich meine mit 3x 8 PIN angeschlossen habe.
Ich weiß da sind eig mind. 1x 8 PIN bei den 4er für redundanz, aber ich dachte eig, dass wenn man die mit 3x 8 PIN anschließt, dann habe ich fix ein 450 W limit, egal was ich softwareseitig mache...
PCI-E Anschluss am Netzteil, Adapter und Kabel können deutlich mehr als 150W pro. Lediglich der "normale" 8-Pin Anschluss am Board der GPU ist nur auf 150W rated. Corsair zB macht seinen 12 Pin bis zu 600W mit nur 2x6+2 Kabeln zum Netzteil.
Das ist soweit ich weiß nur mit dem Nvidia Adapter so. Mit anderen Kabeln hat man das nicht, da da nur 2 Sense Pins belegt sind. Eigentlich alle Kabel von Netzteilhersteller gehen auch nur auf 2x8 Pin, sollte also kein Problem sein mit 3x
21261 in TSE Grafikscore reicht für Rang 70 in DE
Memory +1810
Clock +175
Powerlimit 133%
voltage 100
mehr is gerade nicht drinnen ohne das Arbeitszimmer komplett abzukühlen
Bisher kein Fiepen/Rasseln und super leise Lüfter bei der Gaming OC, bin sehr zufrieden
Das Galax bios boostet zwar nicht höher bei mir vs Strix original, aber der effective Clock ist Höher und dadurch 11400SW, 29500PR, 22300TSE…
Power limit hab ich selbst mit „nur 600 Watt“ beim Original Bios noch nicht gesehen, aber halt trotzdem mehr Performance mit dem Galax 666.
Gib mal nähere Infos (Links) zu den Scores bitte - danke ;)
@nebu3 meinst du das galax bios könnte mir auch bei meinem Problem helfen?
Aber man kann glaub nicht zurück flashen und damit ist die Garantie weg, oder? (FE)
Gerade von der Arbeit gekommen und gedacht ich versuchs nochmal.. Jetzt funktioniert das blöde Kabel auf einmal?! :fresse:
Finde die Palit ist die schönste 4090 atm.
Nein, habe mit strix und Galax Probleme im idle.
Zurück Flashen geht wenn man vorher das Bios speichert.
Hatte die Tage Gelegenheit mal direkt Win10 gegen Win11 zu testen und ich habe mit Win10 zwar bessere Leistungswerte in 3DMark mit der CPU aber schlechte Ergebnisse mit der GPU!
Hat das hier auch schon jmd. feststellen können?
Eine Frage an die PNY 4090 Besitzer:
Ich habe anscheinend eine, wo sich nur 2 Lüfter drehen. Ist bei Euch alles ok? Bzw. falls Ihr auch so eine Karte habt, kann man da was machen? Auch in AB werden nur zwei Lüfter erkannt.
Also bei mir drehen sich alle 3 wenn ich sie anschaue. In AB sinds nur zwei das ist aber bei fast allen Karten so. War auch schon bei meiner 3090 von gigabyte so.
Wie da geschriebe, sind da auch nur 2 Lüfter Anschlüsse auf dem PCB der mittlere, und der der nicht geht sind in dem Stecker zusammen gecrimpt. Das RPM Signal kommt nur vom Mittleren, die anderen 3 Leitung parralell zum mittleren und dem anderen.
Bei mir hat sich nichts getan. Drehen sich auch nur 2 Lüfter.
Aber da daraunter 2x 140mm Lüfter Frischluft drauf blasen scheinen die Temperaturen noch ok zu sein, auch wenn ich die Lüfter fest auf 30% stelle.
Anhang anzeigen 828596Anhang anzeigen 828598
Ok, das wäre für mich in Ordnung mit dem einen Signal für 2 Lüfter. War bei meiner TUF 3080 glaube ich auch so. Aber drehen sollten sich schon alle drei.
Irgend einer meinte bei Reddit der dritte springt erst bei 88° an, aber das kann ich nicht glauben. Kriege die Karte auch nicht auf diese Temps.
Allerdings wird die Karte heißer als die FE. Bei der FE blieb ich stets unter 72° Core und 78° hotspot, die PNY geht recht schnell auf 85° Hotspot rauf. Sie bleibt allerdings krass leise. Verglichen mit dem FE Brummer eine Wohltat.
Also wie gesagt bei mir laufen alle 3 an auch bei niedrig last. Hab die Karte bei mir noch nie über 64° bringen können bei kosnstanter 450W Last. üblich sind bei mir 57°-61° und 1000 -1100 rpm
So also hier mal ein schneller erster Vergleich zwischen FE und PNY 4090
FE - PNY
Verbrauch idle: 6 bis 9W - 18 bis 22W
Temp GPU load: 65 bis 72° - 75 bis 80°
Temp Hotspot load: 75° - 85°
Temp mem load: 72° - 80°
stock Boost takt: 2715 - 2700
Lautstärke: Brumm brumm - super leise
Spulenfiepen: nicht wahrnehmbar - sehr leise, nicht störend (hab keine Games über 150 FPS)
Verarbeitung: super - naja, net so dolle
RGB mit Asus Aura einbindbar: ja - nein
Sag: nein - ja
Gehäuse geht zu: relativ einfach - Adapter muss stark geknickt werden
Alles in allem ist diese PNY etwas langsamer als meine FE, sie taktet ein wenig niedriger. Bin jetzt nicht so der Overclocker, silence is king. Was mich allerdings bei der PNY schon stark nervt ist der idle Verbrauch. @Foxel, kannst Du bitte einmal bei Dir schauen was Deine Karte sich auf dem Desktop nimmt? Dunkler Hintergrund. Die Differenz würde bei meinem User Profil und Strompreis ca 115€ pro Jahr ausmachen, das ist schon ne Menge.
Allerdings muss ich diese Karte zurück senden, denn anscheinend sollten sich alle drei Lüfter auch bei niedrigen Temps drehen. Wie schon angesprochen, gerade beim Wiederverkauf gibt es sonst Probleme. Aber auch die Temps sind so nicht ok. WÜRDEN sich alle drei Lüfter drehen und die Temps auf FE Niveau oder gar darunter sein, dann würde ich die PNY behalten. Eine RMA ist mir aber zu gefährlich, nachher drehen beim Ersatzmodell auch nicht alle drei Lüfter. Also Widerruf und neu bestellen. Es gibt bei Reddit auch etwas dazu und bei Amazon ein entsprechendes Review. Scheint also einige Karten zu betreffen. Wären die Temps ok hätte ich vielleicht noch gesagt egal, aber so... Mal schauen ob Amazon das ohne Murren mitmacht. Und bevor sich jetzt jemand beschwert, ja ich werde schreiben dass sich ein Lüfter nicht dreht. ;)
Ätzend. Also alles wieder einpacken und zu Amazon zuück. :(
Spulenfiepen und ne OC Krücke - "Arsch-Karte" beschreibt das ganz gut ^^
Er kriegt die TUF OC für 1867 € - denke daher nicht, dass er sich beschweren kann.
Hab mich noch nicht entschieden. Aber so eine Karte hätte es verdient auf WaKü umgebaut zu werden.
Vllt bekomme ich ja einen Alphacool Block günstig... dann würde ich es mir überlegen.
Bin zwar kein Alphacool Fan, aber ich zahle bestimmt keine 250 oder 350€ für nen Block.
Ich weiß nicht, ob du die Sachen hier gesehen hattest:
Wie in der Ouzo-Werbung „…für die guten Freunde“ :fresse:
„Aber die Arsch-Karte für die scheiss Freunde“ :haha: (nee, Spaß ;))
Wenn er eh nur zockt, ist das ein guter Preis. Denn beim Zocken würde man die paar fps mehr, deiner FE eh nicht merken ;)
Warum hast du den Bench benutzt? Den hab ich seit Ewigkeiten nicht mehr angefasst
btw:
40k (Grafik) geknackt :oops:(y)
Ähnliche Themen
Antworten
6K
Aufrufe
395K
