[Sammelthread] NVIDIA GeForce RTX 4090 + FAQ
Here we go again
Quelle:
TEST:
Karten:
News:
Wakü News:
Shops:
PowerLimits:
KarteMinMax
4090 Founders Edition450W600W
4090 Gainward Golden Sample450W450W
4090 MSI Suprim X450W450W Silent Mode / 520W Power Modus
4090 STRIX OC500W600W / Dual Bios
4090 Aorus Master450W600W
4090 Zotac AMP Extreme450W495W
4090 MSI Suprim Liquid X480W530W / Selten auch 600W
4090 Gigabyte Gaming OC450W600W
4090 Palit Gamerock OC450W500W
CARDGPU Voltage PhasesGPU Voltage ControllerGPU MOSMOS Current (A)Total GPU CurrentMemory Voltage PhasesMemory Voltage ControllerMemory MOSMOS Current (A)Total Memory CurrentTotal PhasesSource
MSI Suprim X (& Liquid)
26​
Monolithic MP2891Monolithic MP86957
70​
1820​
4​
70​
280​
30​
Techpowerup
ASUS STRIX OC
24​
Monolithic MP2891OnSemi FDMF3170
70​
1680​
4​
70​
280​
28​
Techpowerup
Nvidia Founders
20​
70​
1400​
3​
70​
210​
23​
Techpowerup
Colorful Vulcan (& Neptune)
24​
uPI uP9512UAlpha & Omega AOZ5311NQI-03 BLN3
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI-03 BLN3
55​
220​
28​
Techpowerup
Zotac AIRO
24​
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI BLN0
50​
200​
28​
Techpowerup
ASUS TUF OC
18​
Monolithic MP2888AInfineon TDA21570
70​
1260​
4​
uPI uP9512QVishay SIC638A
50​
200​
22​
Hardware Unboxed
Gigabyte Gaming OC
20​
uPI uP9512UVishay SIC653A
50​
1000​
4​
uPI uP9512RVishay SIC653A
50​
200​
24​
Techpowerup
MSI Gaming Trio X
18​
Monolithic MP2891OnSemi NCP303151
50​
900​
4​
50​
200​
22​
CoolPC
Palit GameRock OC
16​
uPI uP9512UOnSemi NCP302150
50​
800​
3​
uPI uP9512ROnSemi NCP302150
50​
150​
19​
Techpowerup
Zotac Trinity OC
14​
55​
770​
4​
50​
200​
18​
CoolPC
Inno3D X3 OC
14​
uPI uP9512UAlpha & Omega AOZ5311NQI BLN0
55​
770​
3​
55​
165​
17​
KitGuru
Gigabyte Windforce
14​
?Vishay SIC653A
50​
700​
4​
?Vishay SIC653A
50​
200​
18​
profesionalreview
Tool
How To?
Anleitung
7. Enter drücken
10. PC neu starten
Seasonic
gibt Ihren Kunden das Kabel Umsonst, für spezielle Seasonic-NT, welche in den letzten 12 Monaten gekauft wurde.
Corsair
FAQ:
Verliere ich Leistung, wenn ich die RTX 4090 mit PCIe 3 laufen lasse? > Ja, ca 2,1% :) Also nicht viel
Quelle: https://www.computerbase.de/2022-10...hnitt_die_geforce_rtx_4090_mit_pcie_30_update
Ach, mir brauchste nix zu gönnen, ick hab schon zwei Zotac Airo zu nem guten Preis erwischt.
Aber falls sich meine Glaskugel nicht täuscht, gönne ich mir vielleicht dann noch ne Dritte. Für F@H kann man nie genug Grakas haben 😅
Naja selbst Schuld. Ohne Lieferdatum hätte ich nach ein paar Tagen storniert.
Meine Bestellung ist noch für 2130€ im System vermerkt und bezahlt anstatt wie kurz danach bzw. jetzt wieder 2300€. Von daher hab ich gedacht ich warte mal ab...in der Zwischenzeit gabs ja quasi alle möglichen Karten von allen möglichen Herstellern wieder mal im Verkauf, auch die TUF OC...aber halt dann bei Saturn und nich bei Asus im Shop.
Da hatten an dem Tag wohl zuviele bestellt .. wundert mich das du kein Storno bekommen hast denke du bist da dann halt nun direkt in der Warte Posi und wenn die wieder ne Ladung bekommen bekommst du deine dann.
Wundert mich ehrlich gesagt auch, vor allem weil die Bestellung noch für "günstige" 2130€ im System hängt bei denen.
Auf die 4090 wird ne AMD 7900 XT oder 7900 XTX Karte Preislich keinen Einfluss haben dafür is die Kluft zu gross
Wahrscheinlich nicht. Aber mir reicht schon wenn einige merken, dass fürs Zocken ne 1000€ Karte auch reicht (die 4080 als Zwischenschritt taugt ja vom P/L Verhältnis absolut nicht). Dann nimmt der Run auf die 4090 ab und es gibt endlich die Modelle zu normalen Preisen einfach im Handel. Das wäre ja auch schonmal was.
Wenn AMD die XTX raus gebracht hat wird erstmal eine 4080Ti als Konter folgen und den Preispunkt der 4080 einnehmen.
Falls jemand seinen PC unterm Flecktarn betreibt:
Geiler Preis, aber ich habe in meinem Leben noch nie so eine hässliche Grafikkarte gesehen.. :d
Geschafft...
Vorher mit TUF-Kühler -----------------------GPU 71,5°C (Hotspot 82,9°C) - RAM 70,0°C bei 80% PL (Board Power Draw 400W - GPU Chip Power Draw 364W) - GPU/RAM 2.505/10.501MHz (alle Werte avg)
Jetzt mit "TUFSky" + LM + MoRa3 /360LT - GPU 38,9°C (Hotspot 45,1°C) - RAM 64,0°C bei 80% PL (Board Power Draw 396W - GPU Chip Power Draw 361W) - GPU/RAM 2.610/10.501MHz (alle Werte avg)
Beides bei 21°C Raumtemperatur...
VGPU ist von 944mV auf 970mV gestiegen. Was normal ist, wenn die PL gleich hoch und die GPU kühler ist
War jetzt nur moderate Last mit Furmark und ohne OC
@ABA74
Gab aber unter 10.000 Punkte .. glaub der VRAM wird bei der Strix zu warm und drosselt dann ( wobei der durchschnitts VRAM takt nich niedriger is ) muss ich mir nochmal anschauen da würde dann auch Wakü helfen
Hab aber im Treiber auch ECC an.
Wie immer mit 450 Watt max weil 3 x 8 Pin .. immerhin schonmal die 3.135 mhz erreicht
Wenn man die Lüfter der Strix auf 100 % stellt hört sich das an als ob jemand im Nachbar Zimmer am saugen is :ROFLMAO:
aber auch da hilft dann Wasserkühler ... nur wird der Kühler beim normalen Zocken eh nich so schnell bzw laut
Hab seit kurzem den Bug, dass ich nachdem Anmelden von Windows direkt oben rechts eine eingefrorene OSD von AB habe.
Geschafft...
Jetzt mit "StrixSky" + LM + MoRa3 /360LT - GPU 38,9°C (Hotspot 45,1°C) - RAM 64,0°C bei 80% PL (Board Power Draw 396W - GPU Chip Power Draw 361W) - GPU/RAM 2.610/10.501MHz (alle Werte avg)
Beides bei 21°C Ramtemperatur...
Was für einen Block hast du drauf?
LM haste noch was um die GPU Die drum herum gemacht zum isolieren/schützen?
@DieDreiBeiden
Und wie schauts mit deiner 4090 Strix aus ?
So:
Taktet wohl ein wenig niedriger als deine. Aber kann auch an der Temp liegen. Ich hoffe ja das AC oder Watercool bald mal in die Pötte kommen. Wobei ich auch schon mit einem Block von Optimus liebäugle.
Ich kann die Karte kaum bis gar nicht wahrnehmen. Kann aber auch daran liegen das meine Nebenhöhlen zu sind. :fresse:
So:
Deine is noch @Stock also mit Standart Einstellungen glaub ich. Bei meiner hab ich Manuell den Takt hochgezogen beim Core und beim VRAM daher hab ich da mehr.
Wenn du deine Manuell hochziehst wirst du auch auf über 10.000 und mehr kommen.
Joa ich hab den Zeipunkt auch verpasst Gestern ... Gestern am Frühen Abend wo ich die 4090 Strix bekommen hatte hatte Alternate noch den EK 4090 Strix Kühler ( den Klaren mit Passiver Backplate )
aber als ich dann mit dem Testen durch war war er dort ausverkauft ... aber ich habs da auch nich soooo eilig auch wenns grad etwas blöd aussieht wie meine Karte im Gehäuse steht
aber wenns Januar werden sollte bis ich den EK Kühler hab isses auch nich weiter wild .. am 14.12 soll Caseking den klaren Block bekommen vielleicht schlag ich dann da zu
Auch nich bei 3D Mark ? Wenn dem so is dann Glückwunsch hast wohl die beste Karte erwischt was Geräusche angeht (y)
aber kann natürlich auch an deiner Aktuellen erkrankung liegen
Würdest auch empfehlen beim EKWB Block die Tuf BP zu nehmen?
Wenn die EK-BP keinen Ausschnitt fürs Kreuz hat, ja. Alternativ könnte man die EK-BP modden. Ganz ohne „Kruzifix“ möchte ich selbst nicht auskommen
Hab Stunden mit der Montage verplempert, weil ich nicht mit dem mit dem Abbild auf dem GPU-Die zufrieden war (zum Testen normale WLPaste genommen). Das Kreuz bringt da eine Menge (bei mir zumindest)
Hast du die echt in Acryl Harz eingekesselt? Manche raten ja von Harz ab.
Hast du Fotos gemacht??
Joh… :)
Bilder von der Behandlung hab ich leider keine gemacht. Was wolltest du da sehen?
Und warum raten Manche davon ab? Der Kram ist laut Beschreibung gut zum Isolieren von PCBs geeignet. Und wer malt damit nur um die Bauteile herum? :d
Vorher vs nachher. Viel kommt nicht herum, aber es geht um den Spaßfaktor...
Bei TSE merkt man das System-RAM-Limit schon arg
Falls Fragen wegen der GPU-Temp aufkommen. Der Mora stand am offenen Fenster
Mir ist in Hardware Info gerade aufgefallen das man auch die Spannungswandler Temp sehen kann .
So, hab jetzt meine RMA Anweisungen von NVidia bekommen. Aber nicht so ganz verständlich. In den beiden pdf Dateien sind zig mal dieselbe Seite zum Ausdrucken. Muss man die alle dem Paket beilegen? Und Fedex meint, man darf das Etikett nicht einfach aufs Paket kleben sondern muss dafür so eine Versandtasche benutzen?
Lange Rede kurzer Sinn, hat jemand schon mal eine RMA in der letzten Zeit direkt bei NVidia gemacht und kennt den Prozess?
KFA2 vom MediaMarkt via eBay für 2.099 EUR:
Frage: Wenn man zwischen einer PNY und dieser Karte wählen könnte, welche würde man sich eher holen? Hier schwärmen ja viele für die PNY. Die KFA2 macht aber eigentlich auch ganz ordentlich was her von den Specs. Und das Zubehör kann sich durchaus sehen lassen.
Also die Adapter verlegung bei Verticalem GPU Einbau is echt frickelig. Nun hab ich die Adapter Kabel zwar relativ grade
aber dafür liegt der kramm nun am RAM an und somit wird dann nebenbei das Kabel mit erwärmt da mein RAM ja auch bis zu 42 Grad und noch etwas mehr warm wird
was auch nich so sonderlich gut für ein Strom Kabel is was durch den Strom Durchfluss scchon warm wird und das wird nun durch den RAM nochmal mehr erwähnt.
Werd mir wohl doch n neues Netzteil holen müssen mit nativen 16 Pin Kabel aber wohl nich mehr dieses Jahr
Voher : ------------------------------------------------------------------- Nacher :
Wie sieht das bei euch aus bei Verticalem Einbau und dem Adapter ?
Hast dieses Häckchen bei "use Firmware Mode" oder wie das heiß bei der Lüfterkruve aktiviert im MSI Afterburner?
Ah und Gigabyte hat nen Bios und Firmewareupdate auf der Webseite.
Lag wirklich an dem Häkchen. Konnte das nicht aktivieren weil ich mehr als 3 Punkte in der Lüfterkurve hatte. Hab die dann rausgelöscht und dann ging es. Laufen jetzt im Idle bei 1000 Umdrehungen und unter Last steigt die Drehzahl auch nur langsam bis etwa 1300 an. Ist so gut wie nicht hörbar. Der Kühler der Gaming OC ist halt schon echt top. Vor allem die VRAM Kühlung.
Danke für den Tip!
Ich hatte eine KFA2 von Media Markt hier. Die Karte hat mich voll überzeugt, was Kühlleistung und Performance angeht. Leider waren bei meiner Karte die Lüfter deutlich hörbar, schon bei 1000rpm. Es war dieses typische Motornebengeräusch. Ich sage bewusst, bei meiner Karte, da andere Leute hier andere Sachen berichtet haben.
War für mich so absolut nicht tragbar und ging daher zurück und wurde offensichtlich direkt an den nächsten weitergereicht, für 100€ mehr. :fresse:
Anhang anzeigen 826000---
Ich habe auch eine Strix. Allerdings ist der Block schon drauf. Ich habe inzwischen das Seasonic Kabel angeschlossen. Ich finde, dass es einigermaßen clean ist. Mit Adapter würde es vermutlich anders ausschauen :poop:
Hast du Luft oder Wasserkühlung? Bei Wasser würde ich die KFA bevorzugen, die Kühler der Zotac passen da wohl drauf.
Ansonsten eine bestellen und schauen wieviel Geräusche die macht.
Das ist mir bei der Strix auch aufgefallen, der Stecker ist bescheiden Positioniert wenn man vertical mount möchte. Da ist die MSI angenehmer, da deutlich weiter hinten angebracht.
Wirklich schöne Lösungen sind da echt sonst sehr schwierig wenn man nicht seitlich biegen möchte.
Beste Grüße
Ähnliche Themen
Antworten
6K
Aufrufe
392K
