[Sammelthread] NVIDIA GeForce RTX 4090 + FAQ
Here we go again
Quelle:
TEST:
Karten:
News:
Wakü News:
Shops:
PowerLimits:
KarteMinMax
4090 Founders Edition450W600W
4090 Gainward Golden Sample450W450W
4090 MSI Suprim X450W450W Silent Mode / 520W Power Modus
4090 STRIX OC500W600W / Dual Bios
4090 Aorus Master450W600W
4090 Zotac AMP Extreme450W495W
4090 MSI Suprim Liquid X480W530W / Selten auch 600W
4090 Gigabyte Gaming OC450W600W
4090 Palit Gamerock OC450W500W
CARDGPU Voltage PhasesGPU Voltage ControllerGPU MOSMOS Current (A)Total GPU CurrentMemory Voltage PhasesMemory Voltage ControllerMemory MOSMOS Current (A)Total Memory CurrentTotal PhasesSource
MSI Suprim X (& Liquid)
26​
Monolithic MP2891Monolithic MP86957
70​
1820​
4​
70​
280​
30​
Techpowerup
ASUS STRIX OC
24​
Monolithic MP2891OnSemi FDMF3170
70​
1680​
4​
70​
280​
28​
Techpowerup
Nvidia Founders
20​
70​
1400​
3​
70​
210​
23​
Techpowerup
Colorful Vulcan (& Neptune)
24​
uPI uP9512UAlpha & Omega AOZ5311NQI-03 BLN3
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI-03 BLN3
55​
220​
28​
Techpowerup
Zotac AIRO
24​
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI BLN0
50​
200​
28​
Techpowerup
ASUS TUF OC
18​
Monolithic MP2888AInfineon TDA21570
70​
1260​
4​
uPI uP9512QVishay SIC638A
50​
200​
22​
Hardware Unboxed
Gigabyte Gaming OC
20​
uPI uP9512UVishay SIC653A
50​
1000​
4​
uPI uP9512RVishay SIC653A
50​
200​
24​
Techpowerup
MSI Gaming Trio X
18​
Monolithic MP2891OnSemi NCP303151
50​
900​
4​
50​
200​
22​
CoolPC
Palit GameRock OC
16​
uPI uP9512UOnSemi NCP302150
50​
800​
3​
uPI uP9512ROnSemi NCP302150
50​
150​
19​
Techpowerup
Zotac Trinity OC
14​
55​
770​
4​
50​
200​
18​
CoolPC
Inno3D X3 OC
14​
uPI uP9512UAlpha & Omega AOZ5311NQI BLN0
55​
770​
3​
55​
165​
17​
KitGuru
Gigabyte Windforce
14​
?Vishay SIC653A
50​
700​
4​
?Vishay SIC653A
50​
200​
18​
profesionalreview
Tool
How To?
Anleitung
7. Enter drücken
10. PC neu starten
Seasonic
gibt Ihren Kunden das Kabel Umsonst, für spezielle Seasonic-NT, welche in den letzten 12 Monaten gekauft wurde.
Corsair
FAQ:
Verliere ich Leistung, wenn ich die RTX 4090 mit PCIe 3 laufen lasse? > Ja, ca 2,1% :) Also nicht viel
Quelle: https://www.computerbase.de/2022-10...hnitt_die_geforce_rtx_4090_mit_pcie_30_update
Doch, die kommt wieder rein ;)
Die Strix war für einen Kollegen, hat aber zu starkes Spulenfiepen.
Hier mal die Temps:
1668837441744-png.818183
Beste Grüße
@kmwteam
Hatte noch keine Zeit und Lust danach zu schauen, ob es neben der aktuell schlechten Durchlüftung noch am Treiber oder am zugemüllten WIN10 liegt. Zudem hab ich bei FF zig Tabs laufen
Nach dem Warzone 2 spielen und mit Twitch Stream laufen, also nicht komplett Idle, die 1.05V Spannung liegen wohl beim Windows Start kurz an bevor der Arschbrenner sich einschaltet :d
Wie kann ich Rezisable Bar oder wie es heißt einschalten? Als ich im bios geändert habe, hat mein PC immer neu gestartet, ohne ins BIOS zu kommen und musste mein BIOS zurücksetzten. Wie funktioniert das eigentlich genau zu aktivieren, ohne Probleme zu bekommen? Mein mainboard ist ein Gigabyte Z690 UD DDR4
Naja irgendwas scheint bei den "hochwertigeren" Spulen nicht zu stimmen, da gerade die Asus und MSI Karten zumeist unerträgliche Spulengeräusche haben (können) und ich meine nicht etwas, sondern unerträglich. Hatte selbst eine Suprim X hier, da ich ein riesen MSI Fan bin aber die Karte war absolute katastrophe, was Spulenfiepen und Lüfterrattern anging. Die inno3d dagegen ist flüsterleise, minimales zirpen, was man bei 800rpm drehenden Lüftern und der CPU AIO Pumpe nur hört, wenn man bei offenem Gehäuse 5cm vor der Karte hängt!
Es ist klar, dass Trill seine TUF verteidigt, denn wer würde schon gern sagen, dass die Karte super verarbeitet ist aber die Spulengeräusche unerträglich sind (außer man ist schwerhörig). Wenn man es im Forum schreibt, glaubt man es am Ende vll. noch oder man ist vll. einen Moment zufrieden mit den Geräuschen der Karte und redet sie sich weg!
Was diese Generation der Nvidia Karten deutlich gezeigt hat ist, dass es wirklich egal ist, wie das PCB Layout designed ist oder welchen Hersteller man favorisiert. Selbst die "Einstiegskarten" können top Chips verbaut haben und die Karten à la Strix etc. können trotz perfektem PCB Layout keine 3000Mhz halten. Am Ende kommt es auf die Geräuschkulisse und die Temperaturen an, auf mehr nicht! Die Karte hat selbst mit Stock Takt mehr als genug Leistung und viele undervolten ihre Karte sowieso!
Nicht jede Karte ist gleich laut/leise was die Spulengeräusche angeht. Das wird dir jeder bestätigen der mehrere Karten von dem selben Modell getestet hat. Egal ob TUF, FE oder Gaming OC, die Spannweite kann von leise nicht störend bis Schreihals gehen. Das kann man einfach nicht an einer Karte ausmachen und Rückschlüsse auf alle anderen schließen. Das ist Bullshit.
Was die Suprim oder Strix angeht, es gibt sie, auch wenn es bei den beiden Modellen eher sehr selten ist 1/10, eine die leiser ist.
Ja die Master war dagegen sehr leise bei den Spulen Lüfter da für sehr laut mit 1500 RPM im Silent Mode .
Bei der Gigabyte Master musste ich richtig Ran an die Karte um zu hören ob die Fiept bei der Tuf kann ich auf dem Sofa sitzen bleiben und höre sie deutlich aus 3m .
Bei einem Preis für 2000 € hätte ich die Master behalten und den EK für 250 € gekauft!
Aber 2650 war mir das nicht wert.
Es gibt sie also doch die klar leiser fiependen .
Ist bei meiner aber nicht so extrem . Von 1,5 Meter Abstand muss ich mich schon konzentrieren darauf und darf im Hintergrund kein Nebengeräusch sein . Aber kann man halt nichts machen bei dir leider . Wenn du unzufrieden bist bringt nun auch nichts .
Habe dieses Jahr einen Hörtest gemacht in der Firma . Arzt war hoch zufrieden und habe bei meiner PS5 den Lüfter damals getauscht , weil der nicht leise war . Nidec gegen NMB .
Absolut unempfindlich bin ich nicht . Allerdings arbeite ich in der Produktion und bin mit lauten Maschinen etc. vertraut und habe da ne andere Schmerzgrenze als jemand der im Büro arbeitet .
3 ghz sind schonmal drin, so wie bei den meisten denke ich...
Naja die meisten FEs machen die 3000Mhz in Timespy Extreme oder Speedway glaube ich nur mit erhöhter Spannung. Kann mir keiner erzählen, dass er +300 Core sauber durch so nen Bench kriegt.
@MS1988
Ja das Ding ist schon durch war bei meinem Saturn vor Ort wie einer mir hier schon geschrieben hat nach 45 min hab ich die E-Mail von PayPal erhalten das Geld von Saturn überwiesen wurde!
Der Verkäufer sagte auch das er die Karte mit Spulen fiepen als defekt deklariert.
Er meint sowas darf einfach nicht sein bei so einem teuren Produkt versteht er meine Rückgabe !
Ich möchte die Karte vielleicht 3 Jahre behalten oder später vielleicht meiner Tochter geben von daher nehme ich es in Kauf weiter zu suchen,
Top Service bei Saturn!
Wen meinst Du denn mit "er" ?
Habe PL auf 110% gestellt...
Habe ich auch nie behauptet! Bitte genau lesen! Habe immer gesagt könnte/kann und ich habe meine Erfahrung auf jene aus dem Forum bzw. anderen Foren bezogen. Natürlich gibt es auch z.B. eine Strix, welche leise ist, hatten wir in dem Forum ja schon. Es ging mir nur darum, dass vermeintliche "Premium Karten" nicht gleich besser sind, als günstigere Modelle bei dieser Generation und wenn man mit Premium Komponenten wirbt aber diese Karten dann nicht besser performen (in vielerlei Hinsicht), als Einsteigermodelle, kann man nicht sagen, dass diese Karten besser/schlechter sind, besonders in dem Punkt mit den vermeintlich "besseren" Spulen und weniger Spulengeräuschen :d.
grammatikalisch das Pronomen "keiner", weswegen auf Grund dessen männlichen Geschlechts, (ich spare mir in einem Enthusiasten-Hardwareforum das Gendern) das Bezugspronomen richtigerweise "er" lautet.
@MS1988
Vielleicht probierst du wirklich mal ne Zotac.
Die haben die hohen Spulen und die zb. hat wohl auch mehr Phasen .
Wo wahrscheinlich es auf die Edition ankommt.
Es gibt wohl auch ein Vollausbau mit 24 Phasen die etwas schwächer sind als die der Customs , aber immerhin 24 Phasen und das sollte auch
gut sein. Die kann auch 495 Watt PL was ja auch ganz ok ist für paar Test´s.
Im Alltag reichen eh die 450 Watt .
Waterblock von EKWB dafür ist für Januar 2023 geplant.
Da die Karte bei dir unter Wasser soll wäre es ja nicht so wichtig den besten Luftkühler zu haben.
Re bar + g4 decoding oder encoding teil drüber anmachen
Welches board hast du ? du musst auch noch was mit 4g anmachen
bei ASUS
  • Above 4G Decoding: Enabled
  • Re-size BAR Support: AUTO
Richtig schön leise die Karte was die Spulen angeht
Achso :)
Alles was unter +1200 Speicher ist, ist unterdurchschnittlich.
GPU Takt liegt so bei 3050 - 3075 mhz in Benchmarks bei Timespy Extreme durchschnittlich.
Dann hab ich jetzt 3x meeh hier (gehabt). 3 Ghz ging bei einer Karte gar nicht, die anderen mit ach und krach bei 1.1V
Ohne Spannungsanhebung max. 2925-2940 rum.
Speicher ist invers temperaturempfindlich. Aufgeheizt +1600 mgl., gut gekühlt schmeißt +1500 direkt beim Start einer 3D Anwendun Artefakte und schmiert ab.
Ja da hast du eigentlich Recht die 600W sind fürs benchen gut so für den Alltag kommt man mit 500W eigentlich aus,
Wenn die Master nicht so teuer gewesen wäre hätte ich sie behalten und auf Wasser gebaut!
Die war was spülen angeht auch eine andere Liga gegenüber der TUF!
Wie ist den die Suprim MSI?
Suprim soll ähnlich der Asus Karten sein. Und ehrlich, zum Gamen reichen 350W mehr als aus. CP2077 mit 3050Mhz und 550W = 77fps mit 2700Mhz und 350W= 73 fps. RT Psycho alles am Anschlag 4k und DLSS auf Qualität.
Beste Grüße
Sollte rein vom PCB Design das beste auf dem Markt sein nach der HOF .
Die hat 26 Phasen mit 70A pro Phase wie bei den anderen Custom auch , aber eben auch flachere Spulen .
Aber die teile von Monolithic soll wohl das allerbeste sein derzeit.
Hat die Strix wohl auch und die TUF hat wohl von Infineon bzw alles bisschen gemischt^^ , aber kenne mich da garnicht so krass aus.
Hier mal die Strix als vergleich https://www.techpowerup.com/review/asus-geforce-rtx-4090-strix-oc/4.html
Hier noch der Teardown der TUF https://www.kitguru.net/components/graphic-cards/dominic-moass/asus-rtx-4090-tuf-gaming-oc-review/2/
Die Zotac mit den 24 Phasen wäre mal was komplett anderes von den Komponenten her und ist deutlich besser ausgestattet von
PCB Design als die ganzen 14 Phasen Dinger die es derzeit noch zu kaufen gibt.
Meine die 3090 Gainward GS die ich hatte war besser ausgestattet als manche 4090er derzeit auf dem Markt .
Glaube 16 oder 18 Phasen mit dem selben Komponenten , aber 365 Watt PL und plötzlich reichen davon ein 14 Phasen Design für 450 Watt aus ?
Kann sein , aber man will ja schon bisschen was für sein Geld und da darf es schon ein bisschen mehr sein.
mmmmmüll :fresse:
TimeSpy Extreme ist ziemlich anspruchslos für die GPU. Bekomme das auch noch mit +270 durch (3045 Mhz bei 70 Grad und 1.1V). Heaven kackt da schon lange ab.
TS Extreme Graphic Test 2 ist aber hervorragend als Speicher-OC-Test geeignet.
Meine geht schon bei +180 auf 3045. Dann ist aber Schluss. Was für ein PL hast du?
Ach ja und 55 Grad Core.
Was Stabilität angeht vielleicht, aber was Load angeht ist der TSE GT2 bisher die Anwendung mit dem höchsten Power Draw bei mir :d
Ich hab ne FE. Power Limit 600W aber da meine ja nicht Werksübertaktet ist kann/muss ich mehr offset geben.
3045 bei 55 Grad in Time Spy Extreme packt meine auch. Kannst ja mal Unigine Heaven laden und mit den höchsten Settings laufen lassen. Würde mich mal interessieren was dann geht.
Ich habe heute in der Pause mal mein System auf Default, OC und Undervolting getestet mit Stromanzeige in W mit voller Gaminglast in 4K mit RT.
OC:
13900KF mit 5,8GHZ all core, All Limits Removed 398W
4090 Frostbite mit max OC und max Voltage 450W
Total aus der Dose vom Rechner = Knapp 872W
105% Leistung
Default:
13900KF Stock = 290W
4090 Frostbite default ohne Voltageerhöhung = 424W
Total aus der Dose vom Rechner = Knapp 731W
Maßstab 100% Leistung
Undervolting:
13900KF mit 1,32v im Bios. Das sind 1.137V unter Last mit LCC4 in Windows = 211W
4090 Frostbite 70% undervolting = 320W
Total aus der Dose vom Rechner = Knapp 551W
92% Leistung
Von OC bis Undervolting verliere ich in etwa nur 13% Leistung, aber ich habe 37% weniger Stromvebrauch. Es bleibt noch zu erwähnen, dass die CPU ca. 15 grad kälter ist und die Karte auch 5-6 Grad weniger hat.
Ähnliche Themen
Antworten
7K
Aufrufe
541K
