[Sammelthread] NVIDIA GeForce RTX 4090 + FAQ
Here we go again
Quelle:
TEST:
Karten:
News:
Wakü News:
Shops:
PowerLimits:
KarteMinMax
4090 Founders Edition450W600W
4090 Gainward Golden Sample450W450W
4090 MSI Suprim X450W450W Silent Mode / 520W Power Modus
4090 STRIX OC500W600W / Dual Bios
4090 Aorus Master450W600W
4090 Zotac AMP Extreme450W495W
4090 MSI Suprim Liquid X480W530W / Selten auch 600W
4090 Gigabyte Gaming OC450W600W
4090 Palit Gamerock OC450W500W
CARDGPU Voltage PhasesGPU Voltage ControllerGPU MOSMOS Current (A)Total GPU CurrentMemory Voltage PhasesMemory Voltage ControllerMemory MOSMOS Current (A)Total Memory CurrentTotal PhasesSource
MSI Suprim X (& Liquid)
26​
Monolithic MP2891Monolithic MP86957
70​
1820​
4​
70​
280​
30​
Techpowerup
ASUS STRIX OC
24​
Monolithic MP2891OnSemi FDMF3170
70​
1680​
4​
70​
280​
28​
Techpowerup
Nvidia Founders
20​
70​
1400​
3​
70​
210​
23​
Techpowerup
Colorful Vulcan (& Neptune)
24​
uPI uP9512UAlpha & Omega AOZ5311NQI-03 BLN3
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI-03 BLN3
55​
220​
28​
Techpowerup
Zotac AIRO
24​
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI BLN0
50​
200​
28​
Techpowerup
ASUS TUF OC
18​
Monolithic MP2888AInfineon TDA21570
70​
1260​
4​
uPI uP9512QVishay SIC638A
50​
200​
22​
Hardware Unboxed
Gigabyte Gaming OC
20​
uPI uP9512UVishay SIC653A
50​
1000​
4​
uPI uP9512RVishay SIC653A
50​
200​
24​
Techpowerup
MSI Gaming Trio X
18​
Monolithic MP2891OnSemi NCP303151
50​
900​
4​
50​
200​
22​
CoolPC
Palit GameRock OC
16​
uPI uP9512UOnSemi NCP302150
50​
800​
3​
uPI uP9512ROnSemi NCP302150
50​
150​
19​
Techpowerup
Zotac Trinity OC
14​
55​
770​
4​
50​
200​
18​
CoolPC
Inno3D X3 OC
14​
uPI uP9512UAlpha & Omega AOZ5311NQI BLN0
55​
770​
3​
55​
165​
17​
KitGuru
Gigabyte Windforce
14​
?Vishay SIC653A
50​
700​
4​
?Vishay SIC653A
50​
200​
18​
profesionalreview
Tool
How To?
Anleitung
7. Enter drücken
10. PC neu starten
Seasonic
gibt Ihren Kunden das Kabel Umsonst, für spezielle Seasonic-NT, welche in den letzten 12 Monaten gekauft wurde.
Corsair
FAQ:
Verliere ich Leistung, wenn ich die RTX 4090 mit PCIe 3 laufen lasse? > Ja, ca 2,1% :) Also nicht viel
Quelle: https://www.computerbase.de/2022-10...hnitt_die_geforce_rtx_4090_mit_pcie_30_update
Fall jemand gerade einen neuen Prozzi sucht für seine 4090 und noch AM4 hat:
Innerhalb von ein paar Tagen von 467€ auf 366€ gefallen, 101€ weniger ist schon extrem krass. Wow 🤩
Wow
Das wurde mir gerade sowas von schmackhaft gemacht !
Aber leider stecke ich noch in der Planung einer Custom Kühlung und ich denke, da geht das meiste Budget bestimmt drauf
Vor allen weil ich sowas noch nie gemacht habe 😅
Ich frag mich auch wie er Warzone 2 gespielt hat, Release ist erst am 16.11. aber wahrscheinlich einfach vertippt 😁
Kannst doch die Solo Kampagne ab dem 20.10 spielen nur Multiplayer geht noch nicht
Nein, die Warnung der PCI-SIG stammt erst aus dem September.
Sicher? Soweit ich weiß, war das ein Leak und dieser wurde im September publik. Ob die Bedenken erst im September geäußert wurden, weiß ich nicht.
Nein, aber genau deine zweite Aussage ist der Knackpunkt. 3 von x tausend Karten sind defekt und du tust so, als könnte das bei jedem passieren.
Das ist aber nur der Fall, wenn der Stecker grundsätzlich Fehlerhaft ist und genau das wissen wir nicht. Bei 3 Fällen kann man jedenfalls noch nicht von einem grundsätzlichen Problem sprechen.
Selbstverständlich kann das bei jedem passieren. Auch bei Dir.
Das Problem ist doch offensichtlich konzeptions- und konstruktionsbedingt. Nvidia agiert hier an den Grenzen des physikalisch Machbaren.
Meines Wissens nach sind alle Kabeladapter von Nvidia. Natürlich variiert die Qualität des einzelnen Kabels über die Serie hinweg, manche werden gleich bei der initialen Prüfung aussortiert. Andere haben versteckte Materialfehler und einige werden sicher vom Verbraucher unsachgemäss eingesetzt. So what? Das ändert nichts am Risiko. Jeder muss für sich beantworten, ob "3 von x tausend" Kabeln/Steckern (nicht unbedingt Karten, was Du schreibst) vertretbar ist. Persönlich finde ich das Risiko zu hoch. Aber ich habe auch einen anderen Einsatzzweck und starre nicht die ganze Zeit auf das RGB Innenleben eines Gehäuses, um dann im Notfall den Stecker ziehen zu können.
Das ist dann die richtige CPU für das ATX 3.0 Netzteil ... LOL
Sehr konsequent ;-)
Als nVidia würde ich auch erstmal sowas öffentlich sagen. Du hast ja keine Ahnung was es da alles für Adapter und Netzteilkabel gibt. Sie beziehen sich nur auf das was sie auch vertreten müssen.
Dann fallen alle neuen Netzteile raus weil deren genormte 12VHPWR Anschlüsse nicht verwendet werden dürfen...
Die Nummer wird ein Fail für Nvidia und spätestens nach ersten größeren Schäden werden unangenehme Fragen von Gutachtern eintreten,die müssen nur Google nutzen um belastbare Quellen für weitere Untersuchungen zu finden.
naja bios flashen um compatibility zu erhöhen?
ne danke
Woher willst du das wissen?
Dann darfst du absolut keine Elektronik einsetzen. Nirgends.
Du wirst zu jedem NT Hersteller mindestens 3 Fälle finden, bei denen das NT abgeraucht ist. Das gleiche bei Grafikkarten, Handys, Akkuschraubern etc.
Hier findest du mehrere verschmorte 8 Pin Stecker/Kabel: https://www.google.de/search?q=pcie...HTJgAt4Q_AUoAXoECAEQAw&biw=1653&bih=813&dpr=1
Benutzt du die nun auch nicht mehr?
Das Thema hatten wir schon, es heißt Modern Warfare 2 Kampagne und nicht (Warzone 2) und der Rest ist mir bekannt (habs wie gesagt selbst schon zwei Mal durchgespielt)...
ja
sie darf nur 90% der 450w verbrauchen, solange sie nicht voll ausgelastet ist am Anschlag, hast du keine Leistungseinbußen
keine ahnung
Aber ist das mit den 90% PT nur eingestellt sobald ich Afterburner starte, oder immer?
Bei der Strixx sollten es ja auch 600W sein?
Mein Problem ist, dass ich im Vergleich was mein System hergeben sollte, überall weniger FPS usw habe.
EKWB Verzögerung bei Strix/TUF Kühler
afterburner zeigt dir an was da ist
sprich das mit den 90% ist immer, außer du änderst es im Afterburner
die 600w sollten dann aber 130% oder so sein, denke die 100% sind 450w
vllt. hast du aber auch was falsch angestöpselt und nicht 4 seperate Strings vom Netzteil genommen, dann darf die Karte nicht die volle Leistung ziehen
Seit gestern habe ich 4 separate Strings dran, ich habe aber immer noch nur 90%.
Gibt es irgendwo Tests mit einer 4090 bei dem der 5950X und der 5800X3d in 4k getestet wird? :d
den Regler auf 130% ziehen geht nicht?
Bei mir wurde das Problem mit einem BIOS Update gelöst hat auch MSI geschrieben.
Lg
Bios Update für die Gigabyte Gaming OC verfügbar:
Hat das bei jemanden funktioniert? Starte ich die jeweilige .exe für das Bios, sagt er mir, dass der Bios Mode nicht übereinstimmen würde...
Jetzt ist die Suprim schon bei 2599. Die Preise steigen täglich :(
Im Netzteil sitzt alles fest, die Kabelverbindung zum Adapter und der Adapter selbst auch.
Hatte bis gestern 3 Strings dran und da waren es auch 90%.
Bei der Strixx leuchtet auch immer im ausgeschalteten Zustand eine rote LED, aber eben nicht mehr wenn der PC an ist.
Habe selbst noch nichts verändert am Powertarget, weil ich mir da nicht sicher war, ob es eben nicht automatisch auf 100% stellen sollte.
Das bei MSI waren 93%, es gäbe sogar ein neues Bios von Asus, aber da steht nichts zu dem Thema.
@Orgh Bei mir wurde das Problem mit einem BIOS Update gelöst hat auch MSI geschrieben.
Und steht seitdem 100%, wenn du Afterburner startest?
Edit: Der Niedrigste Preis liegt sogar bei 348€!: 🙏🙏🙏
Mindfactory hat im übrigen Nachgezogen, 347€ dort jetzt + die Uncharted PC spiele kostenlos wenn man die CPU bei denen kauft.
@scars Was steht bei dir beim starten von Afterburner?
90 oder 100%
Ähnliche Themen
Antworten
6K
Aufrufe
392K
