Du verwendest einen veralteten Browser. Es ist möglich, dass diese oder andere Websites nicht korrekt angezeigt werden. Du solltest ein Upgrade durchführen oder einen alternativen Browser verwenden.
[Sammelthread]ASUS X570 Strix Series (X570-E Gaming, X570-E Gaming Wifi II, X570-F Gaming, X570-I Gaming)
AMD AM4 Socket 3rd and 2nd AMD Ryzen™/2nd and 1st Gen AMD Ryzen™ with Radeon™ Vega Graphics Processors
Chipset
X570
Memory
3rd Gen AMD Ryzen™ Processors
4 x DIMM, Max. 128GB, DDR4 4400(O.C)/4266(O.C.)/4133(O.C.)/4000(O.C.)/3866(O.C.)/3600(O.C.)/3400(O.C.)/3200(O.C.)/3000(O.C.)/2800(O.C.)/2666/2400/2133 MHz Un-buffered Memory *
2nd Gen AMD Ryzen™ Processors
4 x DIMM, Max. 128GB, DDR4 3600(O.C.)/3400(O.C.)/3200(O.C.)/3000(O.C.)/2800(O.C.)/2666/2400/2133 MHz Un-buffered Memory *
4 x DIMM, Max. 128GB, DDR4 3200(O.C.)/3000(O.C.)/2800(O.C.)/2666/2400/2133 MHz Un-buffered Memory
Dual Channel Memory Architecture
Graphic
Integrated Graphics in the 2nd and 1st Gen AMD Ryzen™ with Radeon™ Vega Graphics Processors
Multi-VGA output support : HDMI/DisplayPort ports
- Supports HDMI 2.0b with maximum resolution of 4096 x 2160 @ 60 Hz
- Supports DisplayPort 1.2 with max. resolution 4096 x 2160 @ 60 Hz
Multi-GPU Support
3rd and 2nd Gen AMD Ryzen™ Processors
Supports NVIDIA® 2-Way SLI® Technology
Supports AMD 3-Way CrossFireX™ Technology
Supports AMD 2-Way CrossFireX™ Technology
Expansion Slots
2 x PCIe 4.0 x16 (x16 or dual x8)
2 x PCIe 3.0 x16 (x16 or dual x8)
1 x PCIe 3.0 x16 (x8 mode)
AMD X570 chipset
1 x PCIe 4.0 x16 (max at x4 mode) *1
2 x PCIe 4.0 x1
Storage
3rd Gen AMD Ryzen™ Processors :
1 x M.2 Socket 3, with M Key, Type 2242/2260/2280/22110(PCIE 4.0 x4 and SATA modes) storage devices support
2nd Gen AMD Ryzen™/2nd and 1st Gen AMD Ryzen™ with Radeon™ Vega Graphics Processors :
1 x M.2 Socket 3, with M Key, Type 2242/2260/2280/22110(PCIE 3.0 x4 and SATA modes) storage devices support
AMD X570 chipset :
1 x M.2 x4 Socket 3, with M Key, Type 2242/2260/2280/22110(PCIE 3.0 x4 and SATA modes) storage devices support
8 x SATA 6Gb/s port(s),
Support Raid 0, 1, 10
LAN
Intel® I211-AT, 1 x Gigabit LAN Controller(s)
Realtek® RTL8125-CG 2.5G LAN
Anti-surge LANGuard
ROG GameFirst Technology
WiFi
2 x 2 Wi-Fi 6 (802.11 a/b/g/n/ac/ax) with MU-MIMO supports dual frequency band 2.4/5GHz
Bluetooth
Bluetooth® 5.0
Audio
SupremeFX 8-Channel High Definition Audio CODEC S1220A
- Dual OP Amplifiers
- Impedance sense for front and rear headphone outputs
- Supports : Jack-detection, Multi-streaming, Front Panel Jack-retasking
- High quality 120 dB SNR stereo playback output and 113 dB SNR recording input
- SupremeFX Shielding Technology
- Supports up to 32-Bit/192kHz playback *2
Audio Feature :
- Optical S/PDIF out port(s) at back panel
- Sonic Radar III
- Sonic Studio III + Sonic Studio Link
USB Ports
3rd Gen AMD RyzenTM Processors :
4 x USB 3.2 Gen 2 port(s) (4 at back panel, )
2nd Gen AMD RyzenTM/2nd and 1st Gen AMD Ryzen™ with Radeon™ Vega Graphics Processors :
4 x USB 3.2 Gen 1 port(s)
AMD X570 chipset :
1 x USB 3.2 Gen 2 front panel connector port(s)
AMD X570 chipset :
4 x USB 3.2 Gen 2 port(s) (4 at back panel, , 3 x Type-A+1 x Type-C)
AMD X570 chipset :
2 x USB 3.2 Gen 1 port(s) (2 at mid-board)
AMD X570 chipset :
4 x USB 2.0 port(s) (4 at mid-board)
Special Features
5-Way Optimization by Dual Intelligent Processors 5
- Whole system optimization with a single click! 5-Way Optimization tuning key perfectly consolidates TPU, EPU, DIGI+ VRM, Fan Xpert 4, and Turbo App together, providing better CPU performance, efficient power saving, precise digital power control, whole system cooling and even tailor your own app usages.
TPU
- Auto Tuning, TurboV, GPU Boost
Gamer's Guardian:
- DRAM Overcurrent Protection
- Stainless Steel Back I/O
- Highly Durable Components
- DIGI+ VRM
- SafeSlot
- ESD Guards on LAN, Audio,and USB ports
ASUS EPU :
- EPU
AURA :
- Aura Lighting Control
- Addressable Gen 2 Header
ASUS Exclusive Features :
- USB BIOS Flashback®
- AI Suite 3
- Ai Charger
- ASUS NODE : hardware control interface
- BIOS Flashback® Button
ASUS EZ DIY :
- ASUS CrashFree BIOS 3
- ASUS EZ Flash 3
ASUS Q-Design :
- ASUS Q-Code
- ASUS Q-LED (CPU, DRAM, VGA, Boot Device LED)
- ASUS Q-Slot
- ASUS Q-DIMM
Gaming Aesthetics :
- AURA-RGB Lighting
Back I/O Ports
1 x DisplayPort
1 x HDMI
5 x USB 3.1 Gen 1 Type-A
8 x USB 2.0
1 x Optical S/PDIF out
5 x Audio jack(s)
1 x Anti-surge 2.5G LAN (RJ45) port
1 x USB BIOS Flashback® Button(s)
1 x ASUS Wi-Fi Module
7 x USB 3.2 Gen 2 (up to 10Gbps) ports (Type-A)
1 x USB 3.2 Gen 2 (up to 10Gbps) ports (Type-C)
Anti-surge LAN (RJ45) port
Internal I/O Ports
1 x PCH_FAN
1 x AAFP connector
2 x Aura RGB Strip Header(s)
2 x Addressable Gen 2 header(s)
2 x USB 2.0 connector(s) support(s) additional 4 USB 2.0 port(s)
2 x M.2 Socket 3 with M key, type 2242/2260/2280/22110 storage devices support
1 x SPI TPM header
8 x SATA 6Gb/s connector(s)
1 x CPU Fan connector(s)
1 x CPU OPT Fan connector(s)
2 x Chassis Fan connector(s)
1 x AIO_PUMP connector
1 x W_PUMP+ connector
1 x 24-pin EATX Power connector(s)
1 x 8-pin ATX 12V Power connector(s)
1 x 4-pin ATX 12V Power connector(s)
1 x Front panel audio connector(s) (AAFP)
1 x Thermal sensor connector(s)
1 x Clear CMOS jumper(s)
1 x Node Connector(s)
1 x System panel connector
1 x T_Sensor Connector
1 x M.2 Fan Header
1 x USB 3.2 Gen 2 (up to 10Gbps) connector
1 x USB 3.2 Gen 1 (up to 5Gbps) connector support additional 2 USB ports
Accessories
User's manual
4 x SATA 6Gb/s cable(s)
1 x M.2 Screw Package
1 x Supporting DVD
1 x Strix door hanger
1 x ROG Strix stickers
1 x Cable ties pack(s)
1 x Wi-Fi Antenna(s)
1 x Extension Cable for RGB strips (80 cm)
1 x Extension cable for Addressable LED
1 x Thermistor cable(s)
1 x ROG Thank you card
BIOS
256 Mb Flash ROM, UEFI AMI BIOS, PnP, WfM2.0, SM BIOS 3.2, ACPI 6.2.
Form Factor
ATX Form Factor
12 inch x 9.6 inch ( 30.5 cm x 24.4 cm )
Note
*1 PCIeX16_3 slot shares bandwidth with PCIeX1_2.
*2 Due to limitations in HDA bandwidth, 32-Bit/192kHz is not supported for 8-Channel audio.
AMD Ryzen™ 5000 Series/ 3000 Series Desktop Processors
4 x DIMM, Max. 128GB, DDR4 4600(O.C.)/4400(O.C.)/4266(O.C.)/4133(O.C.)/4000(O.C.)/3866(O.C.)/3733(O.C.)/3600(O.C.)/3466(O.C.)/3400(O.C.)/3200/3000/2933/2800/2666/2400/2133, un-buffered memory
AMD Ryzen™ 5000 and 4000 G-Series Processors
4 x DIMM, Max. 128GB, DDR4 5100(O.C)/4800(O.C.)/4600(O.C)/4466(O.C.)/4400(O.C)/4266(O.C.)/4133(O.C.)/4000(O.C.)/3866(O.C.)/3600(O.C.)/3466(O.C.)/3200/3000/2800/2666/2400/2133, un-buffered memory
AMD Ryzen™ 2000 Series Desktop Processors
4 x DIMM, max. 128GB, DDR4 3600(O.C.)/3466(O.C.)/3400(O.C.)/3200(O.C.)/3000(O.C.)/2933/2800/2666/2400/2133, un-buffered memory
AMD Ryzen™ 2000 and 3000 G-Series Desktop Processors
4 x DIMM, max. 128GB, DDR4 3200(O.C.)/3000(O.C.)/2933/2800/2666/2400/2133, un-buffered memory
ECC Memory (ECC mode) support varies by CPU
Graphic
1 x HDMI 2.0
1 x DisplayPort
Expansion Slots
2 x PCIe 4.0 x16 (x16 or dual x8)*
AMD Ryzen™ 5000 G Series/4000 G-Series/ 2000 Series Processor
2 x PCIe 3.0 x16 (x16 or dual x8)*
AMD Ryzen™ 2000 G-Series/ 3000 G-Series Processor
1 x PCIe 3.0 x16 (x8 mode)*
AMD X570 Chipset
1 x PCIe 4.0 x16 slot (supports x4 mode)
2 x PCIe 4.0 x1
*PCIeX16_3 slot shares bandwidth with PCIeX1_2.
Storage
Supports 2 x M.2 slots and 8 x SATA 6Gb/s ports
AMD Ryzen™ 5000 Series/ 3000 Series Desktop Processors:
M.2_1 slot (Key M), type 2242/2260/2280/22110 (supports PCIe 4.0 x4 & SATA modes)
AMD Ryzen™ 5000 G-Series/4000 G-Series/ 3000 G-Series/ 2000 G-Series/2000 Series Processor
M.2_1 slot (Key M), type 2242/2260/2280/22110 (supports PCIe 3.0 x4 & SATA modes)
AMD X570 Chipset
M.2_2 slot (Key M), type2242/2260/2280/22110 (supports PCIe 4.0 x4 & SATA modes)
LAN
1 x Realtek 2.5Gb Ethernet
1 x Intel® I211-AT 1Gb Ethernet
Anti-surge LANGuard
1 x Intel® 1Gb Ethernet
WiFi
Wi-Fi 6E
2x2 Wi-Fi 6E (802.11 a/b/g/n/ac/ax)
Supports 2.4/5/6GHz frequency band*
Bluetooth
Bluetooth® v5.2
Audio
Realtek S1220A 7.1 Surround Sound High Definition Audio CODEC*
- Internal audio Amplifier to enhance the highest quality sound for headphone and speakers
- Supports: Jack-detection, Multi-streaming, Front Panel Jack-retasking
- High quality 120 dB SNR stereo playback output and 113 dB SNR recording input (Line-in)
- Supports up to 32-Bit/192 kHz playback*
Audio Features
- Gold-plated audio jacks
- Rear optical S/PDIF out port
- Premium audio capacitors
- Audio cover
USB Ports
AMD RyzenTM 5000, 5000 G-Series, 4000 G-Series, and 3000 Series Desktop Processors
- 4 x USB 3.2 Gen2 ports (4 ports at back panel, Type-A)
AMD RyzenTM 3000 G-Series, 2000, and 2000 G-Series Desktop Processors
- 4 x USB 3.2 Gen 1 ports (4 ports at back panel, Type-A)
AMD X570 chipset
- 1 x USB 3.2 Gen2 front panel connector
- 4 x USB3.2 Gen2 (at back panel, 3x Type-A, 1x Type-C)
- 2 x USB3.2 Gen1 ports (at front panel)
- 4 x USB 2.0 ports (at front panel)
Special Features
Extreme Engine Digi+
- 5K Black Metallic Capacitors
ASUS Q-Design
- M.2 Q-Latch
- Q-Code
- Q-DIMM
- Q-LED (CPU [red], DRAM [yellow], VGA [white], Boot Device [yellow green])
- Q-Slot
ASUS Thermal Solution
- M.2 heatsink
ASUS EZ DIY
- BIOS FlashBack™ button
- BIOS FlashBack™ LED
- ProCool II
- Pre-mounted I/O shield
- SafeSlot
AURA Sync
- AURA RGB headers
- Addressable Gen 2 headers
Back I/O Ports
8 x USB 3.2 Gen 2 ports (7 x Type-A + 1 x USB Type-C®)
1 x DisplayPort
1 x HDMI® port
1 x Wi-Fi Module
1 x Intel® I211-AT 1Gb Ethernet port
1 x Realtek 2.5Gb Ethernet port
5 x Gold-plated audio jacks
1 x Optical S/PDIF out port
1 x BIOS FlashBack™ button
Internal I/O Ports
Fan and Cooling related
1 x 4-pin CPU Fan header
1 x 4-pin CPU OPT Fan header
1 x 4-pin AIO Pump header
2 x 4-pin Chassis Fan headers
1 x 4-pin M.2 Fan header
1 x W_PUMP+ header
Power related
1 x 24-pin Main Power connector
1 x 8-pin +12V Power connector
1 x 4-pin +12V Power connector
Storage related
2 x M.2 slots (Key M)
USB
1 x USB 3.2 Gen 2 connector (supports USB Type-C®)
1 x USB 3.2 Gen 1 header supports additional 2 USB 3.2 Gen 1 ports
2 x USB 2.0 headers support additional 4 USB 2.0 ports
Miscellaneous
2 x Addressable Gen 2 headers
2 x AURA RGB headers
1 x Clear CMOS header
1 x Front Panel Audio header (AAFP)
1 x SPI TPM header (14-1pin)
1 x Speaker header
1 x 10-1 pin System Panel header
1 x Thermal Sensor header
Accessories
Cables
4 x SATA 6Gb/s cables
1 x Thermistor cable pack
Miscellaneous
1 x ASUS Wi-Fi moving antennas
1 x Cable ties pack
1 x M.2 Rubber Package
1 x M.2 Q-Latch package
1 x ROG key chain
1 x ROG Strix thank you card
Installation Media
1 x Support DVD
Documentation
1 x User manual
BIOS
Form Factor
ATX Form Factor
Note
ASUS ROG STRIX Z590-A GAMING WIFI II Intel LGA 1200 ATX motherboard, PCIe 4.0, 14+2 power stages, WiFi 6, Intel® 2.5 Gb Ethernet, three M.2 slots, USB 3.2 Gen 2x2 USB Type-C®, SATA and Aura Sync
Chipset
X570
Memory
Graphic
Multi-GPU Support
Expansion Slots
AMD X570 chipset
2 x PCIe 4.0 x1
Storage
AMD X570 chipset :
1 x M.2 x4 Socket 3, with M Key, Type 2242/2260/2280/22110(PCIE 4.0 x4 and SATA modes) storage devices support
LAN
Anti-surge LANGuard
Audio
Audio Feature :
- Sonic Radar III
USB Ports
3rd and 2nd Gen AMD Ryzen™/2nd and 1st Gen AMD Ryzen™ with Radeon™ Vega Graphics Processors :
4 x USB 3.2 Gen 1 port(s) (4 at back panel, )
AMD X570 chipset :
AMD X570 chipset :
AMD X570 chipset :
AMD X570 chipset :
Special Features
TPU
Gamer's Guardian:
- DIGI+ VRM
- SafeSlot
ASUS EPU :
- EPU
AURA :
- AI Suite 3
- Ai Charger
ASUS EZ DIY :
- ASUS EZ Flash 3
ASUS Q-Design :
- ASUS Q-Slot
- ASUS Q-DIMM
Gaming Aesthetics :
- AURA-RGB Lighting
Back I/O Ports
1 x DisplayPort
1 x HDMI
8 x USB 2.0
5 x Audio jack(s)
4 x USB 3.2 Gen 1 (up to 5Gbps) ports
3 x USB 3.2 Gen 2 (up to 10Gbps) ports (Type-A)
Internal I/O Ports
1 x PCH_FAN
1 x AAFP connector
1 x SPI TPM header
1 x M.2 Fan Header
Accessories
User's manual
1 x Supporting DVD
BIOS
Form Factor
ATX Form Factor
Note
Chipset
X570
Memory
2 x DIMM, Max. 64GB, DDR4 4800(O.C.)/4600(O.C)/4400(O.C)/4266(O.C.)/4133(O.C.)/4000(O.C.)/3800(O.C.)/3600(O.C.)/3466(O.C.)/3400(O.C.)/3200(O.C.)/3000(O.C.)/2933(O.C.)/2800(O.C.)/2666/2400/2133 MHz Non-ECC, Un-buffered Memory *
2 x DIMM, Max. 64GB, DDR4 3600(O.C.)/3466(O.C.)/3400(O.C.)/3200(O.C.)/3000(O.C.)/2933/2800(O.C.)/2666/2400/2133 MHz Non-ECC, Un-buffered Memory *
2 x DIMM, Max. 64GB, DDR4 3200(O.C.)/3000(O.C.)/2933(O.C.)/2800(O.C.)/2666/2400/2133 MHz Non-ECC, Un-buffered Memory
Graphic
- Support DisplayPort 1.4 with max. resolution 8 K 7680 × 4320 @60 Hz
Expansion Slots
1 x PCIe 4.0 x16 (x16 mode)
1 x PCIe 3.0 x16 (x16 mode)
Storage
1 x M.2_1 socket 3, with M Key, Type 2242/2260/2280 (PCIE 4.0 x4 and SATA modes) storage devices support
1 x M.2_1 socket 3, with M Key, Type 2242/2260/2280 (PCIE 3.0 x4 and SATA modes) storage devices support
AMD X570 chipset :
1 x M.2_2 socket 3, with M Key, Type 2242/2260/2280 (PCIE 4.0 x4 and SATA modes) storage devices support
4 x SATA 6Gb/s port(s),
Supports channel bandwidth: HT20/HT40/HT80/HT160
Intel® Wi-Fi 6 AX200
Up to 2.4Gbps transfer speed
Bluetooth
Bluetooth® 5.0
Audio
Audio Feature :
- DTS® Sound Unbound
- LED-illuminated design - Brighten up your build with the gorgeous illuminated audio trace path.
- Sonic Radar III
- Sonic Studio III + Sonic Studio Virtual Mixer
USB Ports
4 x USB 3.2 Gen 1 port(s) (4 at back panel, blue)
AMD X570 chipset :
4 x USB 3.2 Gen 2 port(s) (3 x Type-A+1 x Type-C)
AMD X570 chipset :
AMD X570 chipset :
2 x USB 2.0 port(s)
Special Features
TPU
ASUS EPU :
- EPU
AURA :
- AI Suite 3
- Ai Charger
ASUS EZ DIY :
- ASUS EZ Flash 3
ASUS Q-Design :
- ASUS Q-Shield
- ASUS Q-Slot
- ASUS Q-DIMM
Back I/O Ports
1 x DisplayPort
1 x HDMI
3 x LED-illuminated audio jacks
4 x USB 3.2 Gen 1 (blue)
Internal I/O Ports
1 x HS_FAN
1 x PCH_FAN
1 x AAFP connector
1 x Aura RGB Strip Header(s)
1 x Addressable Gen 2 header(s)
1 x USB 3.2 Gen 1(up to 5Gbps) connector(s) support(s) additional 2 USB 3.2 Gen 1 port(s)
1 x USB 2.0 connector(s) support(s) additional 2 USB 2.0 port(s)
2 x M.2 Socket 3 with M Key design, type 2242/2260/2280 storage devices support (Supports both SATA & PCIE SSD)
4 x SATA 6Gb/s connector(s)
1 x Chassis Fan connector(s)
1 x Speaker connector
Accessories
User's manual
I/O Shield
2 x M.2 Screw Package
1 x Supporting DVD
1 x M.2 bracket
1 x AAFP Extension Cable
1 x Panel cable
BIOS
Form Factor
Mini ITX Form Factor
6.7 inch x 6.7 inch ( 17 cm x 17 cm )
Note
*1 Due to limitations in HDA bandwidth, 32-Bit/192kHz is not supported for 8-Channel audio.
*2 Use a chassis with HD audio module in the front panel to support an 8-channel audio output.
Sound setzt aus oder knistert
Immer wieder USB Disconnects
Meistens tritt dieses Problem auf, wenn man einen hohen RAM Takt verwendet. In diesem Fall kann man versuchen die SOC Spannung auf 1.125V zu erhöhen. Sollte das nicht ausreichen, zusätzlich noch die VDDG CCD Spannung auf 1.00V (oder niedriger), sowie VDDG IOD Spannung auf 0.925V stellen.
USB Disconnects
Mit bestimmten UEFI/Agesa Versionen (v2 1.1.0.0/ 1.1.8.0) können sporadische USB Disconnects auftreten. Um dies zu umgehen bitte folgende Einstellung im Bios deaktivieren:
UEFI -> Advanced -> AMD CBS -> Global C-States deaktivieren
Der Verbrauch steigt dadurch um ca. 5Watt an aber ansonsten hat man keine weiteren Nachteile
USB Flashback funktioniert nicht
Bitte folgende Punkte ausprobieren:
- Datei richtig umbenannt? Vorzugsweise mit dem im BIOS Download enthaltenen Renamer
- Vor dem Flashen das BIOS auf Werkseinstellungen zurück setzen!
- Einen anderen USB Stick ausprobieren. Vorzugsweise ein USB 2.0 Stick
BIOS/UEFI Downgrade
Ein UEFI Downgrade ist ohne Probleme mit USB Flashback möglich, soweit vorhanden.
Ist der Chipsatz Lüfter regelbar?
Nein, dieser wird automatisch, je nach vorhandener Temperatur, geregelt. Bis zu einer Temperatur von 55 Grad ist der Lüfter deaktiviert. Bei höheren Temperaturen wird er stufenweise schneller bis er letztendlich bei 93 Grad seine Höchstgeschwindigkeit erreicht. Über selbst erstellte Bios Mods kann man jedoch den Lüfter auch nach seinen Wünschen einstellen.
Chipsatz Temperatur zu hoch?
Wem das Optische nicht so wichtig ist, kann die Lüfterabdeckung vom Chipsatz beim X570-E oder x570-F entfernen. Dadurch staut sich die warme Luft nicht an, sondern kann direkt entweichen.
Des weiteren kann man im Bios unter "Onboard Devices Configuration" die vorhandenen Steckplätze (PCIe X16, X1, M.2, SB Link) manuell auf PCIe 3.0 umstellen, sofern man keine PCIe 4.0 Karte verwendet. Bei Auto Einstellung wird automatisch PCIe 4.0 angelegt, was zu einer höheren Last führt.
Kann ich ein altes Bios Profil mit einer neuen Bios Version nutzen?
Nein, es ist zu empfehlen kein altes Profil mit einer neuen oder älteren Bios Version zu nutzen. Dies endet meist mit einem Blackscreen. Nach jedem Bios Flash bitte die Einstellungen neu vornehmen. Selbst wenn sich ein Profil laden lässt, kann es trotzdem zu Instabilität führen.
Rechner bootet nicht, wenn eine Soundkarte verbaut ist
Dieses Problem kann mit dem Bios 1404 oder höher (Agesa 1004b) auftreten. In dem Fall bitte in dem AMD CBS Menü die Option "PCIe Ten Bit Tag Support" auf Disabled stellen. Sollte das nicht ausreichen, dann zusätzlich noch unter dem Menü Advanced -> Onboard Devices Configuration -> die Option PCIEXxxx (den Slot auswählen, in der die Soundkarte steckt) von Auto auf Gen3 ändern.
ist das normal das am USB C Anschluss hinten fast keine Stromstärke anliegt? Handy und VR Brille laden da Ultra Ultra langsam (5% in eine stunde). Mein altes MSI Board war da erheblich schneller...
Driven by innovation & committed to quality, ASUS has a wide selection of best in class products. Find & buy a laptop, phone, router, monitor, motherboard & more
Danke! Habs installiert und habe jetzt n neues Symbol in der Leiste. Aber das kann man weder öffnen noch reagiert das auf rechtsklick. Egal was ich zum laden drannhänge oder welches Kabel/Port ich benutze das symbol hat immer ein rotes "X" verhext
bin schon ein stück näher alle geräte werden nur mit usb 2 erkannt egal in welchen port
Ich hatte jetzt wieder das Strix-F Problem, dass der Rechner nicht mehr postet.
Das war bei mit bisher zweimal passiert nachdem der Rechner stromlos war.
Diesmal war er nicht stromlos, d.h. runtergefahren (ist er dabei hängen geblieben?, ich weiß es nicht mehr) und am nächsten Tag wollte er nicht mehr.
Habe ein bisschen USB abgezogen, etwas HDMI.
Er bleibt nach dem Anschalten auf weiß (VGA) hängen, wenn man dann resettet meist auf Orange (RAM) sehr selten auch rot (CPU) oder VGA.
Habe dann tatsächlich zwei Tage lang dann und wann mal wieder nebenbei probiert. Nix.
Heute dann Tag drei, morgens wieder mal angeschaltet. Grün, Board postet und bootet auch. Alles normal.
Überhaupt keine Änderung seit den letzten Versuchen gestern. Rechner läuft ...
Bios ist die 3602, resizeable Bar ist an, CSM daher aus ... war evtl. vorher an.
Aber auch das BIOS ist schon seit 2 Wochen und Settings nicht geändert.
DOCP an mit Ballistix 3600er Ram.
System ist links auch zu sehen.
Zufall oder Temperaturproblem?
Aber wenn es Zufall wäre ... warum ist es dann irgendwie zig Mal hintereinander da.
Das Ganze jetzt mit der 3080, war aber mit der 2080S vorher auch.
Was mache ich jetzt?
Nie mehr abschalten?
Neues Board?
Eigentlich sollte das noch 2 Jahre min. gut sein
Die Software "Ai Charger" braucht es nur zum Laden von iPhone/iPod/iPad.
Ansonsten darf ich anmerken, dass der Standard für USB-C bis zu 3 Ampere an 5 Volt spezifiziert (bis einschließlich USB 2.0 waren es höchstens 0,5 A, bei USB 3.1 max. 0,9 A).
Neues Board?
Kann ich so was ähnliches bestätigen ich hatte letzte Woche 2mal den Fall das nach einen Kaltstart das Bios bootet und er mir im POST-Code 00 angezeigt hatte. Jeweils nach einen CMOS Clear war wieder alles gut. Zum Glück kommt das nicht so oft vor
Neues Board?
this also happened to me once or twice with the strix x570, and it also happened on the asus x570 TUF , after CMOS clear, it solved it.
I wonder if somehow the timings are changed or lost during cold start.
War bei meinem B550 Strix Gaming-a, Ryzen 5800x und Crucial Ballistix 3600 leider auch so. Orangene Debug Lampe leuchtete ab und zu. Egal ob Kalt- oder Warmstart. Nach ein paar Versuchen bootete der Rechner aber wieder ganz normal. Systemabstürze hatte ich keine. Nach Biosupdate, Clear CMOS und Einstellen des XMP-Profils läuft seit einer alles wie am Schnürchen.
P.s.: Ich habe das aktuelle Beta BIOS installiert. Läuft ohne Probleme.
Danke für die Meldungen.
Ich hätte auch ein Cmos Reset probiert als Nächstes.
Finde den aber nicht einfach, Rechner unterm Tisch usw. ist Gefummel.
Einmal habe ich schon die CMOS Batterie ausgebaut weil das mit dem Jumper irgendwie nicht klappte... wofür die Graka raus muss ...
Vielleicht sollte ich auch einfach den Reset Taster an den CMOS Jumper machen wie hier mal einer schrieb.
Ich sage ja immer wieder gerne, mein altes Asus Hero hat 100€ weniger gekostet und hatte nen Cmos Reset Taster, nen Start Taster und ne Segmentanzeige ... sind die 100€ mehr für den Motherboard-Lüfter
Ich überbrücke die beiden Pins einfach mit einem Schraubenzieher. Das klappt und ist schnell und einfach. Etwas anderes macht der Jumper zum Stecken ja auch nicht. Netzteil ausschalten, 2-3 mal Powertaste vom pC drücken Städten Reststrom, dann überbrücken, Netzteil wieder anschalten und los geht es.
Wollte ich auch gerade vorschlagen
Ist die einfachste Lösung solange es die Hersteller nicht für nötig halten dafür auch bei günstigeren Boards(wobei ich bei den X570F/E nicht mehr von günstig sprechen würde) einen dedizierten Button einzubauen.
Aber ich bin ja schon froh das sich der BIOS Flashback endlich anfängt durchzusetzen.
Meiner Meinung nach sind aber sowohl BIOS Flashback als auch CMOS Resetbutton etwas was als Grundausstattung in jedes Board, was OC unterstützt, reingehört.
Das mit dem Taster scheint schon sinnvoll
Das alte Hero hatte sogar eine "Mem Ok" Tate, die nur die Ram-Settings zurückgestellt hat.
Allerdings habe ich ja extra das 3600er gekauft, weil ich kein Bock mehr hatte, die Settings dauernd neu einzutippern. DOCP muss reichen.
Gestern ging während des Spielens auf einmal der PC aus (keine Warnung, kein Bluescreen, garnichts) - und seitdem lässt er sich nicht mehr starten bzw. es wird kein Sinal mehr an die Monitore weitergereicht. Ich kriege bloß ein scwarzes Bild. Laut dem Motherboad sei es angeblich ein VGA Fehler (weißes Licht) - dabei geht die GPU durcaus "an" (LED Beleuchtung springt an). Installiert ist eine Gigabyte 3090 Vision OC. Installiert sind die neusten Treiber (firmware für die GPU mit resizeable Bar, aktuelle Geforce Experience Treiber, Motherboard-BIOS das aktuellste stabile d.h. nicht Beta).
Ich habe bereits
a) die Grafikkarte in den zweiten PCI Slot gesteckt, hat nichts gebracht
b) einen der RAM-Riegel entfernt
c) Verkabelung überprüft
d) CMOS Reset, mehrfach
e) Motherboard-Bios flash auf ältere, stabilere Versionen über den Flashback Slot
f) Alle unnötigen Kabel (Festplatten, Maus, Tastatur, alle Monitore bis auf einen) entfernt, hat nichts geändert
Hat alles nichts gebracht. Zwar "geht" der PC an, das heißt also die Lüfter spinnen und die ganzen Lämpchen gehen an, an meine Monitore wird aber kein Signal weitergeschleift. Hat hier jemand vielleicht eine Idee? Oder ein ähnliches Problem gehabt?
Klingt nach einem Graka Defekt. Hast du die Möglichkeit das mal gegen zu prüfen? Sprich, Graka in einem anderen PC oder in deinem einfach ne andere Graka rein?
Was theoretisch auch möglich ist ist ein Netzteildefekt. Die 3090 ist ja für fiese Spannungsspitzen bekannt und eine davon könnte dein Netzteil gekillt haben.
Ein Kumpel hat noch eine uralte Radeon rumliegen, die werde ich mir besorgen und dann schauen, ob ich wenigstens noch POST/booten kann (der Error Code vom MB "steht" am Ende auf AA, also "sollte" anversich alles funkionieren) - ich gehe davon aus, dass ich dann auch ein Bild kriege. Werde danach wohl schauen, dass ich die 3090 in einen anderen Rechner eingebaut kriege, um zu sehen, ob sie dort funktioniert. Hoffe aktell auch auf ein Problem mit dem Netzteil. Kann ich jetzt aber nicht nachprüfen, weil ich kein weiteres zur Hand habe. Ich bin mir da aber nicht so sicher, weil der PC anversich ja anspringt - die Lüfter beginnen zu drehen, das Motherboard geht seine Tests/Codes durch und alle LEDs fangen an zu leuchen (inklusive auf der Graka). Ist einfach komisch...
@Morgrain für so einen Fall hat man immer ne olle PCIE GPU rumliegen. Falls nicht vorhanden, besorg dir eine.... Hast du Kabel-Verlängerung am Netzteil? Was für ein Netzteil und wie alt?
Habe ein Corsair RM850x - gekauft 04/2020. Kabelverlängerung nein, abgesehen davon, dass mein Gehäuse das Bequiet Dark Base Pro 900 Rev. 2 ist und es dort zwischen Gehäusewand + Netzteil ein kleines Verbindungskabel zur PSU gibt. Die PSU ist also an das Gehäuse angeschlossen und das Strom-Netzteilkabel von der Wand aus geht dann ins Gehäuse und nicht ins Netzteil direkt. Vielleicht könnte es etwas bringe, mal direkt von der Wand ins Netzteil zu gehen, aber ich wüsste nicht, warum es daran liegen sollte. Hat über viele Monate hinweg ohne Probleme funktioniert...
Netzteil sollte reichen 😁 Hatte mal vor Jahren ein ähnliches Phänomen. Da gabs aber auch noch keine Leuchte, die auf die GPU aufmerksam machte. Es lag an einer defekten EPS Verlängerung, die einen Wackligen hatte. Lief auch über ein Jahr ohne Probleme. Darum meine Frage. Eliminiere jede mögliche Fehlerquelle und org ne alte PCIE GPU.
Ich hatte genau dieses Problem auch schon, allerdings auf dem X-570F mit einer 1080ti. Bei mir war der Verursacher eine Asus Essence STX II. Erst nachdem ich die Soundkarte rausgeschmissen hatte, lief der PC überhaupt wieder an. Nachdem ich dann alles im Bios wieder sauber eingerichtet hatte, konnte ich auch die Soundkarte wieder einbauen. Lief dann wieder problemlos. Das ganze läßt sich reproduzieren, wenn ich die Timings für das RAM zu hart setze. Dann muss die Soundkarte wieder ausgebaut werden, CMOS Reset, booten, einstellen, Soundkarte wieder rein.
Hatte bis Februar noch eine Soundkarte von Asus drin, seitdem läuft bei mir aber ein Receiver über HDMI bzgl Sound. Die Soundkarte ist also schon lange raus. Das kann also nicht die Ursache sein. Problem besteht leider immer noch. Habe schon das Kabel zwischen Netzteil und Gehäuse rausgenommen, hat nichts gebracht. Werde als nächstes jetzt heute ne andere GPU mir besorgen und schauen, ob ich dann irgendwie ein Bild kriege. Wenn das klappt muss ich als nächsten Schritt eben meine GPU in einen anderen Rechner einbauen und dann mal schauen. So ein Mist -.-
@Morgrain: Ich leide wirklich mit dir mit... aber wenn ich mich dabei an meine Geschichte erinnere muss ich einfach nur lachen. Bei mir war es ähnlich, allerdings handelte es sich um ein Gigabyte 890FXA-UD5 mit einem Phenom II X4 955 - also völlig anderes System. Lustigerweise hatte ich auch eine Asus (allerdings die Xonar D2X). Von gestern auf heute, kein Bild mehr... alles schwarz... hatte schonmal so ein ähnliches Problem wo die Ursache ein defektes Netzteil war. Also zuerst Starthilfe von einem anderen Netzteil - selbes Problem. Grafikkarte raus rein, selbes Problem. Zusatzkarten raus, selbes Problem. Dann dachte ich, dass das Mainboard defekt geworden ist - eine andere CPU bzw. RAM hatte ich nicht zum testen da, aber nur ein RAM Riegel und auch umgesteckt hatte nicht geholfen. Dass ich da letztes Jahr nicht mehr ein AM3 Mainboard kaufen oder rumbasteln wollte... liegt auch am Alter des PCs und ich hatte eh mal vor etwas aufzurüsten, insofern.... Um noch kurz fertig zu reden: ich dachte mir, dass es kann ja nicht sein kann, dass kein Pieps von meinem Speaker rauskommt was der Fehler denn sei... ah ja... hatte noch vergessen zu erwähnen: mein PCIe x4 RAID Controller (Areca ARC1210) hat ununterbrochen gepiepst... Dies hat er aber auch ohne installierter Grafikkarte gemacht, weshalb ich die Grafikkarte ausgeschlossen hatte.
Lange Rede, kurzer Sinn: Dann ist es bei mir eben das ROG Strix X570-E geworden mit einem Ryzen 4750 Pro und (noch immer) ohne Grafikkarte (Kinder.......). Jetzt kommt aber der Knüller: Wie's der Teufel will hat ein Kollege von mir ein paar Monate später gefragt, ob denn jemand einen alten AM3 PC braucht, weil er ihn abgeben / verkaufen würde (eben AM3 Mainboard, DDR3 RAM, ich glaube ein Sempron... oder doch ein Phenom? egal...). Da ich keine Ahnung hatte, dass er so eines hat, haben wir halt rumgescherzt, aber ich wollte halt unbedingt wissen was denn der Grund für das Nicht-Funktionieren des PCs wäre.
Jedenfalls: Meine CPU in seinem Mainboard lief, meine RAM in seinem Mainboard liefen auch. Dann dachte ich: ja klar, dann ist es tatsächlich mein Mainboard. -> der Vollständigkeit halber: sein Prozessor und seine RAM in meinem Mainboard liefen auch. Und um die Katze aus dem Sack zu lassen: wieder meine Komponenten in mein Mainboard gesteckt und es lief alles wieder. Was die Ursache war? Keine Ahnung... ich schätze mal ein Kurzschluss oder ein Wackler bei der CPU oder das Mainboard hatte irgendwo das Gehäuse berührt.... was weiß ich... jedenfalls hatte ich die CPU nicht raus und rein getan, aber warum das von gestern auf heute passieren sollte, ist mir echt ein Rätsel...
In diesem Sinne... viel Erfolg! Ich leide (wirklich) mit...
Hatte heute meine GPU in den Rechner eines Freundes eingebaut. Er hat zwar "nur" ein 530er Netzteil, aber wenigstens zum booten / BIOS hätte es ja ausreichen müssen. Leider passierte dasselbe wie bei mir: garnix. Kein Bild. Monitor sagt bloß : kein signal. Komischerweise lief in seinem pc aber auf der Grafikkarten nur die Hälfte der LEDs, also die Gigabyte Aufschrift wurde von links nach rechts immer schwächer beleuchtet. In meinem PC mit meinem 850er Netzteil hingegen läuft zumindest die Beleuchtung auf der GPU gleichmäßig. Bin jetzt unschlüssig, ob es weiterhin ein Problem mit dem Netzteil sein könnte. Die GPU scheint aber in jedem Fall nem Schäden zu haben. Nächster Schritt ist wohl erstmal, mir ne andere GPU zu besorgen und die bei mir einzubauen. So ein Mist..
Mal ein anderes Thema weiss einer wann das aktuelle Bios aus der Beta kommt? Würde gerne endlich mal einen Datentransfer ohne rausschmeissen des USB Laufwerks absolvieren.
