SaureGurke
geht mir genauso!Geht mir genauso mit 25.
Von daher ist die schnelle Action in Battlefront für mich auch ganz spaßig.
Mann merkt ich habe getrungen
Hattest du was anderes erwartet?
That's EA[emoji23]
@Gurke wo bekommst du den Krams so Günstig?
Ist es dann eine Russen Version oder normal Ger?
Fighter Squadron
Take to the skies and dogfight in some of the most memorable Star Wars vehicles including X-wings, TIE fighters, the Millennium Falcon and more.
Supremacy
Rebels and Imperials fight for control of five key points in this intense 40-player clash that takes place on some of the largest maps in Star Wars Battlefront. Take advantage of both ground and air vehicles in order to secure victory for your team.
Cargo
A thrilling tug-of-war experience for fans of Star Wars and capture the flag gameplay. Cargo challenges your team to capture valuable cargo boxes from the opposing team. Get the loot and make your way back to your base – but don’t forget to defend your own precious cargo as each capture counts.
Droid Run
Six Rebels and six Imperials fight to capture and hold on to three GNK Power Droids™. These are the Droids you’re looking for. GONK!
Walker Assault
Fight in epic 40-player battles as a Rebel to destroy the Empire's onslaught of AT-AT's by calling in Y-wing bombers. Or, side with the Empire and protect your Walkers while utilizing their mighty weaponry to crush the Rebel objective.
Blast
A classic Team Deathmatch mode with a Star Wars Battlefront twist. Fast-paced and packed with chaotic fun, Blast pits 10 Rebels against 10 Imperials in a fight to the finish.
Drop Zone
Keep an eye on the sky! Escape pods are crashing down onto the planetary surfaces and your team must fight for control over them. Drop Zone provides frantic 8v8 matches that will put your combat and strategic skills to the test.
Heroes vs Villains
The most valiant Heroes and cunning Villains of the galaxy are clashing in this epic Star Wars Battlefront mode. Luke Skywalker, Darth Vader, Boba Fett, and other iconic characters will be part of your team together with ground troopers. Keep your Heroes and Villains alive to score points and win the battle.
Hero Hunt
Seven Imperials against Luke Skywalker? Seven Rebels battling it out against Boba Fett? In Hero Hunt, one player will experience the thrill of playing as an iconic Star Wars Battlefront Hero or Villain, facing off against ground troops from the opposing faction. Want to play as the Hero? Take them out and you’ll get your chance, but remember, once you become the Hero the hunt is on.
danke @ Gurke
Und dann steht da noch frech "bestseller"season pass und ultimate edition verfügbar Oo
Geht der dlc wahn doch wieder los![]()
Was wird es in Battlefront geben?
Dieser Preisunterschied in Origin ist ja nicht ganz sauberDen Seasonpass gibts auch per Proxy problemlos für 34$. Und 74$ oder 65€ für ein Spiel, das mich wieder mal ein Jahr unterhält, paßt für mich.
Ein RGB-Lichtschwert![]()
Spiel kostet Standard 40$, Deluxe 45$ und der Seasonpass 34$. Oder die Ultimate=Deluxe+Seasonpass für 78$.Wo gibt es Premium für 34 ?
VenezuelaDie Frage ist WO.
Mexiko?
Kann es sein, dass die BETA neben den von EA angegebenen Ports noch weitere nutzt, die nicht dokumentiert sind? Ich habe alle angegebenen Ports in der Firewall freigegeben, trotzdem kann ich mich ingame nicht zu meinem EA-Account verbinden und es bleiben Ports außerhalb der spezifizierten Range im Filter hängen, u.a. 44200 und ähnliche.
Gibt es da irgendwo eine Liste, welche man genau freigeben muss?
steht das nicht in deinem firewall log drin welche pakete verworfen werden?
Das Administrieren einer Firewall ist das A und O - sonst bringt das nämlich nüscht. Musst schon täglich deine Logs lesen..
hatte ich nich genau genug gelesen.Ich habe doch oben geschrieben, dass u.a. Pakete auf Port 44200 hängen bleiben?!
Habe bereits diverse vom Spiel genutzten Ports testweise aufgemacht, der Battlefront-Client verschickt aber dann immer wieder Anfragen auf neuen, weiteren Ports die ich öffnen müsste.
Da kann man sich dann ja ranhalten - daher die Frage, ob es eine Liste gibt.
Bei mir gehts problemlos.Venezuela zeigt mir der Origin Store 120 $ an ?
