[Sammelthread] MSI Z97(I/M/A) Gaming 3/5/6/7/9 (AC/ACK)
[Sammelthread] MSI Z97 GAMING Series
ehemals [Sammelthread] MSI Z97M GAMING
--- MSI GAMING Microsite ---
MSI Z97M GAMING
( Preisvergleich | Produktseite | PDF-Manual | Memory-QVL )
--- MSI Z97M GAMING @ hwbot ---
Spezifikationen
Model numberZ97M GAMING (M7919, 7919-001R)
EAN4719072343187
Form factorµATX (244x244mm)
CPULGA1150
ChipsetIntel Z97
MemoryNumber of slots: 4
Channels: Dual
Corresponding standard: DDR3
3200 (OC) / 3100 (OC) / 3000 (OC) / 2933 (OC) / 2800 (OC) / 2666 (OC) / 2600 (OC) / 2500 (OC)
2400 (OC) / 2200 (OC) / 2133 (OC) / 2000 (OC) / 1866 (OC) / 1800 (OC) / 1600 / 1333
Built-in graphicsHDMI 1.4a (4096x2160 @ 24Hz, 2560x1600 @ 60Hz)
DisplayPort 1.2 (4096x2304 @ 24Hz, 3840x2160 @ 60Hz)
Expansion slot2x PCI Express 3.0 x16 (16+0 / 8+8 Lanes)
2x PCI Express 2.0 x1
Multi-GPU2-Way AMD CrossFire, 2-Way NVIDIA SLI
Storage6x SATA 6Gb/s (RAID 0/1/5/10 support)
1x M.2 (10Gb/s, SATA, 2242/2260/2280, shared with SATA5/6)
2x eSATA 6Gb/s (ASMedia ASM1061, PCIe 2.0 x1)
Audio7.1 Channel Realtek HD Audio (ALC1150)
2x OPA1652 headphone amplifiers (1x front, 1x rear)
LAN1x Qualcomm Atheros Killer E2205 (Gigabit Ethernet)
Interface6x Intel USB3.0 (4x Backpanel, 2x Internal)
2x ASMedia ASM1042 USB 3.0 (Backpanel)
8x USB2.0 (4x Backpanel, 4x Internal)
Internal connector1x 24-pin ATX main power
1x 8-pin ATX 12V power
6x SATA 6Gb/s
2x CPU fan header
2x system fan headers
1x front panel header
1x front panel audio header
1x S/PDIF Out header
1x USB 3.0 / 2.0 header
2x USB 2.0 / 1.1 header
1x TPM header
1x Clear CMOS jumper
1x power button
1x reset button
1x OC Genie
1x audio power switch
Back panel2 x USB 2.0 / 1.1 ports
6x USB 3.0 / 2.0 ports
2x eSATA 6Gb/s
1x clear CMOS button
1x optical S/PDIF Out connector
1x HDMI port
1x DisplayPort
1x PS/2 keyboard & mouse port
1x RJ-45 port
6x audio jacks (Center / Subwoofer Speaker Out, Rear Speaker Out, Side Speaker Out, Line In, Line Out, Mic In)
Super IONUVOTON NCT6792
BIOS64Mb flash (Winbond W25Q64FVSIQ)
UEFI AMI BIOS
ACPI 5.0, PnP 1.0a, SM BIOS 2.7, DMI 2.0
Multi-language
Supported OSWindows 7 / 8 / 8.1
AccessoriesDrivers & Utilities Disc
Motherboard User Guide
I/O Shield
4x SATA Cable
Warranty brochure
Software & Application User Guide
M-Connectors
SLI bridge
case badge
audio power adapter
Door Hanger
BIOS
1) Bilder
siehe User Review​
2) Spannungen
siehe User Review​
3) BIOS Downloads - Achtung: Beim BIOS Update gehen die gespeicherten OC Profile verloren (diese sind nicht auf/abwärtskompatibel).
  • 1.0 (Initial Release)
  • 1.1 (Changes: Enhanced OC Call Back, Update BIOS Code Base & MSI GESII Module, Improved USB compatibility & S4 resume function)
  • 1.2 (Changes: Improved memory & VGA compatibility, adjust OC Genie for Refresh CPUs, Improved M-Flash compatibility, updated Intel RC code)
  • 1.3 (Changes: Improved VGA, PS2 keyboard & CPU compatibility, Enhanced EIST function when use non turbo boost CPU)
  • 1.4 (Changes: Removed 1024MB UMA option, fixed CPU fan down time, improved USB keyboard & memory compatibility, Enhanced MFlash function)
  • 1.6 (Changes: Updated VBIOS, GOP driver & CPU microcode, Improved SAMSUNG M.2 & ASMedia SATA compatibility)
  • 1.7 (Changes: Updated BIOS code to support 5th-Generation Intel Core Processors)
  • 1.8 (Changes: Patched WHQL & LAN issues, updated BIOS code, improved VGA & Blu Ray ODD compatibility)
News & Reviews
Hardwareluxx CPU-Kühler & RAM-Kompatibilitätsliste
1) CPU-Kühler
2) RAM
Wer mir die Arbeit abnehmen möchte, kann seinen Eintrag gern direkt in diesem Format posten. Danke.​
Nützliche Links & Tipps (im Forum & im WWW)
WORK IN PROGRESS :angel:
Habe das Board gerade eingebaut und direkt mal eine Frage, weil ich nicht so häufig PCs zusammenbaue:
Welche Treiber und Dienstprogramme muss ich von der MSI Seite wirklich installieren?
Das erscheint mir ziemlich viel...
Empfehlen würde ich dir
- Intel Chipset Treiber
- Intel Management Engine
- Realtek High Definition Audio Driver (wenn du den Onboard Sound nutzt)
- Killer Network Driver Only (wenn du das Onboard LAN nutzt)
Das meiste andere ist optional, die Utilitys sowieso. Eigentlich ist das aber ziemlich selbsterklärend.
Es hatte offenbar niemand ein Interesse daran einen zu erstellen. Wenn du das nicht selbst übernehmen willst, kannst du es ja mal hier im Thread versuchen.... eventuell kann ich dir sogar weiter helfen :fresse:
Also ich brauch keinen neuen, nur den Titel müßte man ändern in "MSi Z97 Gaming Series" dann könnte man alle Boards drin behandeln. So kommt das irgendwie komisch ^^ Bin halt verwundert weil das so gute Boards sind und kein Diskussionsbedarf herrscht. Auf nem Z97 MSi wurde glaub ich auch der höchste CPU-Z Bench gemacht wenn der nicht gefälscht ist.
Kein Diskussionsbedarf muss ja nicht unbedingt heißen, dass die Boards nicht verbreitet sind. Vielleicht sind sie einfach nur sehr unauffällig im Betrieb. Ich kann mich zum Beispiel auch nicht daran erinnern, dass es sonderlich viele Fragen zu oder Probleme mit den Modellen hier im MB-Bereich gab. Und wer doch mal eine Frage hat, kann sich ja nun auch direkt an den MSI Support hier im Forum wenden.
Edit: Ich werde keinen Sammelthread für die gesamte Modellreihe pflegen, weil es mir zu viel Aufwand ist, das richtig zu machen. Ich habe noch genug andere Threads am Hacken und bin mit denen schon mehr aus ausgelastet.
Was mußt du denn pflegen ?
Kann ja einfach nen Sammelthread für die Serie sein. Nur weil du es nicht over the top machen kannst wegen der zeit heißt es ja nich das man es gar nich machen sollte. Brauchst ja nur den Threadtitel ändern und schreibst halt über dein Review das du aus der gesamten Serie eben Model "XY" nur vorstellst und jut ist. Somit hättest du dann per Sammelthread auch mehr zulauf zu deinem mega Review.
Wenn es für dich/euch in Ordnung, ist dass ich mich nicht selbst um BIOS Updates, Tests usw kümmere, dann dürft ihr den Sammelthread gern entern. Ich werde den Titel dann anpassen.
A pro pos BIOS Update, für das Z97M GAMING:
Ja auch erst gelesen, genauso wie einige komische Unwahrheiten hier neulich zu lesen waren wo selbst ich Abwesender gestaunt habe. Nur 16GB maximal oder nur 2 Riegel für Dual Channel usw. ^^
Die Z97 Serie wird noch sehr lange aktuellen Shit erfüllen.
Da hät ich gleich mal ne Frage. Wie mach ich bei sonem UEFI Bios eigentlich nen Update ? Ich hab gelesen das man sowas einfach online saugt und das Board das wie von allein ausführt ohne groß was einzustellen und USB Sticks zu formatieren.
btw, kann man eigene Ladescreens im Mainboard speichern oder das Bios auf Full HD stellen ?
Danke für den Sammelthread.
Ich Update das BIOS immer mit der im UEFI integrierten Funktion (M-Flash) und einem USB-Stick. Du meinst vermutlich Live Update? Von solchen Windows-basierten Tools bin ich ehrlich gesagt kein Fan, daher kann ich dazu nicht viel sagen.
Während des User Reviews ist mir auch aufgefallen, dass das UEFI nur in 1024x786 angezeigt wurde. Ich hatte dazu zwar nachgefragt, aber vor Beendigung des Tests keine Antwort mehr bekommen.
Wenn dich das Logo stört, aktiviere einfach Fastboot, dann siehst du davon nie wieder etwas :fresse:
Ich bin mir nicht sicher, ob ich die Frage richtig verstehe. Das Boot-Logo ist doch kein Fehler, der sich irgendwie eingeschlichen hat und den man mit Fastboot "beseitigt".
Wenn dir nicht klar ist was Fastboot bewirkt, dann kannst du dich gern darüber belesen und selbst entscheiden, ob du die Funktion nutzen willst. Mein Rechner startet mit aktiviertem Fastboot so schnell, dass ich nicht mehr als einen kurzen Blick auf den Windows-Startbildschirm erhasche (das Logo habe ich davor aber ohnehin stets deaktiviert, weil mir die Informationen des POST wichtiger sind).
Hab gerade ma das Bios durchgewühlt und fastboot gar nich gefunden ?!
Das steht nur unter Win8/8.1
Ob das trotzdem allgemein gilt ?
Schau mal in meinem User Review dabei, darin ist auch das UEFI beschrieben und Fastboot müsste im Text erwähnt werden (mit Screenshot).
Seit dem das neue Board und Windows drauf ist hab ich folgendes festgestellt. Der PC war einmal im Schlafmodus bevor ich die Energieoption eingestellt habe. Beim aufwachen kam eine Festplatte nicht in Schwung, hat ein paar mal geklackert dann lief sie.
Dann hab ich die Energieoption so eingestellt das der PC niemals einpennt, nur Bildschirmschoner. Danach war das mit der Platte auch weg.
jetzt hab ich den PC hochgefahren und dabei hat die Platte dann 5-6 mal geklackert bis sie anlief.
Was erwartet mich da, was kann ich machen ? Ich hatte das nicht einmal beim alten Rechner. Ist die Platte durch das einmal fehlerhafte aufwachen schon beschädigt ?
aber im Betrieb läuft die Platte 1A
Wie sehen die SMART-Werte der Platte aus? Wenn da einer der typischen Punkte im roten Bereich ist, würde ich die Daten sichern und die HDD ausmustern. Sonst Anschlusskabel, Stromanschluss prüfen und ggf wechseln.
Ich habe gerade ein Z97A Gaming 6 hier und eines bereitet mir Probleme, da für mich no-go:
Wie kriege ich das Board dazu, nach dem Shutdown die USB Ports weiterhin mit Strom zu versorgen...und wenn es nur das Frontpanel ist.
Vielleicht bin ich blind und habe es im BIOS nicht gesehen, vielleicht ist das aber auch ein Anspruch, der vom Zusatz "Gaming" heutzutage nicht aufgegriffen wird...erleuchtet mich ;)
Das hatte ich spontan auch gedacht, nachgeschaut, aber das ist per default aus... Jedenfalls wollte mein Phone gestern abend weder am USB 3 noch am 2 des Front panels laden, während es beim Asrock z77 oc formula immer ging 8
MSI Super Charger installiert?
Ja, aber der regelt ohnehin nur den Stromfluss im Betrieb je nach erkanntem Gerät, oder? Jedenfalls ist der und auch die Intel Management Engine installiert, weil ich da Zusammenhänge erhoffte
Ich stochere auch nur im Dunkeln, weil ich mit meinem Lumia keine Probleme hatte. Deshalb würde ich vorschlagen, du wendest dich mit der Frage direkt hier hin: MSI
Wenn ich hier weiterspammen darf mit meinem MPower? :fresse:
2872 9-12-12, fast durch.. unfassbar.
Ja klar darfst du. Für die Z87er Modelle gab es glaube ich keinen eigenen Thread und so viel ist hier ja nun auch nicht los, dass sich jemand gestört dadurch fühlt ;)
Wenn dir langweilig ist, kannst du ja mal die Presets für Samsung und PSC testen. Die liefen größtenteils, bis auf die PSC Presets mit CR=1T, die musste ich manuell auf 2T Command Rate umkonfigurieren. Das liegt wohl daran, dass sie auf dem Xpower erstellt wurden, das beim Speicher etwas stärker sein soll.
Zuerst mal die eigenen Presets:
4x4 2800 C9 2T.. man darf ja noch träumen.
4x4 Presets funktionieren nicht, kann aber auch am 4. Stick liegen.
Update: PSC Presets funktionieren auch nicht. Manchmal komme ich bis zur Betriebssystemwahl, spätestens dann friert alles weg.
Sieht doch gut aus. Ist das "stabil" genug für 32M?
Probier es mal mit nur zwei Sticks^^
Manuell auf 2T konfiguriert?
Leider nicht stabil genug, mein 4. Stick hat Probleme, besonders als Quad Kit..
Der Fehler eben bei den PSC Presets: Hatte das 4x2GB Profil geladen, aber nur mit 2x2GB getestet.
Mit Vollbestückung funktionieren die 4x2GB Profile. Die 2600 und 2666 Profile funktionieren auch alle, solange 2T gesetzt ist. Dafür müssen die Sticks in 1+3 sitzen.
Mit funktionieren meine ich, dass der Winboot möglich ist. :fresse:
Mit 2400C7 hatte ich kurz 1M laufen lassen, aber selbst das gab schon not exact in round.
2600C8 2T
2666C8 Mode 2 2T
2666C8 Mode 1 2T
2400C8 1T
2400C7 2T (2T im Profil hinterlegt)
2400C7, Profil auf 1T geändert
