[Sammelthread] ASUS Rampage IV Extreme ( Intel X79)
Rampage IV Extreme Sammelthread (Intel X79)
Bilder Quelle: Asus HP
Specifications
Specifications
CPU
Intel® Socket 2011 for 2nd Generation Core™ i7 Processors
Supports Intel® Turbo Boost Technology 2
* Refer to ASUSTeK Computer Inc. for CPU support list
Chipset
Intel® X79
Memory
8 x DIMM, Max. 64GB, DDR3 2400(O.C.)/2133(O.C.)/1866/1600 /1333/1066 MHz Non-ECC, Un-buffered Memory
Quad Channel Memory Architecture
Supports Intel® Extreme Memory Profile (XMP)
* Hyper DIMM support is subject to the physicalcharacteristics of individual CPUs.
* Refer to ASUSTeK Computer Inc. or user manual for the Memory QVL (Qualified Vendors Lists).
Multi-GPU Support
Supports NVIDIA® 4-Way SLI™ Technology
Supports AMD 4-Way CrossFireX Technology
Expansion Slots
4 x PCIe 3.0/2.0 x16 *1
1 x PCIe 3.0/2.0 x16 (x8 mode, gray) *1
1 x PCIe 2.0 x1
Storage
Intel® X79 chipset :
2 x SATA 6Gb/s port(s), red
4 x SATA 3Gb/s port(s), black
Support Raid 0, 1, 5, 10
ASMedia® PCIe SATA controller :
2 x eSATA 6Gb/s port(s), red
LAN
Intel®, 1 x Gigabit LAN Controller(s)
Bluetooth
Bluetooth V2.1+EDR
Audio
Realtek® ALC898 7.1-Channel High Definition Audio CODEC
- Supports : Jack-detection, Multi-streaming, Front Panel Jack-retasking
Audio Feature :
- Blu-ray audio layer Content Protection
- Optical S/PDIF out port(s) at back panel
USB Ports
ASMedia® USB 3.0 controller :
8 x USB 3.0 port(s) (4 at back panel, blue, 4 at mid-board)
12 x USB 2.0 port(s) (8 at back panel, black+red, 4 at mid-board)
Overclocking Features
ROG OC Key
- OSD TweakIt
- OSD Monitor
ROG Connect :
- RC Diagram
- RC Remote
- RC Poster
- GPU TweakIt
ROG iDirect
Extreme Engine Digi+ II :
- 8 -phase CPU power design
- 3 -phase VCCSA power design
- 2 + 2 phase DRAM power design
ROG Extreme OC kit :
- Subzero Sense
- VGA Hotwire
- Slow Mode
- LN2 Mode
- PCIe x16 Lane Switch
- Q Reset
- EZ Plug
ProbeIt
UEFI BIOS features :
- ROG BIOS Wallpaper
- GPU.DIMM Post
iROG
Extreme Tweaker
Loadline Calibration
BIOS Flashback
USB BIOS Flashback
Overclocking Protection :
- COP EX (Component Overheat Protection - EX)
- Voltiminder LED II
- ASUS C.P.R.(CPU Parameter Recall)
Special Features
ASUS EPU :
- EPU
CPU Level Up
ASUS Exclusive Features :
- MemOK!
- Onboard Button : Power/Reset/Clr CMOS (at back IO)
ASUS Quiet Thermal Solution :
- ASUS Q-Fan Plus
- ASUS Fan Xpert
ASUS EZ DIY :
- ASUS O.C. Profile
- ASUS CrashFree BIOS 3
- ASUS EZ Flash 2
- ASUS MyLogo 2
ASUS Q-Design :
- ASUS Q-LED (CPU, DRAM, VGA, Boot Device LED)
- ASUS Q-Slot
- ASUS Q-DIMM
- ASUS Q-Connector
Back I/O Ports
1 x PS/2 keyboard/mouse combo port(s)
1 x Bluetooth module(s)
2 x eSATA 6Gb/s
1 x LAN (RJ45) port(s)
4 x USB 3.0
8 x USB 2.0 (one port can be switched to ROG Connect)
1 x Optical S/PDIF out
5 x Audio jack(s)
1 x Clear CMOS button(s)
1 x ROG Connect On/ Off switch(es)
1 x RC Bluetooth switch(es)
Internal I/O Ports 2 x USB 3.0 connector(s) support(s) additional 4 USB 3.0 port(s)
2 x USB 2.0 connector(s) support(s) additional 4 USB 2.0 port(s)
4 x SATA 6Gb/s connector(s)
4 x SATA 3Gb/s connector(s)
2 x CPU Fan connector(s)
3 x Chassis Fan connector(s)
3 x Optional Fan connector(s)
1 x S/PDIF out header(s)
1 x 24-pin EATX Power connector(s)
1 x 8-pin ATX 12V Power connector(s)
1 x 4-pin ATX 12V Power connector(s)
1 x Front panel audio connector(s) (AAFP)
1 x System panel(s)
1 x OC Key header(s)
1 x OT header(s)
2 x Subzero Sense connector(s)
1 x Slow Mode switch(es)
7 x ProbeIt Measurement Points
3 x Thermal sensor connector(s)
1 x LN2 Mode header(s)
1 x Q Reset switch(es)
2 x EZ Plug connector(s) (4-pin in white for memory DIMMs; 6-pin in black for PCIe slots)
1 x Power-on button(s)
1 x Reset button(s)
1 x Go Button(s)
1 x BIOS Switch button(s)
Accessories
I/O Shield
4 x SATA 3Gb/s cable(s)
4 x SATA 6Gb/s cable(s)
1 x 3-Way SLI bridge(s)
1 x 4-Way SLI bridge(s)
1 x SLI bridge(s)
1 x CrossFire cable(s)
1 x Q-connector(s) (2 in 1)
1 x ROG Connect cable(s)
1 x ProbeIt cable set(s)
1 x 12 in 1 ROG Cable Label(s)
1 x OC Key(s)
1 x OC Key cable(s)
1 x X-Socket pad(s)
BIOS
2 x 64Mb Flash ROMs, PnP, DMI2.0, WfM2.0, SM BIOS 2.5, ACPI2.0a Multi-Language BIOS
Manageability
WfM2.0, DMI2.0, WOL by PME, WOR by PME, PXE
Support Disc
Support DVD:
- Drivers and Applications
Kaspersky Anti-Virus
ASUS TurboV EVO Utility
ASUS PC Probe II
ASUS Update
ASUS AI Suite II
ASUS AI Charger+
Daemon Tool Pro Standard
ASUS WebStorage
Form Factor
Extended ATX Form Factor
12 inch x 10.7 inch ( 30.5 cm x 27.2 cm )
Note * This motherboard is ready to support PCIe 3.0 SPEC. Functions will be available when using PCIe 3.0-compliant devices. Please refer to ASUSTeK Computer Inc. for updated details.
Nützliche Links
Problem beseitigungen
Benchmarks zeigen zu geringe Werte am SATA6GB Port = An den richtigen Ports angeschlossen? Klick für Bild
Mein System zeigt mir ständig eine geringe auslastung der Kerne an und taktet sich nicht oder kaum runter = der Intel Rapid Storage Treiber macht im Moment noch Probleme, prüfen ob er installiert ist, wenn ja deinstallieren und den MSAHCI Treiber nehmen..
Probleme mit einem USB Port oder einem USB Gerät? Probiert mal volgendes = Im Windows mal im Energiesparmodus das selektive Abschalten nicht benötigter usb ports deaktivieren....... Danke an plagestonecold
Preissuchmaschine
Reviews
Also Sven seine Brauch 1,32-1,33 für 4,8GHZ
Ich Brauch nur 1,3V (echte Spannung 1,29V) für 4,8GHZ
Obwohl er eine niedrigere VID hat. Ich hab 1,120 und er 1.088
Er hat das Asrock und ich Asus.
Und das bei 20° Wasser.
Also Chiller war aus und is sehr kühl
bedenke bitte dass Prime 27.7 fordernder ist und da ich die doppelte Rammenge verwende ist das auch noch an Mehrbelastung.
Ich kann ja bei Gelegenheit mal Prime 26.6 laufen lassen. Wird aber ein wenig dauern.
Achso, das habe ich übersehen.
Ich Teste morgen mal mit Prime 27.7
Hast du da SP1 bei Windows Instaliert?
Braucht man, ansonsten wird kein AVX genutzt.
Ihh:-D
Ich hasse es eigentlich:d
Wie bekommt man das AVX wieder weg ?
Will es nur für'n Run drauf machen
indem nan 26.6 nimmt? ;)
Würde gern als Vergleich wissen, was meine mir Prime 27.7 Brauch.
Nur so aus Spaß zum Test.
Will AVX dann nicht mehr drauf haben, wenn ich Prime 26.6 nutze.
Habe da mal schlechte Erfahrungen gesammelt.
Glückwunsch zu deinem 1000sten :-)
Darf man fragen warum? Wenn du AVX nicht nutzen willst, nimm halt Prime 26.6. Da ist die Unterstützung von AVX nicht mit drin.
Unstabilität in Programmen.
Ich Teste morgen einfach
Genau das ist der Grund, warum ich Prime 26.6 nicht für tauglich halte. Was in 26.6 für 6 Stunden stabil ist, fliegt mir in diversen Programmen nach nichtmal 5 Minuten um die Ohren.
Wozu AVX, was die CPU quält, wenn man es nicht Brauch ?!
Dazu kann man gut mit weniger Vcore leben
Weil AVX je nach Anwendung um die 40% Mehrleistung bringt!? Da geh ich lieber 100 oder 200MHz mit dem Takt runter und hab trotzdem bessere Performance.
Gern :-)
Ich war heute den 2. Kreislauf und den MIPS Kühler für das Asus auf der Post abgeholt.
Bin aber noch nicht dazu gekommen das Paket auszupacken -.-
Ich werde das Mainboard nun doch behalten und da kommt en 4 Kerner rein.
Meine jetzige CPU komm in ein Asrock X70 Extreme 11 :-)
dann bin ich ja mal auf das Extreme11 gespannt.
---------- Post added at 23:59 ---------- Previous post was at 23:10 ----------
so kühl ist meiner bei weitem nicht! Meine Temperaturen sehen bei 20 Grad Wasser und diesem Takt anders aus.
Oha!
Und ich erst. Endlich neues Spielzeug.
Nächste Woche hab ich was zu tun. Exteme 11.
Dann en Komplettes Top 3770K Bundle. Da geht der Urlaub schnell Flöten.
Welche Temperaturen
Hast du bei 20 Grad ?
Bei mir War da das Wasser 18-20 Grad eingestellt.
Ich Hatte 19° eingestellt am Chiller.
ich genau 20 - somit 20-21 Grad Wasser
Gerade extra für Dich gemacht, gleicher Takt, in etwa gleiche Spannung, gleiches Prime. Nur mehr RAM:
Oha!
Welche Temperaturen
Aber denk dran...ich will aich was zum spielen haben ;)
Gesendet von meinem GT-N7100 mit der Hardwareluxx App
Ohja!
Auch wenn es dann nicht mehr meine ist...werde ich trauern!
Verdammt...wenn ich nur nen gescheiten 6 core endlich bekäme!
ja da muss man lange dran suchen.
Oder eben pretestet kaufen. Ich muss das so machen. Ich habe beim
normalen Kauf nie Glück.
Dito!
Schaut Super aus Sven, unsere Prozessorsn könnten Verwandt sein ?
Mit 1886 Ramtakt benötige ich auch wesentlich weniger Vcore.
Teste das mal mir 2133 RAM, dann wird's interessant.
Das Teste ich heute mal mit 1886 RAM.
Und nochwas. Hast du evtl ein Messerät ?
Falls ja, könntest du mal aus Spaß schauen, was bei Vcore unter Last @4800 anliegt ? (Prime 26.6 Bullid 3)
Denn wenn ich 1,3V im BIOS einstelle, habe ich reale 1,29V (mit Messgerät getestet)
---------- Post added at 09:23 ---------- Previous post was at 09:23 ----------
Du bekommst dein Futter :-)
Ähnliche Themen
