[Sammelthread] Asus Maximus V Gene R.O.G (Intel Z77)
Willkommen im Sammelthread zum ...
Layout:
weitere Bilder:
Spezifikationen:
Chipset Intel® Z77
Memory 4 x DIMM, Max. 32GB, DDR3 MHz Non-ECC, Un-buffered Memory
Dual Channel Memory Architecture
Supports Intel® Extreme Memory Profile (XMP)
* Hyper DIMM support is subject to the physical characteristics of individual CPUs.
* Refer to ASUS or user manual for the Memory QVL (Qualified Vendors Lists).
Graphic Integrated Graphics Processor
Multi-VGA output support : HDMI/DisplayPort ports
- Supports HDMI with max. resolution 1920 x 1200 @ 60 Hz
- Supports DisplayPort with max. resolution 2560 x 1600 @ 60 Hz
Supports Intel® HD Graphics, InTru™ 3D, Quick Sync Video, Clear Video HD Technology, Insider™
Multi-GPU Support Supports NVIDIA® SLI™ Technology
Supports AMD CrossFireX™ Technology
Supports LucidLogix® Virtu™ MVP Technology *1
Expansion Slots 2 x PCIe 3.0/2.0 x16 (x16 or dual x8, red) *2
1 x PCIe 2.0 x4 (black)
1 x mini-PCIe 2.0 x1 *3
Storage Intel® Z77 chipset : *4
2 x SATA 6Gb/s port(s), red
2 x SATA 3Gb/s port(s), black
1 x eSATA 3Gb/s port(s), red
1 x mini-SATA 3Gb/s port(s), black
Support Raid 0, 1, 5, 10
Supports Intel® Smart Response Technology, Intel® Rapid Start Technology, Intel® Smart Connect Technology *5
ASMedia® PCIe SATA controller : *6
LAN Intel®, 1 x Gigabit LAN Controller(s)
Audio SupremeFX III built-in 8-Channel High Definition Audio CODEC
- Output Signal-to-Noise Ratio (A-Weighted): 110 dB
- Output THD+N at 1kHz: 95 dB
- Supports : Jack-detection, Multi-streaming, Front Panel Jack-retasking
Audio Feature :
- SupremeFX Shielding™ Technology
- 1500 uF Audio Power Capacitor
- Gold-plated jacks
- X-Fi® Xtreme Fidelity™
- EAX® Advanced™ HD 5.0
- THX® TruStudio PRO™
- Creative ALchemy
- Blu-ray audio layer Content Protection
- Optical S/PDIF out port(s) at back panel
USB Ports Intel® Z77 chipset :
4 x USB 3.0 port(s) (2 at back panel, blue, 2 at mid-board)
8 x USB 2.0 port(s) (4 at back panel, black+white, 4 at mid-board)
ASMedia® USB 3.0 controller :
2 x USB 3.0 port(s) (2 at back panel, blue)
Overclocking Features mPCIe Combo™ (mPCIe/mSATA combo card)
ROG Connect :
- RC Diagram
- RC Remote
- RC Poster
- GPU TweakIt
Extreme Engine Digi+ II :
- 8 -phase CPU power design + 4 -phase iGPU power design
- 2 -phase QPI/DRAM power design
ProbeIt
UEFI BIOS features :
- ROG BIOS Print
- GPU.DIMM Post
GameFirst
iROG
Extreme Tweaker
Loadline Calibration
USB BIOS Flashback
Overclocking Protection :
- ASUS C.P.R.(CPU Parameter Recall)
Backpanel:
1 x DisplayPort
1 x HDMI
1 x eSATA 3Gb/s
1 x LAN (RJ45) port(s)
4 x USB 3.0
4 x USB 2.0 (one port can be switched to ROG Connect)
1 x Optical S/PDIF out
6 x Audio jack(s)
1 x Clear CMOS button(s)
1 x ROG Connect On/ Off switch(es)
OnBoard-Anschlüsse:
1 x USB 3.0 connector(s) support(s) additional 2 USB 3.0 port(s)
2 x USB 2.0 connector(s) support(s) additional 4 USB 2.0 port(s)
4 x SATA 6Gb/s connector(s)
2 x SATA 3Gb/s connector(s)
2 x CPU Fan connector(s)
3 x Chassis Fan connector(s)
1 x S/PDIF out header(s)
1 x 24-pin EATX Power connector(s)
1 x 8-pin ATX 12V Power connector(s)
1 x Front panel audio connector(s) (AAFP)
1 x System panel(s)
8 x ProbeIt Measurement Points
1 x Power-on button(s)
1 x Reset button(s)
1 x Go Button(s)
1 x mPCIe Combo header(s)
Lieferumfang:
User's manual
I/O Shield
2 x SATA 3Gb/s cable(s)
4 x SATA 6Gb/s cable(s)
1 x SLI bridge(s)
1 x Q-connector(s) (2 in 1)
1 x ROG Connect cable(s)
1 x 12 in 1 ROG Cable Label(s)
1 x ROG Door Hanger(s)
UEFI SCREENS:
Links:
Preisvergleich
Produktseite / Info beim Hersteller
Downloads: Bios, Treiber, Handbuch,...
Downloads: Bios, Treiber, Handbuch... Direktlinks
+ Handbuch MAXIMUS V GENE User's Manual (English)
+ Maximus V GENE Bios 0402 - [First Release Bios]
+ Maximus V GENE Bios 0503 - [1.Improve system stability. 2.Enhance compatibility with some USB devices.]
+ Maximus V GENE Bios 0602 - [Official Beta Bios Asus FTP]
+ Maximus V GENE Bios 0650 - [Beta Bios Shamino]
+ Maximus V GENE Bios 0701 - [Beta Bios Shamino]
+ Maximus V GENE Bios 0805 - [Added DRAM Tuning Improved Performance Default enable thunder bolt support IRST Update]
+ Maximus V GENE Bios 0880 - [Updates system compatibility Improves performance Improves DRAM Overclocking]
+ Maximus V GENE Bios 0881 - [fixed data vref bug ]
+ Treiber Chipsatz: Intel Chipset Software Installation Utility V9.3.0.1019 XpVistaWin7
+ Treiber Chipsatz: Intel Chipset Software Installation Utility V9.3.0.1020 XpVistaWin7
+ Treiber Chipsatz: Intel Management Interface Engine V8.0.0.1262 XpVistaWin7
+ Treiber Chipsatz: Intel Management Interface Engine V8.0.4.1441 Win7 32bit & 64bit
+ Treiber Chipsatz: Intel Management Interface Engine V8.0.10.1464 Win7 32bit & 64bit Windows XP HE MCE Pro 32bit & 64 Bit
+ Treiber SATA: Intel® Rapid Storage Technology V11.0.0.1032 Windows XP/7 32bit & 64bit (WHQL)
+ Treiber SATA: Intel® Rapid Storage Technology V11.1.0.1006 Windows XP/7 32bit & 64bit.(WHQL)
+ Treiber SATA: Intel® Rapid Start Technology Software V1.0.0.1022 for Windows 7 32bit & 64bit
+ Treiber SATA: Asmedia SATA Controller V1.3.4.0 Windows XP 32bit & XP 64bit & Win7 32bit & Win7 64bit (WHQL)
+ Treiber USB: Intel USB 3.0 Driver V1.0.1.209 Win7 32bit & Win7 64bit (WHQL)
+ Treiber USB: Intel USB 3.0 Driver V1.0.4.220 Win7 32bit & Win7 64bit (WHQL)
+ Treiber USB: Asmedia USB 3.0 V1.14.3.0 Windows XP 32bit & XP 64bit & Win7 32bit & Win7 64bit (WHQL)
+ Treiber LAN: Intel Gigabit Ethernet Driver V16.6.0.0 WHQL XpWin7
+ Treiber LAN: Intel Gigabit Ethernet Driver V16.8.1 Win7 32-Bit
+ Treiber LAN: Intel Gigabit Ethernet Driver V16.8.1 Win7 64-Bit
+ Treiber LAN: Intel Gigabit Ethernet Driver V17.0.0 Win7 32-Bit
+ Treiber LAN: Intel Gigabit Ethernet Driver V17.0.0 Win7 64-Bit
+ Treiber Video: Intel Graphics Accelerator V8.15.10.2598 Windows Win7 32bit & Win7 64bit (WHQL)
+ Treiber Video: Intel® HD Graphics Driver V8.15.10.2712 Win7 32-Bit
+ Treiber Video: Intel® HD Graphics Driver V8.15.10.2712 Win7 64-Bit
+ Treiber Video: Intel® HD Graphics Driver 15.26.8.2696 Win7 32-Bit
+ Treiber Video: Intel® HD Graphics Driver 15.26.8.64.2696 Win7 64-Bit
+ Treiber Video: Lucidlogix VIRTU Version 1.2.112.20176 Win7 32-Bit
+ Treiber Video: Lucidlogix VIRTU Version 1.2.112.20176 Win7 64-Bit
+ Treiber Video: Lucidlogix VIRTU V2111120856 Win7
+ Utility Video: LucidLogix Virtu MVP Wizard V1.00.08 for Windows Win7 32bit & Win7 64bit
+ Utility Video: Lucid Virtu Universal MVP Software V2.1.110.19997
+ Treiber Audio: Realtek Audio Driver Version 5.10.0.6570 & 6.0.1.6570 WHQL XpVistaWin7
+ Treiber Audio: Realtek Audio Driver Version 5.10.0.6602 & 6.0.1.6602 WHQL XpVistaWin7
+ Utility Audio: Sound Blaster X-Fi 2 Utility Package V1.0 (R11) Windows 7
+ ASUS AI Suite II 1.0.2.27 Windows XP Win7
+ ASUS AI Suite II 1.0.2.29 Windows XP Win7
+ ROG GameFirst V1.0.1.09
+ ROG ConnectPlus V1.0.0.14
+ ROG Connect V1.0.6.03
+ ROG CPU-Z V1.59.2
+ ROG Theme V1.0.0.12
+ DAEMON Tools Pro V44003120221 XP Win7
Besonderheiten:
Reviews:
[url=http://www.overclockers.com/asus-maximus-v-gene-motherboard-review/]ASUS Maximus V GENE Motherboard Review | Overclockers.com
ASUS Maximus V GENE (Intel Z77) Motherboard Review | TweakTown USA Edition
ASUS Maximus V GENE Motherboard review | guru3d.com
ASUS Maximus V Gene Overclocking Review And Benchmarks | motherboards.org
Asus Maximus Gene V Preview | lanoc.org
ASUS Maximus V GENE Review | votez.net
Asus Maximus V Gene (Z77) Motherboard Sandy Bridge Review | eTeknix.com
Intel Z77 Chipset Launch Roundup - ASUS Maximus V Gene | hardwareheaven.com
ASUS Maximus V Gene| AwardFabrik.de
Au-Ja! - ASUS Maximus V Gene | au-ja.de
Weitere Infos und nützliche Links:
- Maximus IV GENE-Z BIOS Guide - Overclocking
Kompatibilität Arbeitsspeicher:
QVL - QUALIFIED VENDOR LIST - DOWNLOAD
User Berichte:
Kompatibilität CPU Kühler:
+ Corsair H60 (Preisvergleich)(Foto von Emiras)
+ Corsair H70 (Preisvergleich)
+ EKL Alpenföhn K2 (Preisvergleich)
+ Noctua NH-C14 (Preisvergleich)
+ Noctua NH-D14 (Preisvergleich)
+ Prolimatech Genesis (Preisvergleich)
+ Prolimatech Megahalems (Preisvergleich)
+ Prolimatech Black Series Megahalems (Preisvergleich)
+ Thermalright Venomous-x (Preisvergleich)
+ Thermalright HR-02 Macho (Preisvergleich)
+ Thermalright Silver Arrow (Preisvergleich)
Overclocking Ergebnis:
Könntest du das Mittelteil des Halters nicht so verbiegen, dass es nicht mehr stört?
Ah ok, das war auf dem ersten Bild nicht zu erkennen. Bei den Haltern meines Noctua hat man nur eine "Lasche" zum anfassen in der Mitte.
Aber ja, hier stören anscheinend die beiden herausstehenden Teile an der jeweiligen Klammer. Kann man die nicht umbiegen und zwischen die Kühlrippen legen?
Man kann die ein bisschen biegen, aber nicht zur sehr, da die sonst nicht mehr in den Schlitz des Kühlers passen. Habe mir soeben auch zwei Lamellen eingedrückt, da der Halter dann auf die Lamellen eine größere Kraft ausübt.
Wie groß ist der Weg/Spielraum, wenn alles fest verschraubt ist? Bleibt der Abstand gleich oder muss ich Angst haben? Gibt es eine anderes Model, welches eine Backplate hat? Sollte schon eine 7870 sein. Kann die noch umtauschen.
Hast Du zufällig noch alternative Lüfterklammern, die passen könnten - von einem älteren Kühler vielleicht?
Ansonsten: isolieren, dann sollte das auch kein Problem sein. Oder im unteren PCIe-Slot, dennoch, probieren. Eine Karte mit Backplate wäre auch eine elegante Lösung - gerade, wenn ggf. noch umgetauscht werden könnte.
Derlei Probleme hatte ich ja schon beschrieben, bin also leidgeprüft aus eigener Erfahrung ... *ggg*
Leider habe ich keine anderen Klammern. Womit denn am besten isolieren? Reicht einfaches Isolierband? Gibt es denn aktuelle AMD Karten mit Backplate? Habe noch keine gefunden. Unterer Slot ist definitiv keine Lösung, dann liegt die Karte direkt an der Seitenwand.
Also, ich hatte noch Iso-Band im Werzeugkasten; keine Ahnung, ob das jetzt spezielle Eigenschaften hatte; funktionierte aber gut.
Ob und welche Karten nun Backplates haben, das müsstest Du recherchieren; meines Wissens hat z. b. die Asus 7970 DC2 eine Backplate - nagel mich darauf aber nicht fest :-)
MfG.
Die 7970 ist mir aber schon zu mächtig. Mir reicht eine 7870. Löst sich bei dir das Isoband? Kann mri vorstellen, dass sich der Kleber bei Hitze löst.
Also, solange der K2 verbaut war, funktionierte das wunderbar - ich bin aber auf den Prolimatech Genesis umgesteigen, weshalb das überflüssig wurde.
Dann werde ich es auch probieren. Habe die Halter nun ein paar mm biegen können. Sollte mit etwas Glück klappen. Nächste Wochen weiß ich genaueres. Bilder folgen dann.
habe/hatte auch das Problem mit den Lüfterklammern
GENE IV, V 354, GTX 570 Phantom, NH-C14
Die Lüfterklammer berührte das Metallkreuz auf der Rückseite der 570 -> Kein Bild.
Habe dann dünnen Silikonschlauch aufgeschnitten und über die Klammer gezogen -> Bild wieder da.
Hat zufällig jemand diese Kombi und noch einen 120er Lüfter in der Rückseite? Welcher passt noch zwischen
Kühler und Rückwand?
Ikaruga
Habe nun eine Frage zur Montage des K2. Die schwarze Halteplatte hat eine Folie drauf. Auf der Seite welche auf das Mainboard kommt. Muss die runter? In der Anleitung steht nichts darüber.
Wie fest zieht man die Schrauben des Kühlers an?
Soweit ich mich recht entsinne, musste da keine Folie an der Backplate abgezogen werden; welche Schrauben meinst Du denn, für die Sockelmontage oder die Halteklammer des Kühlers?
- egal, welche: die Schrauben werden angezogen, bis kein spürbarer Widerstand mehr besteht - das merkst Du schon.
MfG.
MfG.
Also bleibt die Folie dran?
Ich mein die Schrauben um den Kühler zu montieren. Die mit den Federn.
... die Daumenschrauben der Befestigungsstege werden angezogen, bis kein spürbarer Widerstand mehr besteht; eine Folie ist nicht abzuziehen, es handelt sich lediglich um eine Isolierung.
Gemäß Installationsanleitung vorgehen, dann kann auch nichts schief gehen ...
Habe seit langem wieder einen Desktop angeschafft.
Die Konfiguration ist grob folgende:
MB: Asus Gene V
CPU: 3770K
GPU: 560 GTX TI
16GB Corsair Vengeance
256 GB SSD
Nach dem Zusammenbau und Windows 7 Pro Installation musste ich aber feststellen, dass der Leistungsindex der CPU nur bei 7,2 lag.
Ich habe denn Prime95 laufen lassen und dabei ist mir aufgefallen, dass der CPU nie über 1,6 Ghz taktet?!
Ich habe mehrere Bios Einstellungen getestet(Default, CPU Tune Up auf 4,2 GHz und diverse Optionen aktiviert und deaktiviert) jedoch habe ich es nicht geschafft einen Takt über 1,6 GHz zu erreichen.
Temperaturen sind mit 35-40°C unter Prime 95 unkritisch.
Woran könnte es denn scheitern?
Bin für jede Hilfe dankbar.
Würde mal neueres Bios flashen - am besten zuerst 0503 und dann im Anschluß das 0701.
(Das 0881 finde ich nicht so toll - brauche mehr VCore damit)
Moin Leute,
ich habe mal eien Frage:
Mein Gene V ist heute angekommen und ich will neben Grafikkarte noch zwei weitere Steckkarten auf dem Board betreiben, aber leider läuft dann die Grafikkarte nur mit PCIe x8 ... würde es etwas bringen, wenn ich gewisse Zusatzchips (z.B. USB 3.0) im BIOS deaktiviere? Und wenn ja, welche?
In der Anleitung befindet sich unter 2-17 ein Schaltplan, wenn ich das richtig verstehe, dann müsste ich Dinge, die auf Leitung A liegen deaktivieren, falls das denn überhaupt geht, oder?
Kann ich somit meinen ersten PCIe Slot im x16 Modus betreiben, obwohl die anderen beiden auch bestückt sind?
Mir wäre der x16 schon wichtig, da ich in sehr hohen Auflösungen spiele und mir die Speicherbandbreite deshalb wichtig ist (als Grafikkarte wird eine Hd7970 3GB verwendet).
Gruß,
No0dle
Nein - sobald eine Karte in zweiten x16 PCIe steckt laufen beide auf x8.
Große Nachteile brauchst Du vor allem mit einer PCIe 3.0 kompatiblen Grafikkarte nicht befürchten.
Ivy Bridge CPU hast Du - denn mit einer Sandy Bridge CPU kannst Du den x4 PCIe nicht nutzen - und mit PCIe 3.0 wäre dann ja auch nichts.
Ist das eine Milchmädchenrechnung, wenn ich sage, dass PCIe 3.0 x8 PCIe 2.0 x16 entspricht, da sich die Bandbreite mit PCIe 3.0 verdoppelt hat?
Wenn eine Karte - egal welche - im zweiten roten 16x Slot steckt laufen beide nur noch auf 8-fach soviel ich weiß.
Selbst allein bestückt bringt der zweite nie mehr als 8x. Mit einem neuen Ivy Bridge Prozessor hast du pcie 3.0 und das ist auf 8-fach aber in etwa so schnell wie ein pcie 2.0 16x. Die älteren Sandy Bridges können nur pcie 8x zur verfügung stellen. Sichtbare unterschiede dürften dabei aber kaum entstehen, da selbst pcie 2.0 auf 8x schnell genug für alle Grafikkarten ist.
So weit ich halt so gehört und gelesen hab. ^^
Seit 10 Tagen hab ich auch so ein Maximus V Gene und finde es einfach ein tolles Teil. :-)
Momentan läuft ein 2600K darauf. Er bleibt interessanterweise auf Standardeinstellungen deutlich kühler als auf dem GA-Z68MX-UD2H davor. Ich hab ihn versehentlich ^^ leicht übertaktet (im Bios irgendwo auf "optimiert" gestellt) und er erreichte auf 4,6 GHz gerade mal die Temperaturen wie davor auf Standardtakt. Zwischen 55°-57° mit Prime95. Als Kühler ist seit jeher ein Noctua NH-U9B SE2 drauf. Nur die Lüfter hab ich gegen die PWM-Versionen von Noctua getauscht, da das Board anscheinend keine Spannungsregelung an den Prozessor-Lüftern kann. Meine einzige negative Erfahrung mit dem Board bis jetzt.
Das ganze steckt in einem roten Lian Li 354R. Eine Corsair ForceGT 240GB fürs System und die wichtigsten Programme. Eine WD Black 1TB für den Rest. 16 GB Corsair Vengeance auf 1600, eine Sound Blaster Recon3D Fatal1ty, ein Enermax Platimax und momentan noch eine 560 Ti OC von Gigabyte. Die soll aber bald durch eine Asus GTX 670 DC2 beerbt werden.
Oder doch eine 680? Mal kucken.
Jedenfalls ist das Teil ein richtiges kleines Mini-Rechenmonster. :-)
Ich mag grafisch gut gemachte Computerspiele ganz gern.
Haupteinsatzzweck ist aber die Creative Suite Production.
Dafür ist das Ding einfach perfekt.
Wer will dann da noch einen einen Mac. ^^
---------- Post added at 19:05 ---------- Previous post was at 19:01 ----------
Versteh ich nicht ganz. Ich hab ne Soundkarte im 4x Slot, eine Graka im ersten 16x und einen 2600K. Alle laufen wie sie sollen. Natürlich auf 2.0 aber die Graka auf 16x (laut cpu-z).
Okay ... meine Forte nicht und es gab ein Papperl auf dem Stand 3 Slot nutzen ist nicht ohne Ivy ... merkwürdig.
Danke ihr beiden, sobald ich meine Ivy Bridge CPU habe (Mi/Do), werde ich das ganze mal testen und evtl. hier Vergleichswerte zwischen PCIe 3.0x16 und PCIe3.0x8 in speicherhungrigen Spielen wie ArmA2 und Il-2 Cliffs of Dover posten ;)
Eine Isolierung kann es auch sein. Finde die Anleitung sehr dürftig, dann von dieser Isolierung keine Rede ist. Dienstag bekomm ich endlich meinen 3770k, dann geht es los.
@dhd
3770K hättest Du Dir sparen können - gerade zum Übertakten ist der 2500K oder meinetwegen auch der 2600K ideal; den Mehrwert eines 3770K sehe ich nicht.
Das "Performance-Plus" ist allenfalls bei der integrierten Grafik zu sehen - aber selbst hier nur bedingt; für Multimedia (Blu Ray & Co.) liegt die HD-Grafik der
SB-CPUs gleichauf mit den IB-Modellen. Den Mehrpreis würde ich mir sparen und lieber bei Grafikkarte, SSD oder der Peripherie (Sound etc.) investieren.
Äußerst interessant in diesem Zusammenhang
MfG.
Zu meinem Problem:
Habe mittlerweile Bios 0503 auf 0701 gepatcht. Ohne Ergebnis.
Mit absoluten Default Bios Einstellungen tacktet der erhöht der 3770k seinen Multiplier nicht über 16.
Nach Auto-Tune-Up auf 4,6 GHz ist auch nicht mehr als der 16er Multi drin....nur beim Benchmark denn 10 °C mehr, da VCore um 0,4V höher liegt.
Habe absolut keinen Plan warum.
Gibt es irgendeine Einstellung die hiefür verantwortlich sein kann?
@dhd
MfG.
Sehe ich anders. Sonst hätte ich mir Ivy auch nicht gekauft. Eine SSD habe ich schon und die 7870 reicht um damit ein paar Tage im Jahr zu spielen. ;)
Ähnliche Themen
