[Sammelthread] Asus Sabertooth 990fx
Inhalt:
  • Spezifikationen
  • Bilder
  • Bios
  • Review´s / Test´s
  • Downloads
  • Kompatibilität
  • Preis
  • FAQ
Spezifikationen:
CPU
AMD AM3+ FX™/Phenom™ II/Athlon™ II/Sempron™ 100 Series Processors
Supports AM3+ 32 nm CPU
Supports CPU up to 8 cores
Supports CPU up to 140 W
AMD Cool 'n' Quiet™ Technology​
Chipset
AMD 990FX/SB950​
AMD 990FX/SB950
Memory
4 x DIMM, Max. 32GB, DDR3 1866/1600/1333/1066 Hz ECC, Non-ECC, Un-buffered Memory
Dual Channel Memory Architecture​
Expansion Slots
3 x PCIe 2.0 x16 (dual x16 or x16, x8, x8) *1
1 x PCIe 2.0 x16 (x4 mode, black)
1 x PCIe 2.0 x1
1 x PCI​
Storage
AMD SB950 controller :
6 x SATA 6Gb/s port(s), brown
Support Raid 0, 1, 5, 10
JMicron® JMB362 controller :
2 x SATA 3Gb/s port(s), black
1 x Power eSATA 3Gb/s port(s), green
1 x eSATA 3Gb/s port(s), red​
LAN
Realtek® 8111E , 1 x Gigabit LAN Controller(s)​
Audio
Realtek® ALC 892 8-Channel High Definition Audio CODEC
- Supports : Jack-detection, Multi-streaming, Front Panel Jack-retasking
Audio Feature :
- Absolute Pitch 192kHz/ 24-bit True BD Lossless Sound
- Blu-ray audio layer Content Protection
- ASUS Noise Filter
- Optical S/PDIF out port(s) at back panel
IEEE 1394
VIA® 6308P controller
2 x IEEE 1394a port(s)
(1 at mid-board, 1 at back panel)​
USB Ports
ASMedia® USB 3.0 controller :
4 x USB 3.0 port(s) (2 at back panel, blue, 2 at mid-board)
14 x USB 2.0 port(s) (10 at back panel, black+red, 4 at mid-board)​
Special Features
ASUS Dual Intelligent Processors 2 with DIGI+ VRM
TUF ENGINE! Power Design :
- 8 +2 Digital Phase Power Design
- TUF Components (Alloy choke, Cap. & MOSFET; certified by military-standard)
- ASUS DIGI+ VRM Utility
- E.S.P. : Efficient Switching Power Design
Ultimate COOL! Thermal Solution :
- TUF CeraM!X Heatsink Coating Tech.
- TUF Thermal Radar​
ASUS Exclusive Features
- MemOK!
- AI Suite II
- Anti-Surge
- ESD Guards
- Front Panel USB 3.0 Support
- ASUS UEFI BIOS EZ Mode featuring friendly graphics user interface
ASUS EZ DIY :
- ASUS Q-Shield
- ASUS O.C. Profile
- ASUS EZ Flash 2
- ASUS MyLogo 2
- Multi-language BIOS
ASUS Q-Design :
- ASUS Q-LED (CPU, DRAM, VGA, Boot Device LED)
- ASUS Q-Slot
- ASUS Q-DIMM
- ASUS Q-Connector​
Back I/O Ports
1 x PS/2 keyboard/mouse combo port(s)
1 x eSATA 3Gb/s
1 x IEEE 1394a
1 x LAN (RJ45) port(s)
2 x USB 3.0
10 x USB 2.0
1 x Optical S/PDIF out
6 x Audio jack(s)​
Internal I/O Ports
1 x USB 3.0 connector(s) support(s) additional 2 USB 3.0 port(s) (19-pin, moss green)
2 x USB 2.0 connector(s) support(s) additional 4 USB 2.0 port(s)
1 x COM port(s) connector(s)
6 x SATA 6Gb/s connector(s)
2 x SATA 3Gb/s connector(s)
1 x IEEE 1394a connector(s)
1 x CPU Fan connector(s) (4 -pin)
4 x Chassis Fan connector(s) (3 x 4 -pin, 1 x 3 -pin)
1 x Optional Fan connector(s) (4 -pin)
1 x S/PDIF out header(s)
1 x 24-pin EATX Power connector(s)
1 x 8-pin ATX 12V Power connector(s)
1 x Front panel audio connector(s) (AAFP)
1 x System panel(s) (Q-Connector)
1 x MemOK! button(s)
1 x Clear CMOS jumper(s)​
Accessories
User's manual
ASUS Q-Shield
4 x SATA 6Gb/s cable(s)
1 x SLI bridge(s)
1 x Q-connector(s) (2 in 1)
1 x TUF Certification card(s)
1 x TUF 5 Year Warranty manual(s) (by region)​
BIOS
32 Mb Flash ROM, UEFI BIOS, PnP, DMI2.0, WfM2.0, SM BIOS 2.5, ACPI 2.0a, Multi-language BIOS, ASUS EZ Flash 2,​
Manageability
WfM 2.0, DMI 2.0, WOL by PME, WOR by PME, PXE
Support Disc Drivers
Anti-virus software (OEM version)
ASUS Update
ASUS Utilities​
Form Factor
ATX Form Factor
12 inch x 9.6 inch ( 30.5 cm x 24.4 cm )​
Bilder:
Bilder von Huddel (nochmals danke)
Bilder von JACK RABBITz
(Quelle: User Huddel, Asus, JACK RABBITz)
Bios:
(0402)
Review´s/Test´s
Deutsch
HWLUXX
hartware.net
pcgameshardware
Tom´s Hardware
Englisch
guru3d.com
hardwarecanucks.com
legitreviews.com
Downloads
ASUS Sabertooth Downloadbereich
Asus FTP-Server derzeit wieder mal offline :-(
Betabios 0607 -Fan ignore Bug gefixed, CPU-Lüfter Monitor lies sich nicht abschalten, dadurch kam eine Fehlermeldung beim Booten
Bios 0705
1. Enhance RAID expansion card compatibility.
2. Enable support for Spanish and Russian Language.
3. Enhance RAID0 performance with SB950 native SATA ports.
4. Enable support for UEFI RAID Driver to support RAID partition above 2.2TB
Bios 0810
Bios 0813
1. Improve memory compatibility
2. Improve system stability
Bios 0901
Probleme mit X6 CPU´s, Board startet nicht mehr!
Bios 1102
1.Improve system stability.
2.Enhance compatibility with some USB devices.
3.Patch system hanged when use AM3 1090T or 1100T CPU.
Bios 1208
Bios 1304
Bios 1503
Kompatibilität
Arbeitsspeicher
-Kingston HyperX 2133Mhz 4x 2GB
-G.Skill Ripjaws-X 8GB Kit
-G.SKILL 8GB Kit DDR3-1600 F3-12800CL8D-8GBECO / 1,35V
inkompatibler Arbeitsspeicher
-2x2GB G.Skill F3-10666CL8D-4GBRM 8-8-8-24 1,5v (kein Boot möglich)
Luftkühlung
-Prolimatech Megahalems (mit Retentionmodul)
Wasserkühlung für Chipsatz
Preis
HWLUXX
FAQ
Asus Supportforum
Ich hoffe das geht erstmal soweit (Ist mein erster Sammelthread :)), ich versuche alles aktuell zu halten, nun her mit den Erfahrungen und Informationen...
Es ging mir jetzt nicht so um die Watt Zahl meines NT, sondern es gab/gibt ja Board die mit NT´s von Hersteller XY warum auch immer nicht laufen, eben ähnlich wie mit Speichermodulen, das die sich nicht mögen.
Mir ist nichts bekannt.....aber bei mir ist auch gleich das Cougar gelaufen, bzw verrichtet seinen Dienst Top:bigok:
Hab auch 16 GB zzt drin.....habe auch von G.skill die 1600er drin sniper Variante als 2x4GB.
Da ich noch ein Gutschein von MF hatte, hatte ich mir noch ein Kit von denSniper geholt, allerdings die 1866er. Laufen alle vier Module zzt mit 9-10-9-24
Aber allerdings nur noch im 2 T modus. Sind aber trotzdem vom Durchsatz einen Zacken schneller als unter 1600Mhz.
Nice, Board eingebaut, 901 geflashed, löppt alles. Ram und cpu grob übertaktet+untervoltet klappt alles auf anhieb. Sehr geil :)
Was zeigt bei Euch denn der Thermal Rader bei Vcore 1 und 2 an?
Bei mir hab ich unter Prime blend 52 Grad bei 1 und 47 bei 2.... bei 22.7 ZT....
wir ein heißer Sommer :)
das ist ok. ich hab bis zu 55°C auf 1..
bei welchen settings? ich hab jetzt mit nem x6 3750 Mhz @ 1,42v...
ich hab jetzt 3624Mhz@1,332 unter Last
mit nem PII 1090T
und ich ab extra noch nen 120er Lüfter in die Seitenwand gebaut, der auf den Kühler bläst....ich warte ja immer noch auf nen Boardkühler, damit das teil effektiv mit Wasser gekühlt wird, aber da kommt und kommt nix....hätt mir doch wieder ein CH holen sollen....aber sonst bin ich super zufrieden mit dem Board....brauche viel weniger Vcore für die CPU und sonst sind die Temps ok......hab auch noch nen Sensor unter den Kühler geschoben, der sagt mir nur knappe 38Grad....ich weiß ja nicht, in wie fern die onboard Kalibriert sind und ob überhaupt :)
Wenn sie im Sommer durchbrennen, ist ja Garantie drauf....und Asus hat dann was flasch gemacht :)
ich denke die spawas können bis 90°C ab. Muss man ja nicht herausfordern, aber Sorgen braucht man sich nicht zu machen imo. Ich hab nur passive Belüftung der SpaWas durch die Luft die für den Radi durchs Gehäuse gezogen wird...
Bin von Board-Wakü weg, zuviel Stress bei jedem Umbau, und 3 Boards gehimmelt (weil zu ungeduldig und unvorsichtig), langt mir ;)
Da hast Du wohl recht. Und vor allem teuer :) 100 Euro hat mich mein Kühler für mein CH IV gekostet und bei E-bay ist das Teil für gerade mal 25 euro weg....sowas tut schon weh...daher was solls. Wenns hält :)
mhm hab jetzt doch nen bulli drin, und komme bei 4,4 - 4,6 ghz schon an die grenzen der spawa's mit 80°C im prime ;) naja, mir ist lautlosigkeit atm wichtiger, zum benchen (wenn ich mich nicht zurückhalten können sollte) muss dann halt nen lüfter dazugenommen werden ;)
Das die Teile aber auch so verdammt heiß werden....
Funzt eigentlich k10stat mit den Bulldozern?
da könnte man sich ja schöne Profile zusammenbalsten...für in den Win Betrieb undervolting und weniger MHZ und wenn man leistung brauch eben OC....so hatte ich das vor, bevor mir das Board abgeraucht ist :)
Was ich allerdings sehr toll finde das es keine offizielle Freigabe von Asus für mehr wie 8 GB Kits gibt, obwohl es doch bis 32GB freigegeben ist....oder hab ich da was verpasst?
Wollte nämlich diese oder eher diese die 1. sind ja vom Preis sehr Attraktiv, nur steht ja das sie eher für den Intel Chipsatz Entwickelt!
Hat da jemand einer dieser Kits am Start?
nein, nicht diese. Aber ich hab einaml die G.skill Sniper 1600 7-8-7-24 1,6V drin und nachträglich habe ich mir die G.sikll Sniper 1866 9-10-9-27 1.5 V dazugeholt...
Beide Kits verbaut und lauften mit 9-10-9-24 @1,5 V mit 1866mhz...Allerdings nur noch mit cmr 2 mit nur einem Kit ging 1T aber vielleicht kann der BD das ja besser, ich hab ja noch den P II drauf....
Ok, schön zu Wissen, nur leider sind deine beiden Kits nicht mehr verfügbar!
@Sushi1976
Danke für deine Info, nur wollte ich 1. auf 16GB und 2. bin ich bis jetzt mit GSkill sehr zufrieden so das ich der Marke die treue halten wollte!
Natürlich auch euch allen eine Frohes neues!
AMD psstat soll funzen
@Vagabondxl
Doch, die Kits gibt es noch. Z.B. die G.Skill Sniper DIMM Kit 8GB PC3-14900U CL9-10-9-28 (DDR3-1866) bei Mindfactory....aber ich denke, ich weiß was Du meinst....
als 16Gb Kit gibt es die nicht...nur als 8GB Kit.......
Du hättest gern ein 16GB Kit, oder?
Ich hab ja zwei Kits um auf meine 16GB zu kommen....ich denke, aber das sich das nicht viel nimmt, ob man jetzt ein 16 GB Kitz nimmt mit 4x4GB oder ob man sich 2x das gleiche Kit holt mit 2x4 + 2x4 GB ....und wie man sieht, funzt bei mir das ja sogar mit zwei unterschiedlichen Kits....zzt bei 1,475V
Aber mit denen von Dir ausgesuchten RipjawsZ kannst Du nichts falsch machen...die haben die gleichen Timings und gleiche Arbeitsspannung, wie ich sie jetzt bei meinen G.skill Sniper verwende....Die sollten so laufen....auch wenn dabei steht extra für intel...steht bei den Sniper auch dabei :)
@Oese
Danke für die info :)
@Vagabondxl
@Oese
Ja genau, ich dachte an 16GB Kit!
Würde mich ja mal Interessieren was da nun der Unterschied sein soll bei den beiden Kits, so Unterscheiden sie sich ja nur durch den letzten Buchstaben!?
Hi Jungs, macht euch keine Sorgen. :wink:
Ich habe auch 16GB G.Skins, also Vollbestückung, aus 2 Kits je 2x4GB, siehe meine Sig.
Läuft einwandfrei ohne Probleme. ;)
oki doki
fuzzy
Mal eine kurze Frage an die Radeon 6970-Fraktion: Welche PCIe-Temps habt ihr laut Suite?
Die schreit bei mir rum, dass der PCIe-1-Sensor unter Spielelast 61°C aufweist.
schade dass die ganzen Beiträge der letzten Tage alle verloren sind.
Würde sicher dem ein oder anderen auch helfen bei der Fehlersuche. :rolleyes:
oki doki
fuzzy
Hallöchen,
ich selber bin auch ein stolzer Besitzer eines Sabbertooths. Nun habe ich aber 2 Probleme!
Habe gestern 16 GB (4x 4GB) KHX1600C9D3K4/16GX von Kingston (HyperX) eingebaut. Erst sagte mir Windoof (Windows 7 Ultimate 64BIT) es werden nur 8 GB benutzt. Dann habe ich am Bios was eingestellt dann konnte ich 12 nutzen. Aber ich habe immer noch nicht die vollen 16 GB. Gibts noch eine möglichkeit, dass ich alle nutzen kann?
Desweiteren fahre ich selber noch mit dem alten BIOS. Ich habe mir die ROM- Datei gedownloadet, habe aber absolut keine ahnung wie ich des nun Installiere. Bei Gigabyte gins über Windows-Tools aber bei Asus? Könntet ihr mir weiter helfen.
Danke im Vorraus.
PSC Speicher Test auf dem Sabertooth mit Thuban CPU:
(DDR3-2150) 1075 MHz @ CL 6-9-6-24 1t @ 1,67v
@über mir:
Platziere die Datei (entpackt) z.B. auf Partition "C:", dann geh ins Bios und such den Punkt ASUS EZ-Flash!
Wenn du fündig geworden bist: EZ-Flash starten, auswählen, updaten (WARTEN), danach reboot = fertig!
@Spcial. Hast du mal mit der vDDR Spannung rumexperimentiert? Werd aus der nicht richtig schlau. Kleine Erhöhungen scheinen nichts zu bringen. Erst wenn ich das auf 1.4V stelle scheint der Ram stabiler zu sein. Wie ist deine Erfahrung?
