--> http://macsupport.redaktiv.de/sonstiges-info/spotlight-suche-auf-dem-server.html
Gibts eigentlich gute Dokumentationen/HowTos/Wikis/Foren zu OS X/Darwin; quasi analog zu den gängigen LinuxDistros, die man sich anschauen sollte?
Unter Gentoo gibts sowas ja z.B. on Masse --> da muß man nie dumme Fragen stellen, sondern einfach nur die verfügbare Doku durchwühlen, lesen und verstehen, danach ist es rel. simpel...
werd das ganze am Wochenende mal testen...#man mdutil
mdutil(1) BSD General Commands Manual mdutil(1)
NAME
mdutil -- manage the metadata stores used by Spotlight
SYNOPSIS
mdutil [-pEs] [-i on | off] volume ...
DESCRIPTION
The mdutil command is useful for managing the metadata stores for mounted
volumes.
The following options are available:
-p Publishes the local copies of the metadata stores for the volumes
indicated to their real drives.
-E This flag will cause each local store for the volumes indicated to be
erased. The stores will be rebuilt if appropriate.
-i on | off
Sets the indexing status for the provided volumes to on or off. Note
that indexing may be delayed due to low disk space or other condi-
tions.
-s Display the indexing status of the listed volumes.
SEE ALSO
mdcheckschema(1), mdfind(1), mdutil(1), mdimport(1)
