Hilfe! Rebuild am AMCC 3ware 9650SE seit 7 Stunden bei 0%!
TechnoFeather
Hallo.
Seit 7 Stunden ist mein AMCC 3ware 9650SE Controller nun dabei mein Raid5 neu aufzubauen, weil ich eine WD Platte in Port0 ersetzen musste. Dieser Rebuild hängt aber leider bei 0% fest.
hier mal ein paar Daten dazu:
tw_cli /c0 show all
/c0 Driver Version = 3.00.04.070
/c0 Model = 9650SE-8LPML
/c0 Available Memory = 224MB
/c0 Firmware Version = FE9X 4.06.00.004
/c0 Bios Version = BE9X 4.05.00.015
/c0 Boot Loader Version = BL9X 3.05.00.002
/c0 Serial Number = L326021A710xxxx
/c0 PCB Version = Rev 032
/c0 PCHIP Version = 2.00
/c0 ACHIP Version = 1.90
/c0 Number of Ports = 8
/c0 Number of Drives = 4
/c0 Number of Units = 1
/c0 Total Optimal Units = 0
/c0 Not Optimal Units = 1
/c0 JBOD Export Policy = off
/c0 Disk Spinup Policy = 1
/c0 Spinup Stagger Time Policy (sec) = 1
/c0 Auto-Carving Policy = off
/c0 Auto-Carving Size = 2048 GB
/c0 Auto-Rebuild Policy = on
/c0 Rebuild Rate = 5
/c0 Verify Rate = 2
/c0 Controller Bus Type = PCIe
/c0 Controller Bus Width = 1 lane
/c0 Controller Bus Speed = 2.5 Gbps/lane
Unit UnitType Status %RCmpl %V/I/M Stripe Size(GB) Cache AVrfy
u0 RAID-5 REBUILDING 0% - 64K 4190.92 ON ON
VPort Status Unit Size Type Phy Encl-Slot Model
p0 DEGRADED u0 1.36 TB SATA 0 - WDC WD15EADS-00P8B0
p1 OK u0 1.36 TB SATA 1 - WDC WD15EADS-00P8B0
p2 OK u0 1.36 TB SATA 2 - WDC WD15EADS-00P8B0
p3 OK u0 1.36 TB SATA 3 - WDC WD15EADS-00P8B0
tw_cli /c0 show rebuild schedule
Rebuild Schedule for Controller /c0
Slot Day Hour Duration Status
1 Sun 12:00am 24 hr(s) disabled
2 Mon 12:00am 24 hr(s) disabled
3 Tue 12:00am 24 hr(s) disabled
4 Wed 12:00am 24 hr(s) disabled
5 Thu 12:00am 24 hr(s) disabled
6 Fri 12:00am 24 hr(s) disabled
7 Sat 12:00am 24 hr(s) disabled
'schedule' is not a valid controller parameter of the show command.
tw_cli /c0 show diag
### Time Stamp: 07:56:05 16-Sep-2011
### Host Name: QuadPC
### Host Architecture: x64 (64 bit)
### OS Version: Microsoft Windows Service Pack 1 (Build 7601)
### Model: 9650SE-8LPML
### Serial #: L326021A710xxxx
### Controller ID: 0
### CLI Version: 2.01.09.004
### API Version: 2.06.01.006
### Driver Version: 3.00.04.070
### Firmware Version: FE9X 4.06.00.004
### BIOS Version: BE9X 4.05.00.015
### Available Memory: 224MB
Diagnostic Information on Controller //QuadPC/c0 ...
..power settle (pre-rollcall) pause..
EPCT file not found in flash.
Auto detecting enclosures ...
E=1018 T=00:00:00 : Drive add
P=0h: Drive add confirmed
P=1h: Drive add confirmed
E=1018 T=00:00:05 : Drive add
P=2h: Drive add confirmed
P=3h: Drive add confirmed
Inventory done, port=0
Inventory done, port=2
Inventory done, port=1
Inventory done, port=3
Assigning drive handle 0 to port 0
Assigning drive handle 1 to port 1
Assigning drive handle 2 to port 2
Assigning drive handle 3 to port 3
Associate slots: Rollcall, Begin : find drives
Rollcall, Waiting to start DCB read
--PortHandle[ 0] DriveHandle[ 0] phy: 0
DIT status: DRV_PRESENT (0xFF)
Drv type: SATA Direct
Model #: WDC WD15EADS-00P8B0
Serial #: WD-WMAVU049xxxx
Drv FW #: 01.00A01
Capacity: 2930277168 (0x00000000AEA87B30)
drv ports: Supported 1, Connected : 1
WWN: 50014ee001aa0a82
sasAddr: 0000000000000000
Features: SMART: 1, Security: 1, 48-bit addr: 1, Acoustic: 1,
SCTWriteSame: 1
Feat. Ext: TimeLimited R/W: 0, WDMA FUA: 0, Stream: 0, WWN: 1
Acoustic: 0xFE, def=0x80 (0xFE=best performance)
Security: Status=0x21 (disabled, unlocked)
DMA TCQ: 0 ++ SATA NCQ: 1
Pwr Cycles: 1163, Realloc Sct: 0, Temp (°C): 23
Link Speed: Supported=0x3 (1.5 Gbs to 3.0 Gbs) Current=0x2 (3.0 Gbs)
Spndle Spd: 5400
--PortHandle[ 1] DriveHandle[ 1] phy: 1
Serial #: WD-WMAVU032xxxx
Drv FW #: 01.00A01
WWN: 50014ee0ac47f9fe
sasAddr: 0000000000000001
SCTWriteSame: 1
Pwr Cycles: 1159, Realloc Sct: 0, Temp (°C): 22
Spndle Spd: 5400
--PortHandle[ 2] DriveHandle[ 2] phy: 2
Serial #: WD-WMAVU047xxxx
Drv FW #: 01.00A01
WWN: 50014ee0ac54d08a
sasAddr: 0000000000000002
SCTWriteSame: 1
Spndle Spd: 5400
--PortHandle[ 3] DriveHandle[ 3] phy: 3
Serial #: WD-WMAVU048xxxx
Drv FW #: 01.00A01
WWN: 50014ee0ac54a2b2
sasAddr: 0000000000000003
SCTWriteSame: 1
Pwr Cycles: 1145, Realloc Sct: 0, Temp (°C): 23
Spndle Spd: 0
Rollcall, middle : check DCBs, export JBODs
port 0: Valid DCB
port 1: Valid DCB
port 2: Valid DCB
port 3: Valid DCB
Rollcall, finish : make RAID Units
Num Bins = 2048 : Sectors Per Bin = 4291584
Re-numbering units: (there are 1 valid units)
rank # 0x: 0 FFF FFF FFF FFF FFF FFF FFF FFF FFF FFF FFF FFF FFF FFF FFF FFF FFF FFF FFF FFF FFF FFF FFF FFF FFF FFF FFF FFF FFF FFF FFF
old unit#: 0 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31
new unit#: 0 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31
SETTINGS: Distributing UNIT 0 parameters (count=9, bytes=166)
Port Info [00]: AutoQMode=01 QDepth=31 QMode=NCQ
Port Info [01]: AutoQMode=01 QDepth=31 QMode=NCQ
Port Info [02]: AutoQMode=01 QDepth=31 QMode=NCQ
Port Info [03]: AutoQMode=01 QDepth=31 QMode=NCQ
Updating cache settings for unit: 0
UNIT: 0 (Data) is ONline SCTWriteSame=1, FastRebuild=1, fastVerify=1
Stripelet Size=64k, parities=1
NumActBins=2048, StripesPerBin=11176
Verify RAID5 (80) cap: 8788998144 (task: 0%) (Unclean=0)
CBOD (0)[0] cap: 2929666048 (lbaOff 0)
CBOD (1)[1] cap: 2929666048 (lbaOff 0)
CBOD (2)[2] cap: 2929666048 (lbaOff 0)
CBOD (3)[3] cap: 2929666048 (lbaOff 0)
LUN 0x0 Start LBA 0x0 Size 0x20bdd7800
Cache Settings: WCE=0 - (ForceDriveCacheOn=0) - RCD=0
IgnoreFua=0, WriteJournaling=1, DisableCacheOnDegrade=1
Replay done, D=0x0, P=0x0
AMI Assoc. Slots: AMI 907x enclosure not present.
DcbMgr::WriteSegment(map=0x4B8FB0, segID=0x32, events=8, error=0x0)
DcbMgr::WriteSegment(map=0x4B8FB0, segID=0x33, events=8, error=0x0)
InitConnect credits: 256
DcbMgr::WriteSegment(map=0x4B7D98, segID=0x33, events=8, error=0x0)
DcbMgr::UpdateStatus: UNIT 0 (time 00:00:10)
DcbMgr::WriteSegment(map=0x4B7DF0, segID=0x8, events=8, error=0x0)
DcbMgr::UpdateStatus: (finish 00:00:10)
features: 0x00000003
Driver Firmware
SRL 0x0025 0x0024
ArchId 0x0000 0x0006
Branch 0x0004 0x0000
Build 0x0046 0x009B
Result 0x00000002
64 bit SGL format
Start unit 0x0 Time : 00:00:10
Associate slots: Rollcall, Waiting to start DCB read
Drv FW #: 01.00A01
SCTWriteSame: 1
Spndle Spd: 5400
Drv FW #: 01.00A01
SCTWriteSame: 1
Spndle Spd: 5400
Drv FW #: 01.00A01
SCTWriteSame: 1
Spndle Spd: 5400
Drv FW #: 01.00A01
SCTWriteSame: 1
Spndle Spd: 5400
EVPD pg 0h
EVPD pg 80h
EVPD pg 83h
ReportLuns Cmd, Unit 0
LUN # 0 added
Send AEN (code, time): 0x31, 01/01/1970 00:01:00
Synchronize host/controller time
(EC:0x31, SK=0x00, ASC=0x00, ASCQ=0x00, SEV=04, Type=0x71)
AutoSpare check...
SELF TEST: all tests completed.
Unit 0 A-Verifier STARTED
Send AEN (code, time): 0x29, 09/14/2011 11:16:03
Verify started
(EC:0x29, SK=0x00, ASC=0x00, ASCQ=0x00, SEV=03, Type=0x71)
unit=0
DcbMgr::WriteSegment(map=0x671544, segID=0x33, events=8, error=0x0)
DcbMgr::UpdateStatus: UNIT 0 (time 11:16:03)
DcbMgr::WriteSegment(map=0x67159C, segID=0x8, events=8, error=0x0)
DcbMgr::UpdateStatus: (finish 11:16:03)
[A:1][A:2][A:3][A:4][A:5][A:6][A:7]
[A:8][A:9][A:a][A:b][A:c][A:d][A:e][A:f]
DcbMgr::UpdateStatus: UNIT 0 (time 11:52:08)
DcbMgr::UpdateStatus: (finish 11:52:08)
[A:10][A:11]DcbMgr::WriteSegment(map=0x4B7E18, segID=0x32, events=8, error=0x0)
DcbMgr::WriteSegment(map=0x4B7CB8, segID=0x33, events=8, error=0x0)
DcbMgr::UpdateStatus: UNIT 0 (time 11:57:33)
DcbMgr::WriteSegment(map=0x4B7D10, segID=0x8, events=8, error=0x0)
DcbMgr::UpdateStatus: (finish 11:57:33)
Auto Clean: 0
DcbMgr::WriteSegment(map=0x4C0238, segID=0x33, events=8, error=0x0)
DcbMgr::UpdateStatus: UNIT 0 (time 11:59:13)
DcbMgr::WriteSegment(map=0x4C0290, segID=0x8, events=8, error=0x0)
DcbMgr::UpdateStatus: (finish 11:59:13)
DcbMgr::WriteSegment(map=0x4C02B8, segID=0x32, events=8, error=0x0)
[A:12][A:13][A:14]Send AEN (code, time): 0x31, 09/14/2011 12:05:03
[A:15][A:16][A:17]
[A:18][A:19][A:1a][A:1b][A:1c][A:1d][A:1e][A:1f]
DcbMgr::UpdateStatus: UNIT 0 (time 12:29:43)
DcbMgr::UpdateStatus: (finish 12:29:43)
[A:20][A:21][A:22][A:23][A:24][A:25][A:26][A:27]
[A:28][A:29][A:2a]Send AEN (code, time): 0x31, 09/14/2011 12:55:03
[A:2b][A:2c][A:2d]DcbMgr::WriteSegment(map=0x4B7E18, segID=0x32, events=8, error=0x0)
DcbMgr::UpdateStatus: UNIT 0 (time 13:01:53)
DcbMgr::UpdateStatus: (finish 13:01:53)
[A:2e]Auto Clean: 0
DcbMgr::UpdateStatus: UNIT 0 (time 13:05:13)
DcbMgr::UpdateStatus: (finish 13:05:13)
[A:2f]
DcbMgr::UpdateStatus: UNIT 0 (time 13:06:58)
DcbMgr::UpdateStatus: (finish 13:06:58)
[A:30][A:31][A:32][A:33][A:34][A:35][A:36][A:37]
[A:38][A:39]DcbMgr::WriteSegment(map=0x4B7E18, segID=0x32, events=8, error=0x0)
DcbMgr::UpdateStatus: UNIT 0 (time 13:31:33)
DcbMgr::UpdateStatus: (finish 13:31:33)
Auto Clean: 0
DcbMgr::UpdateStatus: UNIT 0 (time 13:33:33)
DcbMgr::UpdateStatus: (finish 13:33:33)
DcbMgr::UpdateStatus: UNIT 0 (time 13:34:08)
DcbMgr::UpdateStatus: (finish 13:34:08)
[A:3a]DcbMgr::WriteSegment(map=0x4B7E18, segID=0x32, events=8, error=0x0)
Auto Clean: 0
DcbMgr::UpdateStatus: UNIT 0 (time 13:36:08)
DcbMgr::UpdateStatus: (finish 13:36:08)
DcbMgr::UpdateStatus: UNIT 0 (time 13:37:03)
DcbMgr::UpdateStatus: (finish 13:37:03)
[A:3b]DcbMgr::WriteSegment(map=0x4B7E18, segID=0x32, events=8, error=0x0)
Auto Clean: 0
DcbMgr::UpdateStatus: UNIT 0 (time 13:38:33)
DcbMgr::UpdateStatus: (finish 13:38:33)
DcbMgr::UpdateStatus: UNIT 0 (time 13:39:33)
DcbMgr::UpdateStatus: (finish 13:39:33)
InitConnect credits: 1
DcbMgr::WriteSegment(map=0x4C7620, segID=0x33, events=8, error=0x0)
DcbMgr::UpdateStatus: UNIT 0 (time 13:39:38)
DcbMgr::WriteSegment(map=0x4C7678, segID=0x8, events=8, error=0x0)
DcbMgr::UpdateStatus: (finish 13:39:38)
Unit 0 A-Verifier STOPPED
Auto Clean: 0
features: 0x00000001
64 bit SGL format
64 bit SGL format
Power state interrupt 0x00
Time : ..power settle (pre-rollcall) pause..
Associate slots:
Associate slots:
Associate slots:
Drv FW #: 01.00A01
SCTWriteSame: 1
Pwr Cycles: 1163, Realloc Sct: 0, Temp (°C): 33
Spndle Spd: 5400
Drv FW #: 01.00A01
SCTWriteSame: 1
Pwr Cycles: 1159, Realloc Sct: 0, Temp (°C): 32
Spndle Spd: 5400
Drv FW #: 01.00A01
SCTWriteSame: 1
Spndle Spd: 5400
Drv FW #: 01.00A01
SCTWriteSame: 1
Pwr Cycles: 1145, Realloc Sct: 0, Temp (°C): 32
Spndle Spd: 5400
port 0: Valid DCB
port 1: Valid DCB
port 2: Valid DCB
port 3: Valid DCB
Verify RAID5 (80) cap: 8788998144 (task: 46%) (Unclean=0)
InitConnect credits: 0
features: 0x00000000
32 bit SGL format
BBU comm error 0x241 while writing packet : I2C transaction aborted
BBU comm error 0x241 while reading packet : I2C transaction aborted
DcbMgr::UpdateStatus: UNIT 0 (time 13:40:33)
DcbMgr::UpdateStatus: (finish 13:40:33)
Driver Firmware
SRL 0x0025 0x0024
Build 0x0046 0x009B
Result 0x00000002
64 bit SGL format
EVPD pg 0h
EVPD pg 80h
EVPD pg 83h
LUN # 0 added
Send AEN (code, time): 0x31, 09/14/2011 13:40:48
DcbMgr::UpdateStatus: UNIT 0 (time 13:40:45)
DcbMgr::UpdateStatus: (finish 13:40:45)
AutoSpare check...
Verify RAID5 (80) cap: 8788998144 (task: 46%) (Unclean=1)
Send AEN (code, time): 0x29, 09/14/2011 13:41:45
Verify started
unit=0
DcbMgr::UpdateStatus: UNIT 0 (time 13:41:45)
DcbMgr::UpdateStatus: (finish 13:41:45)
Auto Clean: 0
DcbMgr::UpdateStatus: UNIT 0 (time 13:42:00)
DcbMgr::UpdateStatus: (finish 13:42:00)
[A:3c][A:3d][A:3e][A:3f][A:40][A:41][A:42]
[A:43][A:44][A:45][A:46][A:47][A:48][A:49][A:4a]
DcbMgr::UpdateStatus: UNIT 0 (time 14:26:20)
DcbMgr::UpdateStatus: (finish 14:26:20)
[A:4b]Send AEN (code, time): 0x31, 09/14/2011 14:30:45
[A:4c]DcbMgr::WriteSegment(map=0x4B7E18, segID=0x32, events=8, error=0x0)
DcbMgr::UpdateStatus: UNIT 0 (time 14:36:35)
DcbMgr::UpdateStatus: (finish 14:36:35)
[A:4d]DcbMgr::WriteSegment(map=0x4B7E18, segID=0x32, events=8, error=0x0)
Auto Clean: 0
DcbMgr::UpdateStatus: UNIT 0 (time 14:37:50)
DcbMgr::UpdateStatus: (finish 14:37:50)
[A:4e][A:4f][A:50][A:51][A:52]
[A:53][A:54]DcbMgr::WriteSegment(map=0x4B7E18, segID=0x32, events=8, error=0x0)
DcbMgr::UpdateStatus: UNIT 0 (time 14:59:45)
DcbMgr::UpdateStatus: (finish 14:59:45)
[A:55]Auto Clean: 0
DcbMgr::UpdateStatus: UNIT 0 (time 15:01:45)
DcbMgr::UpdateStatus: (finish 15:01:45)
[A:56][A:57][A:58][A:59][A:5a]
DcbMgr::UpdateStatus: UNIT 0 (time 15:16:35)
DcbMgr::UpdateStatus: (finish 15:16:35)
[A:5b]Send AEN (code, time): 0x31, 09/14/2011 15:20:45
[A:5c][A:5d][A:5e][A:5f][A:60][A:61][A:62]
[A:63][A:64][A:65][A:66][A:67][A:68]Send AEN (code, time): 0x31, 09/14/2011 16:10:45
[A:69][A:6a]
DcbMgr::UpdateStatus: UNIT 0 (time 16:15:55)
DcbMgr::UpdateStatus: (finish 16:15:55)
[A:6b]
E=0202 T=16:20:00 : Data ECC error (int)
task file written out : cd dh ch cl sn sc ft
: 60 D2 2D D6 80 80 80
E=0202 T=16:20:00 P=0 : Soft reset drive
E=0207 T=16:20:00 P=0 : ResetDriveWait
E=0202 T=16:20:00 P=0 : Inserting Set UDMA command
E=0202 T=16:20:00 P=0h: Repair LBA 0x922dd68b...OK
E=0202 T=16:20:00 P=0h: Repair LBA 0x922dd68c...OK
E=0202 T=16:20:00 P=0h: Repair LBA 0x922dd68d...OK
Send AEN (code, time): 0x23, 09/14/2011 16:20:00
Sector repair completed
(EC:0x23, SK=0x01, ASC=0x11, ASCQ=0x00, SEV=02, Type=0x71)
port=0, LBA=0x922DD68C
E=0202 T=16:20:00 P=0h: Complete IPRs in error
A-Verifier ERROR, time: eacae (ErrorCode): 202
Start Stripe #: 01245bad
BBU status word : 0x0
//QuadPC/c0 Controller Log Information ...
Serial #: WD-WCAVU024xxxx
Drv FW #: 01.00A01
WWN: 50014ee258bf02bc
SCTWriteSame: 1
Pwr Cycles: 1, Realloc Sct: 0, Temp (°C): 26
Spndle Spd: 5400
Drv FW #: 01.00A01
SCTWriteSame: 1
Pwr Cycles: 1164, Realloc Sct: 0, Temp (°C): 26
Spndle Spd: 5400
Drv FW #: 01.00A01
SCTWriteSame: 1
Pwr Cycles: 1168, Realloc Sct: 0, Temp (°C): 27
Spndle Spd: 5400
Drv FW #: 01.00A01
SCTWriteSame: 1
Pwr Cycles: 1150, Realloc Sct: 0, Temp (°C): 26
Spndle Spd: 0
port 0: No DCB (JBOD)
port 1: Valid DCB
port 2: Valid DCB
port 3: Valid DCB
Degrade RAID5 (80) cap: 8788998144 (task: 0%) (Unclean=0)
d> CBOD (0)[-1] cap: 2929666048 (lbaOff 0)
DcbMgr::WriteSegment(map=0x4B8FB0, segID=0x32, events=6, error=0x0)
DcbMgr::WriteSegment(map=0x4B8FB0, segID=0x33, events=6, error=0x0)
32 bit SGL format
DcbMgr::WriteSegment(map=0x4B7D98, segID=0x33, events=6, error=0x0)
DcbMgr::UpdateStatus: UNIT 0 (time 00:32:31)
DcbMgr::WriteSegment(map=0x4B7DF0, segID=0x8, events=6, error=0x0)
DcbMgr::UpdateStatus: (finish 00:32:31)
Send AEN (code, time): 0x6, 09/16/2011 00:32:31
Incomplete unit detected
(EC:0x06, SK=0x00, ASC=0x6b, ASCQ=0x02, SEV=02, Type=0x71)
unit=0
Driver Firmware
SRL 0x0025 0x0024
Build 0x0046 0x009B
Result 0x00000002
64 bit SGL format
EVPD pg 0h
EVPD pg 80h
EVPD pg 83h
LUN # 0 added
DcbMgr::WriteSegment(map=0x4B7E18, segID=0x32, events=6, error=0x0)
DcbMgr::WriteSegment(map=0x4B7CB8, segID=0x33, events=6, error=0x0)
DcbMgr::UpdateStatus: UNIT 0 (time 00:32:46)
DcbMgr::WriteSegment(map=0x4B7D10, segID=0x8, events=6, error=0x0)
DcbMgr::UpdateStatus: (finish 00:32:46)
DcbMgr::WriteSegment(map=0x4B7CA0, segID=0x33, events=6, error=0x0)
DcbMgr::WriteSegment(map=0x4B7CF8, segID=0x8, events=6, error=0x0)
Send AEN (code, time): 0x31, 09/16/2011 00:32:51
AutoSpare check...
No Replacement list to sort (1)! 1 drive only!
No Replacement list to sort (4)! 1 drive only!
No Replacement list to sort (5)! 1 drive only!
driveHandle=0 Cap=0xAEA87B30
DcbMgr::UpdateArray: UNIT 0 (time 00:33:28)
DcbMgr::WriteSegment(map=0x4BF3D8, segID=0xF, events=2, error=0x0)
DcbMgr::WriteSegment(map=0x4BF420, segID=0x2, events=6, error=0x0)
DcbMgr::WriteSegment(map=0x4BF3D8, segID=0xF, events=6, error=0x0)
DcbMgr::UpdateArray: (finish 00:33:28)
DcbMgr::WriteSegment(map=0x4BF478, segID=0x32, events=8, error=0x0)
DcbMgr::WriteSegment(map=0x4BF478, segID=0x33, events=8, error=0x0)
Rebuild RAID5 (80) cap: 8788998144 (task: 0%) (Unclean=1)
r> CBOD (0)[0] cap: 2929666048 (lbaOff 0)
UA:ReplaceUnitPort complete (errorCode): 0
Unit 0 A-RebuilderRaid5/6 STARTED
Send AEN (code, time): 0xb, 09/16/2011 00:33:48
Rebuild started
(EC:0x0b, SK=0x00, ASC=0x00, ASCQ=0x00, SEV=03, Type=0x71)
unit=0
DcbMgr::WriteSegment(map=0x66FD34, segID=0x33, events=8, error=0x0)
DcbMgr::UpdateStatus: UNIT 0 (time 00:33:48)
DcbMgr::WriteSegment(map=0x66FD8C, segID=0x8, events=8, error=0x0)
DcbMgr::UpdateStatus: (finish 00:33:48)
Auto Clean: 0
DcbMgr::UpdateStatus: UNIT 0 (time 00:33:58)
DcbMgr::UpdateStatus: (finish 00:33:58)
AutoSpare check...
[A:1][A:2]BBU comm error 0x241 while writing packet : I2C transaction aborted
SETTINGS: Saving UNIT 0 parameters ... DcbMgr::UpdateSupport: UNIT 0 (time 00:42:08)
DcbMgr::WriteSegment(map=0x4B7DD8, segID=0x4, events=8, error=0x0)
DcbMgr::UpdateSupport: (finish 00:42:08)
done. (count=5, bytes=132)
done. (count=6, bytes=139)
done. (count=7, bytes=146)
Enable write cache; not dirty
Cache Settings: WCE=1 - RCD=0
IgnoreFua=1, WriteJournaling=0, DisableCacheOnDegrade=0
SETTINGS: Saving UNIT 0 parameters ... DcbMgr::UpdateSupport: UNIT 0 (time 00:42:28)
DcbMgr::UpdateSupport: (finish 00:42:28)
done. (count=8, bytes=152)
[A:3]Send AEN (code, time): 0x31, 09/16/2011 01:22:48
[A:4][A:5]Send AEN (code, time): 0x31, 09/16/2011 02:12:48
[A:6]Send AEN (code, time): 0x31, 09/16/2011 03:02:48
[A:7]
[A:8][A:9][A:a][A:b]Send AEN (code, time): 0x31, 09/16/2011 03:52:48
DcbMgr::UpdateStatus: UNIT 0 (time 04:36:03)
DcbMgr::UpdateStatus: (finish 04:36:03)
[A:10][A:11][A:12]Send AEN (code, time): 0x31, 09/16/2011 04:42:48
[A:13][A:14][A:15][A:16][A:17]
DcbMgr::UpdateStatus: UNIT 0 (time 05:10:13)
DcbMgr::UpdateStatus: (finish 05:10:13)
[A:28][A:29]Send AEN (code, time): 0x31, 09/16/2011 05:32:48
[A:2a][A:2b][A:2c][A:2d][A:2e][A:2f]
DcbMgr::UpdateStatus: UNIT 0 (time 05:46:38)
DcbMgr::UpdateStatus: (finish 05:46:38)
[A:38][A:39][A:3a][A:3b][A:3c][A:3d]Send AEN (code, time): 0x31, 09/16/2011 06:22:48
[A:3e][A:3f]
DcbMgr::UpdateStatus: UNIT 0 (time 06:25:38)
DcbMgr::UpdateStatus: (finish 06:25:38)
[A:40][A:41][A:42][A:43][A:44][A:45][A:46][A:47]
[A:48][A:49][A:4a][A:4b][A:4c][A:4d][A:4e][A:4f]
DcbMgr::UpdateStatus: UNIT 0 (time 07:07:28)
DcbMgr::UpdateStatus: (finish 07:07:28)
[A:50]Send AEN (code, time): 0x31, 09/16/2011 07:12:48
[A:51][A:52][A:53][A:54][A:55][A:56][A:57]
[A:58][A:59][A:5a]BBU comm error 0x241 while writing packet : I2C transaction aborted
[A:5b]BBU comm error 0x241 while writing packet : I2C transaction aborted
[A:5c]BBU comm error 0x241 while writing packet : I2C transaction aborted
[A:5d][A:5e][A:5f]
DcbMgr::UpdateStatus: UNIT 0 (time 07:53:33)
DcbMgr::UpdateStatus: (finish 07:53:33)
[...........................................sehr viele Leerzeichen..............................]
