jaja schon klar jungs. die kenne ich auch! andere spiele haben nur einen fps zähler integriert. ich fragte doch nur, ob crysis das auch hat. scheint aber wohl nicht so zu sein. strange.
crysis hat einen, google mal keine lust für dich zu suchen
Changelog v1.1
• Added FMOD Designer to Mod SDK.
• Added editor.cfg being installed into Crysis 2 root folder to enable useful default settings for custom animations.
• Fixed a bug with CryMaxTools in 3DS Max not being functional.
• Fixed a bug with not working automatic installation of LoadCryMaxTools.ms into respective 3DS Max installation.
• Fixed registry warning when starting Sandbox 3 Editor on Vista/Win7 machines.
• Fixed installation error “Error: Could not access network location $MOBU11_64_PATH$” on 32-bit operating systems”.
• Fixed 32-bit CryTIFF plugin being installed into Photoshop 64-bit version.
• Fixed .bat file for CryMaxTools not installing plugins and tools for all 3DS Max versions properly.
• Fixed a bug with 64-bit 3DS Max plugins getting installed into 32-bit 3DS Max if both are the same release version.
• Fixed a bug with the 3DS Max Exporter not working properly with exporting animations.
• Fixed a bug with the 3DS Max 9 installation to only include plugins from now on as CryMaxTools are not supported for this version.
• Fixed a bug where some installed 3DS Max versions did not show up for automatic plugin installation.
• Removed automatic 64-bit 3DS Max plugin and tools installation (requires manual installation).
• Removed Motion Builder as it is no longer supported.
• Sandbox (64bit) is a mandatory installation.
• Significantly reduced size of the installer.
@Time
Sind diese Settings spielbar mit CF Karten, oder SingleKarten wie HD6970 / GTX 580 oder nur Wunschdenken,- und bleibt somit nur den genialen Bildern vorbehalten...
@timewarp
wann kannste mal die Maps hochladen?? Vorallem bitte ohne dieses hässliche graining das macht das ganze spiel kapput!
Aber wenn du zockst,also ohne Screens machen,wirst du doch bestimmt die Settings etwas zurückschrauben?
Weil 15 FPS sind zum spielen nicht wirklich geeignet.
sagt mal gibt es eine möglichkeit per befehl in der autoexec den grain zu deaktivieren? wäre froh wenn das weg is im game das finde ich nämlich echt schlecht gemacht bei Crysis 2 :/
@Time
Wann wird die Konfig denn fertig sein.
Die Screens sehen so aus als könnten sie eine 580 ins schwitzen bringen![]()
